Skids --> engine skids / diff skids. What brand and Style? - JeepForum.com
post #1 of 10 Old 03-24-2004, 11:39 PM Thread Starter
Sparty
Sparty's Avatar
OK....I want to get some protection for the basement of the Jeep.
I'm looking through Quadratec for some armor. More specifically I'm looking into the Diff. Skids and Engine Skids.... and I really need suggestions
An engine skid (Skid Row) is big and covers the oil pan (right??).....that is around $220. In Quadratec, they have a Rock-It skid that just covers the oil pan for like $65.
Is it worth the extra $160 to get the full blown Engine Skid?
I'm also looking at Diff. Skids. I think I like the Warn for around $65 apiece, is this good, or is there something else out there that I should look at for Diff. Skids?
Thanks.
Sparty is offline
post #2 of 10 Old 03-24-2004, 11:43 PM
JeepFleeb
Guest
For the engine skid I like the new one from Nth Degree in design and price ($125).
JeepFleeb is offline
post #3 of 10 Old 03-25-2004, 12:59 AM
Bebop
Guest
I would also add a power steering pump skid. I took a major hit on that skid that would have surely done in the pump had the skid not been there.
Unfortunately, I don't know the brand for all of my skids cuz the local 4x4 shop ordered and installed it for me.
Bebop is offline
post #4 of 10 Old 03-25-2004, 08:04 AM
Poppy360
Poppy360's Avatar
I think you meant to say the steering box skid. If you can whack your power steering pump...you've got a whole nother set of issues that need to be addressed.
FYI, 4x4rockshop.com has a special going on til the end of the month. You get the Kilby steering box skid and gas tank skid for $250 shipped! Great deal.
'98 TJ Sport 4.0L
RE 3.5" Long Arm w/ 1"BL; 35" KM2's; 8.8; HP30; 4.88's; Dual ARB's; Warn HS9500i; OME Shocks; CO2; Fully Armored; ORO U-Turn Steering; LoD Rear Bumper/Tire Carrier; Durango Steering Box; Heated Seats
Poppy360 is offline
post #5 of 10 Old 03-25-2004, 11:21 AM
Stormtrooper
Stormtrooper's Avatar
looks good, but whats it bolt to?
What is the skid bolt to. From the website it looks like it bolts underneath the oilpan flange? how's that work?
-steve
Cheers, Steve
Stormtrooper is offline
post #6 of 10 Old 03-25-2004, 11:33 AM
Poppy360
Poppy360's Avatar
I'd be a little worried about that lip catching on a rock while backing up.
'98 TJ Sport 4.0L
Poppy360 is offline
post #7 of 10 Old 03-25-2004, 03:40 PM
XXXcursion
Guest
I have the warn oil plate skid, and the best part about it is that it also covers the transmission and ties into the transfer case skid so the jeep will slide over a rock from end to end
XXXcursion is offline
post #8 of 10 Old 03-25-2004, 03:45 PM
Bebop
Guest
That's what I meant to say...thanks for pointing that out!
Bebop is offline
post #9 of 10 Old 03-25-2004, 04:21 PM
JeepFleeb
Guest
-steve
It bolts onto the engine block and the transmission bellhousing.
Personally I wouldn't worry about the lip to drain the oil. It hangs down a facrtion of an inch and only an inch or two wide. That's a pretty small target for a rock to reach up and grab.
XXXcursion: How has your warn held up? I've heard from a few people that it starts to bend once it gets abused.
post #10 of 10 Old 03-25-2004, 04:30 PM
XXXcursion
Guest
Very well actually, a couple little dings but other than that it has held up well
My skid actually has the new mounting setup compared to the older models so i think it should last a long time
Can Skid Row lca skids and engine skids be used together? WranglerTom TJ Wrangler Technical Forum 4 07-30-2006 02:57 PM
Prep question for LCA skids (JKS Mini Skids) VinoTJ YJ Wrangler Technical Forum 3 03-06-2006 09:44 AM
oil pan and diff skids chris06 TJ Wrangler Technical Forum 6 09-25-2005 05:57 PM
Diff Skids Brian P TJ Wrangler Technical Forum 5 07-09-2005 12:30 PM
Diff skids GoTopless TJ Wrangler Technical Forum 19 08-21-2003 08:33 AM
