Shouldn't my AC blow colder than 58? - JeepForum.com
 7Likes
post #1 of 26 Old 07-03-2021, 07:28 AM Thread Starter
joeyroe
I've already taken my jeep to 3 different shops, and each time they just evacuate/recharge my system, tell me my pressures are good, BUT nobody can make it blow colder than 58 degrees.
Maybe I'm being too picky, but I think it should blow colder. Assuming I'm right, does anyone have any ideas where the problem lies?
Further details...
  • Heat and defraust work fine
  • Blend door seems to work (I think) because I can turn on/off heat
  • Compressor and fans seem to work fine
  • No evidence of any leaks
joeyroe is offline
post #2 of 26 Old 07-03-2021, 07:44 AM
Silverstoneavb
I'm pretty certain the condenser is what regulates how cool the freon is. Look there if you have problems with temp. I've been experiencing my HVAC not being as cool also but pretty sure that's been due to AZ being 110+. It just can't keep up
Sent from my Pixel 4 using Tapatalk
Silverstoneavb is offline
post #3 of 26 Old 07-03-2021, 04:28 PM
badmoose
My old rule of thumb on ag equipment was 40 degrees below ambient temperature.
2005 TJ
Zone 3" suspension lift
General Grabber AT2's 33x12.5x15
badmoose is offline
post #4 of 26 Old 07-03-2021, 07:59 PM
jeep_boy02
1934 CJ7
Yes... it depends on ambient air temp and pressures. I believe residential is around 30 cooler so that's a good ballpark.
Did you get a reading printout or a look at the gauges? Compressor could be in the green but on the low side instead of a midzone reading. Working but not working as well as it should you know.
Also double check the condenser fins aren't mashed about. Lowes has a fin straightener for like $8.
Sent from my SM-A015A using Tapatalk
joeyroe likes this.
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #5 of 26 Old 07-05-2021, 06:05 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
https://drivrzone.com/proper-auto-ac-vent-temperature/
joeyroe likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #6 of 26 Old 07-27-2021, 07:43 AM
henderson49
58 is warmer than it should be. The general rule is 40 below ambient air temp, but mine will reach 45 even when outside temp is 95. Park in the shade, close the side vents and measure temp in the middle air vent on dash-set the blower on second setting (not wide open) and give it 4-5 minutes to reach lowest temp. About a year ago I had to replace compressor/condenser and 2 switches to get it to operate where it had been.
joeyroe likes this.
henderson49 is offline
post #7 of 26 Old 07-27-2021, 04:57 PM Thread Starter
joeyroe
Related Question...?
Do you think it might help to insulate the Liquid line that runs from the condenser to evaporator?
It seems logical since it's the longest "cold" AC line and it's exposed to scorching engine heat. Unless I'm mistaken, the orifice is on the condenser side of the line which explains why the entire line is cold (albeit, barely after engine is hot).
joeyroe is offline
post #8 of 26 Old 07-28-2021, 07:30 AM
henderson49
Update on my AC. Noticed yesterday the air from vent seemed warmer with full blower setting. Admittedly it was 90+ degrees outside. Got home and checked the temp, in the shade at second blower speed and side vents closed as recommended. Engine idle at 1500 RPM's. Got 45 degrees at second blower speed and 60 degrees at full blower speed (on recirculate setting). Not sure if the 60 degree rating is because of higher ambient temp or not.
post #9 of 26 Old 07-28-2021, 08:23 AM
TheBoogieman
I've never had to check AC temps ever. If it's 100 degrees outside (95% or higher humidity regularly) and I'm comfortable with the AC on medium, I'm good. It takes under 10 minutes to check it with a gauge and add R-134 to the system. I buy the stuff with stop leak and oil, just in case.
post #10 of 26 Old 08-01-2021, 06:07 PM
aston4
I think you should investigate the blend door more thoroughly.
Also make sure the evaporator isn't freezing up. I just went through this issue, it was a combination of a little too much freon and a blocked drain hole.
aston4 is offline
post #11 of 26 Old 08-03-2021, 03:32 PM
tr21triton
my a/c pressure's are low on both the low and high side. i get 30 on the low side and 190 on the high side . vacumed the system and replaced all the o-rings then added freon and it never came up. air was cold but not in the range or pressures in the manual. added more freon and still wouldn't come up.
tr21triton is offline
post #12 of 26 Old 08-04-2021, 10:14 AM
aston4
those pressures ought to give you some cold air.
is the low pressure line cold? if it is, it's a venting/blockage issue
aston4 is offline
post #13 of 26 Old 08-04-2021, 10:50 AM
aston4
aston4 is offline
post #14 of 26 Old 08-04-2021, 10:56 AM
aston4
aston4 is offline
post #15 of 26 Old 08-04-2021, 12:02 PM
tr21triton
it got down to around 50. outside temp was 80 . fsm said i should get 33-44, low side should be 32-41, high side 200-260. i do notice i cant get it to blow out of the defrost vents, but does blow out the dash and floor. are you saying blend door problems, i'll have to check the l/p line....
