Smittybilt tube fenders for rear - JeepForum.com
post #1 of 5 Old 04-16-2009, 12:31 PM Thread Starter
detroitmurph
I am looking into putting the rear tube fenders on my TJ but not interested in adding the corner guards. Is it possible to mount the fenders to the body without the use of the corner guards or is there something special about the mounting that requires you to use the corner guards?
detroitmurph is offline
post #2 of 5 Old 04-16-2009, 12:46 PM
jeff83
you will have some trouble welding 3/16 plate to that thin sheet metal that is your tub
build it, wheel it, break it, repeat
1983 CJ 7 (traded for TJ)
1992 YJ Renegade (sold)
1999 XJ Classic (daily driver)
1997 TJ Sport (building)
jeff83 is offline
post #3 of 5 Old 04-16-2009, 01:56 PM
RYANR97
RYANR97's Avatar
I have the corner guards with the tube fender, Yes I think you could just bolt them up using the stock bolts that hold the stock flare on.
RYANR97 is offline
post #4 of 5 Old 04-16-2009, 03:45 PM
pachary
I know that when I ran stock flares, they "flexed". The tube ones won't. I think you will end up with interesting wrinkles as a result.
Unless your rig NEVER rubs those rear tubes............................................. ................the TNT's mounted to 3/16 STEEL hold up fine, but I would rather a flexible flare mounted on the stock sheetmetal.
PAul
2005 TJ Unlimited/I6-M6/Rubi 4:1 Tcase/4.5RESF/1.25JKS BL-1BMML/37"SSRs/WarnM8000/Besttop TireCarrier/Waggy D44/ FR-RR DetroitD44/Cobra Remote CB/custom F&R Bumpers/JeeperMan Skids/York OBA/Rokmen TummyTuck/TNT 3" Fenders and Rear Corners/AA SYE- Carolina Drivelines CV Shaft
pachary is offline
post #5 of 5 Old 04-16-2009, 04:13 PM Thread Starter
detroitmurph
is there tabs that would just be able to screw to the tub?
Smittybilt Tube Fenders RYANR97 TJ Wrangler Technical Forum 95 12-01-2011 09:15 PM
smittybilt tube fenders jpringles YJ Wrangler Technical Forum 17 11-26-2009 08:15 AM
smittybilt tube fenders?? jeepin94 TJ Wrangler Technical Forum 6 05-05-2008 11:33 PM
Smittybilt SRC Tube fenders for TJ detroitmurph TJ Wrangler Technical Forum 0 04-28-2008 11:56 AM
Smittybilt (SRC) Tube Fenders...$200!! JJs99TJ TJ Wrangler Technical Forum 241 10-28-2006 10:43 AM
