Slugish Jeep - JeepForum.com
post #1 of 6 Old 07-04-2010, 09:32 AM Thread Starter
Laxjeepster
Slugish Jeep
My 1997 mwrangler sport 6cyl is running with very little power going up incline and hills. Going through more gas than normal. Not sure it the cataylic convertor is plugged or maybe the oxygen senser... The check engine light came on and the guy at advance auto told me the computer said the 5 cyl. miss fired ?????? Any sugguestions to elimitate
Laxjeepster is offline
post #2 of 6 Old 07-04-2010, 09:36 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
sounds like a bad cat to me.
is your exhaust noticeably quieter?
hold your hand up to the tailpipe when it is running. you should be able to tell if there used to be more exhaust exiting from there.
Mail crawling.
MisfitSeven is offline
post #3 of 6 Old 07-04-2010, 11:28 AM
Outatime05
(Post deleted by author.)
Outatime05 is offline
post #4 of 6 Old 01-06-2012, 11:44 PM
chris4jeep
i think i have the same issue..... do you have to push the gas down alot to get the rpms to go up on hills?
30A&MUD4ME
chris4jeep is offline
post #5 of 6 Old 01-07-2012, 12:49 AM
matt001122
Could also be the TPS (Throttle Position Sensor). Does it seem to "buck" on you, or is it running smoothly when this is happening?
'02 Wrangler Sahara, built from the frame up
matt001122 is offline
post #6 of 6 Old 01-07-2012, 05:29 AM
MisfitSeven
MAiL Crawler.
It could also be a bad spark plug or bad fuel injector at the #5 cylinder.
Did you figure out what was causing the problem?
Mail crawling.
loss of power , misfire , cylinder 5 missfire
slugish jeep asbury YJ Wrangler Technical Forum 15 03-07-2009 06:45 PM
New Owner 1993 yj 4.0 slugish Birdawg YJ Wrangler Technical Forum 3 02-20-2003 02:20 PM
