speedo calibration - JeepForum.com
post #1 of 5 Old 05-22-2004, 10:44 AM Thread Starter
Dr Gutiemouth
Dr Gutiemouth's Avatar
speedo calibration
so im putting on 32" tires this weekend...
im positive its gonna mess with my speedometer
how bad?
how can i calibrate it myself?
or can i?
how much does it cost to have it calibrated?
thanks for your help in advance
Green Jeep Club Member #39
The Almighty 2" BB Jeep Club Member #2
*outdated
Dr Gutiemouth is offline
post #2 of 5 Old 05-22-2004, 11:35 AM
cptn_mrgn78
cptn_mrgn78's Avatar
It will be a little off. How much depends on the stock tire size and gearing. I see that you have a 97 so you are either running 3.05 or 3.55. All you need to do is find the correct speedo gear for your size tire and swap it with your old speedo gear. Here is a website that gives step by step instruction.
http://www.stu-offroad.com/speedo/speed1.htm
I'm sure that some will post a link showing speedo gears and tire size. You can buy the speedo gear from you dealership for $12.
RIP: '97 TJ with 2in Teraflex with QD's. 32in AT's. Hi-lift jack, two 10in subs and a 500 watt amp. 150watt KC Daylighters. Avalanche Engineering Rocker Knockers.
New: '05 Unlimited
cptn_mrgn78 is offline
post #3 of 5 Old 05-22-2004, 11:50 AM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
I mounted 32's as well and my speedo was off (read slower) by 5 mph. I installed the 37 tooth gear and Im back to normal.
I have 4.10, 4.11. f/r
BTW it was very easy to swap the gears. took all of 10 mins tops
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #4 of 5 Old 05-22-2004, 12:35 PM Thread Starter
Dr Gutiemouth
i got 3.73 any ideas on which on i need>?
*outdated
post #5 of 5 Old 05-22-2004, 01:10 PM
RedRubiconLJ
2015 JK Wrangler
Use this chart
http://www.raingler.com/tech/speedoChart.asp
SOLD 2013 JKUR
2004 TJ sold
1993 YJ sold
JB SS SYE - Speedo Calibration Bennettj13 TJ Wrangler Technical Forum 18 02-27-2009 08:58 PM
97 TJ Speedo calibration MillerTimeTJ TJ Wrangler Technical Forum 1 05-08-2007 07:11 AM
Unlimited Speedo Calibration STANSUSKI JK Wrangler Technical Forum 3 02-09-2007 09:41 AM
Speedo Calibration Gav'spurplez TJ Wrangler Technical Forum 20 11-30-2006 09:54 AM
Speedo calibration? Jeepster Tim TJ Wrangler Technical Forum 14 06-28-2005 09:12 AM
