Soundbar - JeepForum.com
 1Likes
  • 1 Post By Ironhead
post #1 of 9 Old 09-23-2019, 12:41 PM Thread Starter
aburns1284
Soundbar
Looking to replace my soundbar on my 99 TJ. All I can find is the Vertical Driven one and the reviews were not that great. Any advice?
aburns1284 is offline
post #2 of 9 Old 09-23-2019, 12:52 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
What is wrong with your stock soundbar?
Wheelin98TJ is offline
post #3 of 9 Old 09-23-2019, 12:56 PM
Ironhead
Ironhead's Avatar
I removed the soundbar in my 03 and went with tower speaker pods.
Ironhead is offline
post #4 of 9 Old 09-23-2019, 12:59 PM Thread Starter
aburns1284
The fabric is ripped and wires are exposed and the speakers are not working.
post #5 of 9 Old 09-23-2019, 01:52 PM
Ironhead
Ironhead's Avatar
so you're looking for new speakers or a new bar?
most bars or pods with speakers included will be low quality.
FireMedic82 likes this.
Ironhead is offline
post #6 of 9 Old 09-23-2019, 03:36 PM
FireMedic82
FireMedic82's Avatar
I haven't seen any of the aftermarket sound bars in person, so I can't give suggestion there. But, unless your factory setup isn't bashed up and broken, I'd just replace the speakers with any brand you choose, and look into either re covering it or stripping off the material and spraying it.
Never seen what hides beneath the factory material, so that that suggestion with a grain of salt. Although, if you plan on ditching the factory one anyway, maybe it's worth ripping off the cover, just to see how it looks underneath.
Edit: I'm seeing some oem pods for yours on eBay for quite a bit less than the vertically driven. Maybe that's an option?
Sent from my XT1650 using Tapatalk
Throw the photoshoppers a bone and post your executed mods, we would like to see the after pics. Copy and paste the url. https://www.jeepforum.com/forum/f59/executed-photoshop-mods-1417032/
FireMedic82 is offline
post #7 of 9 Old 09-23-2019, 04:42 PM
Kiwi_TJ
I would second the opinion above. If the outer is shot, you could strip that off and either paint up if you like the shiney look, or rhino line over it for a matt finish.
I replaced the speakers in my stock sound bar with 5.25" Alpine speaker, and packed the space full of pillow stuffing and it sounds much better.
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #8 of 9 Old 09-24-2019, 08:39 AM Thread Starter
aburns1284
Thanks!! Replacing the speakers was def an option that I was going to look into. I will go ahead and go that route and then just try and recover it. Thank you everyone!! I really appreciate the input.
Also...where would the pillow stuffing need to go? I read another post where someone was talking about using pillow stuffing after replacing the speakers in their soundbar.
post #9 of 9 Old 09-24-2019, 04:43 PM
Kiwi_TJ
Hi There,
Just stuff the pillow stuffing inside the sound bar, and leave a little pocket to put the speaker into. It stops the sound from the two speakers reacting inside the sound bar and dampens vibration so that you do not get the sound bar "buzzing" like the door panels on the "rice racers".
Kiwi_TJ is offline
