Sentry Key™ engine immobilizer [can a thief bypass this easily?] - JeepForum.com
post #1 of 3 Old 01-02-2009, 09:22 AM Thread Starter
Nerv
Just curious, i have a grey sentry key for my 2004 Jeep TJ and I was curious if this anti theft system was a joke to car thiefs, meaning they can still start vehicle when braking steering column etc. Should I invest in Ravelco???
Nerv is offline
post #2 of 3 Old 01-02-2009, 10:09 AM
Grt_Ape
Ravelco is an awesome system, worth the money **edit** for a non-SKIM TJ.
That said, the factory SKIM works pretty damn well.
Chris
2006 LJ Rubicon
Last edited by Grt_Ape; 01-02-2009 at 10:46 AM. Reason: clarifying previous statement.
Grt_Ape is offline
post #3 of 3 Old 01-02-2009, 10:25 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Don't believe Ravelco's BS. The only way the SKIM can be bypassed is with another key or swapping out the cluster, skim module and ECM and then breaking the column.
There is a report of a code grabbing device that can read your key and then transmit it to the SKIM antenna, but think through the logistics for a moment.
They have to know you have a key, follow you around enough to grab the code from it. Then find your TJ, wait until you are looking, break into it, break the column, and then start it.
That takes so much effort that it's just easier to tow it away with a tow truck in which case nothing much keeps it safe.
The only thing a Ravelco system does on a Senty key equipped TJ is lighten your wallet and hack up your wiring.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
Disable the SKIM (Sentry Key Immobilizer Module) Benny2Times TJ Wrangler Technical Forum 265 01-19-2020 12:00 PM
Ravelco VS. Sentry Key Immobilizer System Nerv TJ Wrangler Technical Forum 20 12-29-2011 06:18 PM
SKIM "Sentry Key Immobilizer Module" install RedRubiconLJ TJ Wrangler Technical Forum 45 12-13-2011 09:25 AM
how to bypass sentry key trick pony TJ Wrangler Technical Forum 51 01-25-2011 03:35 PM
Re: DIY immobilizer vettefever5 TJ Wrangler Technical Forum 3 05-06-2009 06:15 PM
