Side Steps - JeepForum.com
post #1 of 46 Old 10-09-2007, 11:01 AM Thread Starter
mr_federalist
mr_federalist's Avatar
Side Steps
I know they look kinda dorky but my wife and kids could use them. I don't like the round nerf bars, so does anyone have any recommendations for steps that would go on my Unlimited?
These don't look too bad...
http://www.quadratec.com/products/13116_710_07.htm
mr_federalist is offline
post #2 of 46 Old 10-09-2007, 11:33 AM
wahala
I have these installed on my TJ. My wife uses them to get into my jeep with no problem, but I haven't lifted it yet. They took about 1 hour to install, and would install easier if I had done the body lift first.
wahala is offline
post #3 of 46 Old 10-09-2007, 11:48 AM
wonderboy
Guest
For that price you could have someone make you some that would be MUCH better than those!!!
wonderboy is offline
post #4 of 46 Old 10-09-2007, 12:18 PM
chefdab
I still have the stock steps from mine if you're interested. They should bolt right up. PM me and we can work out a deal.
David
2005 LJ w/ RE 5.5 LA riding on 35"MT/Rs
"Roads, where we're going we don't need roads."
... at what point has "NEED" ever come into play when it comes to Jeep upgrades
Originally Posted by ranmannm View Post
I'm a idiot so be genital.
chefdab is offline
post #5 of 46 Old 10-09-2007, 12:20 PM
garybattles
Trail Gear makes rock sliders with tubes that could function as steps. I don't have any pics, but they have a website. I bought their rear bumper with tire carrier and it is good quality.
gmb08
garybattles is offline
post #6 of 46 Old 10-09-2007, 12:21 PM
bigchevyman24
bigchevyman24's Avatar
I like these(Ryanstulc's rig):
Not sure where to get those from but maybe you can private message ryanstulc or someone else will chirp in...his profile says they are "reverse-a-bar side armor"
Or these at poison spyder:
http://www.spydercustoms.com/index2....tes/index.php4
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline
post #7 of 46 Old 10-09-2007, 01:03 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I put my wife on a diet and she could get into the jeep just fine after a 30lb. weight loss.I told her I just couldn't afford side steps
TheBoogieman is offline
post #8 of 46 Old 10-09-2007, 01:22 PM
bigV
bigV's Avatar
http://www.4x4products.com/
bigV is offline
post #9 of 46 Old 10-09-2007, 01:55 PM Thread Starter
mr_federalist
Thanks for all the suggestions. The jeep already has rock sliders so I'm just looking for something to bolt up underneath.
post #10 of 46 Old 10-09-2007, 02:17 PM
klimb2xs
I was looking at those also. But I opted for the Jeeperman frame mounted skids. I just received them yesterday and they only took 30 minutes to install.
I know Jeeperman went out of buisness, but Redrock had them in stock for $399 with free shipping.
klimb2xs is offline
post #11 of 46 Old 10-09-2007, 02:45 PM Thread Starter
mr_federalist
What do they look like? Will they fit a rubicon?
post #12 of 46 Old 10-10-2007, 09:44 AM
chefdab
Here's the best pic I have of them on.
They should fit your Rubicon just fine. They are the same grey color as the sport flares and the swaybar cover. Look at the frame rail under your door. There should be a couple of hole and two slots for the steps. You would probably need to get some nutzerts for the holes but other than that they will bolt right in. They basically slide into the slot and then the bolts are for extra support. I'm not sure if I still have the bolts though, just the steps.
David
chefdab is offline
post #13 of 46 Old 10-10-2007, 09:57 AM
halfmoonclip
Yes, the factory side steps will fit a Rubicon. Ask me how I know this.
They do look a little nerdy, but they work well for the vertically challenged getting in and out. They also let me step out of a muddy/snowy spot and not track ALL the glop inside. They're also pretty cheap.
Avoid nutserts like a social disease. Instead, get the threaded hooks that loop thru the same holes in the frame. Jeepsareus should have them; quick and easy to use, and you won't say 'heck' or 'pshaw' even once.
What I would like, personally, is the retro-looking stirrup side step, but I can't find them to bolt on.
Moon
'04 Rubi, manual, usual options, Hella H-4s, any range lockers, Randy's booster seats, Oly pushbar, 245/75R16 BFG
'09 Audi A4 Avant- my bride's schnellpuffenpanzer
'12 Ford Focus-the sure way to get good Jeep mileage
'07 Dodge Caliber R/T AWD-da kid's ride
Goodbye Old Blue XJ; 10+yrs, 100K+ miles; virtually trouble free; Long may you run!
halfmoonclip is offline
post #14 of 46 Old 10-10-2007, 10:28 AM Thread Starter
mr_federalist
Moon
You mean this style? Oops, forgot to ask how you know this?
http://www.4wd.com/productdetails.aspx?partID=13616
post #15 of 46 Old 10-10-2007, 06:43 PM
halfmoonclip
Naaaah, the steel stirrup style that attach permanently (or at least as permanently as ANYTHING is on a Jeep...did you see the thread about antiseize and PB Blaster?) to the frame...kinda a U shape with a step at the bottom. Old-timey Jeeps used 'em.
Thnx,
Moon
ETA- great nom de net! Are you a Thompson guy?
M
Need some help with side steps... dirtyjeepgirl75 TJ Wrangler Technical Forum 4 01-08-2008 02:48 PM
TJ vs LJ side steps Xlr8n TJ Wrangler Technical Forum 9 05-05-2007 02:31 AM
side bars/side steps oddball TJ Wrangler Technical Forum 6 06-06-2006 08:28 PM
OE Side Steps SpitNine TJ Wrangler Technical Forum 5 12-21-2002 09:10 PM
