Spazzing Left Blinker / Indicator / Turn Signal - JeepForum.com
post #1 of 14 Old 06-07-2007, 10:06 AM Thread Starter
rjcarrillo1911
Just started the other night on my 2005 TJ Sport. The left turn signal blinks at double the normal speed. The right one is still functioning properly and the when the hazards are on they both function properly. Its been happening for about 3 days. I'm probably going to try and pull the fuse and put it right back and see if that remedies the problem. Any input? Has anyone else ever experienced this same problem?
It used to happen to me once in a while on my 2000 Ford Explorer, but it would go away after a little while. It would smoke a little bit too right behind the steereing wheel where the button for the hazards was and smell like something was burning (with the explorer). I thought it was from me installing an after market stereo, but that didn't really make any sense.
rjcarrillo1911 is offline
post #2 of 14 Old 06-07-2007, 10:09 AM
GW
2015 JK Wrangler
From my experience on other cars, that usually an indication that the signal rely is about to go kaput.
GW is offline
post #3 of 14 Old 06-07-2007, 10:12 AM
njbowhntr
One of your blinker lights is out on that side. Of it was both sides then it would be a fuse or your flasher.
Ron
US Navy 1993-'97
njbowhntr is offline
post #4 of 14 Old 06-07-2007, 10:28 AM
skinton
Are all the light on working? Try you hazards. Check grounds.
I had this problem on my 98. I didn't have the tailight grounded properly are I had taken it off to mount light guards.
1998 TJ Sport, 4.0L - 5 sp
2013 JKU Sport, 3.6L - 6 sp
skinton is offline
post #5 of 14 Old 06-07-2007, 11:01 AM
thejafe
thejafe's Avatar
Same thing happened to me and yep, needed a bulb.
thejafe is offline
post #6 of 14 Old 06-07-2007, 12:22 PM
JDEEEWP
same here only i also noticed that after the turn when the directional was off. the indicator light stayed on. seemed that it was telling me that my blinker was out on that side. sometimes i think my jeep is smarter then me.
'01 TJ Sport (black), 4.0L, 5speed, Dana44, Flowmaster 50, 2"BB + OME, 32"ATs on 16" alloys.
'01 Suzuki GSX-R750(red), -1T 520 kit.
JDEEEWP is offline
post #7 of 14 Old 06-09-2007, 08:48 AM Thread Starter
rjcarrillo1911
checked the lights...
...sure enough, rear bulb was out. The manual also mentions the same thing. Thanks for the help! Picked up some new bulbs last night, plan on changing it today.
post #8 of 14 Old 06-09-2007, 11:00 AM
KeithMutiny
Guest
its simple, its the bulb, thats the indicator that one of the functions arent working, have someone check while you test your signals and brake lights, and just swap the bulb.
*edit* - and im too late, hahaha.
KeithMutiny is offline
post #9 of 14 Old 06-09-2007, 11:20 AM
metfan34
Guest
my left signal will not styay on when i activate it however the lights work nad the right signal will not pop back up after turning when i complete my right turns? any suggetstions?
metfan34 is offline
post #10 of 14 Old 06-09-2007, 12:01 PM
KeithMutiny
Guest
sounds like the multi function switch, which is actually that entire unit comming out of the steering column, but i would check your flasher relays first, just incase.
post #11 of 14 Old 06-09-2007, 12:22 PM
Jonny Jeep
Jonny Jeep's Avatar
Repair the multifunction switch if you can get the spring size you need. See this write up I did...
https://www.jeepforum.com/forum/showthread.php?t=421210
or spend $70 on a new switch.
Jonny Jeep is offline
post #12 of 14 Old 07-06-2021, 03:27 PM
SeaLawyer
My son's '03 is doing this randomly. I replaced the bulb, and it stopped for a few days, but now it's back. I suppose the bulb could have been faulty, but thinking it's something else. Relay?
SeaLawyer is offline
post #13 of 14 Old 07-25-2021, 07:45 PM
SeaLawyer
Having the same issue. Anyone have any thoughts?
post #14 of 14 Old 08-01-2021, 09:56 PM
KevinTJ2000
This was a dirty switch stock on my 2000. Spray some electrical contact cleaner straight down into the switch stock through the hazard light activation switch opening on the steering column and cycle the hazard lights on and off. This is now scheduled preventive maintenance on my Jeep every few years. If I new I could find a replacement part as good as the original, I would replace it. Cleaning as prescribed completly solved this issue and the problem has never returned.
KevinTJ2000 is offline
Left turn indicator when I hit the Brake hunter44102 TJ Wrangler Technical Forum 6 04-17-2010 02:38 PM
New turn signal switch, no left signal? sasquachYJ YJ Wrangler Technical Forum 4 01-25-2010 09:07 PM
Fog lights turn off when left blinker is on phxdrumpro TJ Wrangler Technical Forum 4 02-15-2009 07:22 PM
Need to hear turn signal indicator...seriously Obcean2 YJ Wrangler Technical Forum 8 02-06-2008 05:51 PM
Blinker turn signal crapping out Jgw50 TJ Wrangler Technical Forum 6 04-06-2006 12:00 PM
