shifting into 4 wheel high - JeepForum.com
post #1 of 3 Old 08-03-2010, 09:45 PM Thread Starter
wrangler4
My 2004 rubicon has a 4 inch lift and 33's was bought this way . If I shift it into 4 high when I'm stopped it will not lock the 4 wheel drive but puts my transmission into neutral even when I shift into any gear. this only happens in 4 high 4 low is fine. When I'm moving 4 high works fine. So what's not connected? Again only when I'm not moving the 4 high light also won't come on either. Any gear while moving no problems any answers?
wrangler4 is offline
post #2 of 3 Old 08-03-2010, 10:07 PM
freeskier93
The t-case has a neutral selection, make sure your not in neutral in the t-case. If you have a body lift it might cause the linkage to be off, so what looks like 4wd hi is neutral. Though linkage can be adjusted.
Also, the NV series t-case is a on the fly system and is meant to be shifted into 4wd hi while moving (note: only with 4wd hi, 4wd low should be engaged at a stop or very low speeds, under 5mph). I find when trying to shift into 4wd hi at very low speeds/sopped it grinds and doesn't work, it's meant to be shifted while moving.
freeskier93 is offline
post #3 of 3 Old 08-03-2010, 11:22 PM
fang_x
fang_x's Avatar
just play with the lever, on my 4inch of lift and 33's i had to sort of set the 4high part al ittle higer then it wanted to to set it. it works fine. sometimes the light wont turn on, but you can feel the difference
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
4hi , tj , wrangler , linkage , shifter
shifting into 4 wheel high wrangler4 TJ Wrangler Technical Forum 9 08-06-2010 01:02 AM
Clanging Noise Shifting at High RPM's PSYCH0 TJ Wrangler Technical Forum 6 02-18-2009 09:02 PM
High Rpm While Shifting 172heavy TJ Wrangler Technical Forum 7 07-14-2008 10:09 AM
High engine rev's when shifting tjboy TJ Wrangler Technical Forum 4 12-21-2005 07:52 PM
