SERIOUS Vibration! Not DW, NEED HELP!! - JeepForum.com
post #1 of 10 Old 07-10-2010, 08:47 PM Thread Starter
rastaangel
Today I was driving into the city and after I stopped to take a leak all of a sudden my jeep developed the most savage vibration EVER!!!
I tryed playing around with tire pressure and that did nothing...
I know its not death wobble because it doesnt shake my steering wheel, its just shakes my jeep like a uber paint shaker over 80km/hr and only gets worse there after...
It is lifted 2.5" but my drive shaft isnt at a bad level cuz I drop my TC with washers...
The tires are 33x13.5 rockers that have been on for 2 months now, no vibes before this...
When I got to the city I jacked it up and checked to see if there was play in my ball joints, and i found none and double checked the lug nutrs for tightness...
And now for the weird part.......
This massive vibration comes and goes... it will completely stop for 30 secs then do it lightly for 10 secs then stop for a while then go into a massive horribly scary shake to the point I have to slow down then I spped up and it does nothing then this vibe comes back...
I NEED HELP lol
rastaangel is offline
post #2 of 10 Old 07-10-2010, 08:54 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
DS U joints?...
Gone but not forgotten.
Knuckelhead is offline
post #3 of 10 Old 07-10-2010, 09:11 PM Thread Starter
rastaangel
When I got gas I crawled under neither and it didnt feel loose...
post #4 of 10 Old 07-11-2010, 05:03 PM
wushaw
Rockin jeep
wushaw's Avatar
Did you check all your tires for a possible belt seperation.
wushaw is offline
post #5 of 10 Old 07-11-2010, 05:18 PM Thread Starter
rastaangel
Today I took my rockers off and put my 235/75 winter tires on and there is now no vibration what so ever...
So the problem is the tires...
How can they be outta balance that bad when there balacned with beads?
How can I tell if there seperating?
post #6 of 10 Old 07-11-2010, 05:45 PM
wushaw
Rockin jeep
wushaw's Avatar
Simple, take your hands and rub them, feel for irregularities.
wushaw is offline
post #7 of 10 Old 07-11-2010, 05:53 PM
Unlimitedlou
Unlimitedlou's Avatar
Maybe you threw a wheel weight?
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #8 of 10 Old 07-11-2010, 06:05 PM
wushaw
Rockin jeep
wushaw's Avatar
He used the beads, they are inside the tire.
wushaw is offline
post #9 of 10 Old 07-11-2010, 06:09 PM
bairy
Still could be wheel bearings and ball joints. Your smaller tires are putting less strain on those items and not causing them to fail at their limits.
33x13.5" tires are wide. probably on 15x10" wheels too. That is a lot of leverage against the Ball joints and Wheel bearings.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #10 of 10 Old 07-15-2010, 05:55 PM Thread Starter
rastaangel
Is there any ways to check the wheel bearings and ball joints?
I was just told to jack it up and check for vertical play in the tires to check for ball joint play...
vibes , vibration , dw , death wobble , shake , shaking , tj , wrangler
Bad vibration? Ripcurlsurfin96 YJ Wrangler Technical Forum 8 05-01-2007 09:17 PM
still getting vibration redwolf_747 TJ Wrangler Technical Forum 7 01-11-2005 07:36 AM
getting a vibration redwolf_747 TJ Wrangler Technical Forum 2 01-09-2005 05:02 PM
Vibration Help msajeep YJ Wrangler Technical Forum 5 01-04-2005 10:27 AM
Vibration rrust TJ Wrangler Technical Forum 5 12-22-2004 05:13 PM
