searched everywhere, still no clear answer - JeepForum.com
post #1 of 18 Old 03-02-2012, 05:49 PM Thread Starter
deadwalkinsammy
i have a 97 with a 2.5l, i have replaced just about everything on the jeep so now this is really starting to get to me. when i start it up cold it starts up just fine and drives fine for a while, but then it idles rough at stoplights after about 20 mins of driving, if i start it hot, it does it all the time. i'll be cruising in 4th and it'll stall out on me while im driving. now here's the list of things ive replaced.
plugs, wire, cap, rotor, distributor, cps, tps, iac motor, timing chain kit, oil pan gasket, valve cover gasket, head gasket, radiator, water pump, thermostat, fuel pump, exhaust manifold, catalytic converter, and muffler and tail pipe.
now here's something you should know, the stud that bolts the exhaust manifold onto the head was stripped when i bought the jeep and a bolt was jerry rigged into the hole. will a silly exhaust leak cause all these problems?
also, would it be ok to tap that hole and try to thread it to get a bolt to hold the mani down, if its leaking exhaust from there, you can tell. but what leads me to believe it is, is when i take of in 1st and start to get higher on rpms i hear a puttering sound.
hopefully someone can help me with this, im at my witts end.
deadwalkinsammy is offline
post #2 of 18 Old 03-02-2012, 05:56 PM
clintrivera
clintrivera's Avatar
After the jeep gets warm it goes into closed loop (under cruise and idle) which will take into account the 02 sensor. An exhaust leak will cause rough running since the 02 sensor isn't reading all the gasses. Also how long has it been since you replaced it? It also may be an intake manifold leak since you have a stripped bolt.
clintrivera is offline
post #3 of 18 Old 03-02-2012, 06:09 PM Thread Starter
deadwalkinsammy
hey clint, thanks for the reply, good to see a fellow rivera on here lol
i replaced the o2 sensors today and yesterday. my dad keeps telling me not to worry about the exhaust leak, but that makes total sense to me about the exhaust leak. but the intake is bolted in all the way, the only bolt missing is the very front one, it only bolts into the exhaust manifold.
post #4 of 18 Old 03-02-2012, 08:53 PM
clintrivera
It would take a pretty big exhaust leak to make it run REALLY bad. Have you tested your coolant temperature sensor and MAP sensor yet? Those are really the only two other sensors left to check.
You migh also try pulling the plugs and seeing if they all look the same - as in they are buring the same. The color of the plugs will tell you what the engine is doing. I'm assuming you don't have a CEL.
post #5 of 18 Old 03-02-2012, 10:08 PM
chainbrain2002
when it starts doing it you need to leave it running and put a live data diagnostic scanner onto it and see what everything is doing with it running. it might lead you in the right direction.
chainbrain2002 is offline
post #6 of 18 Old 03-02-2012, 10:17 PM
MFERNICO
My Jeep started and idled rough upon hot start awhile ago. Apparently there was a recall to wrap the #3 injector to help it.
The littlest things.
MFERNICO is offline
post #7 of 18 Old 03-03-2012, 10:51 PM Thread Starter
deadwalkinsammy
well... my coolant sensor is still in decent shape, and my map sensor seemed to be alright, i checked that yesterday, i feel like the exhaust leak it has is a pretty serious one, one because its coming before both o2 sensors and two because its at one of the main hold down spots for the manifold. im going to drill out a hole a little to clean it up, bevel the edge of the hole and then burn a stud into the head, grind the weld flat and hope it holds, seems like a reasonable solution.
post #8 of 18 Old 03-03-2012, 10:52 PM Thread Starter
deadwalkinsammy
im curious as to what you mean by wrapping the #3 injector...
post #9 of 18 Old 03-04-2012, 01:17 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
There is a TSB on this. It involves heat soak on the #3 injector. Google Jeep TSB 18-031-03
Rubi4MyMrs is offline
post #10 of 18 Old 03-06-2012, 06:14 PM Thread Starter
deadwalkinsammy
Even though that's doe 00-04 tjs I'm going to try that, might be a flaw in more model years, gives me hope. Also we're going to peel back the intake and exhaust manifolds and power steering pump and rethread that manifold bolt hole so I can bolt that pig down.
post #11 of 18 Old 03-06-2012, 11:35 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
I was just answering your question on the #3 injector. Kind of doubt it is your problem. I see you have a 2.5L & the TSB was for the 4.0L. Besides it is winter although I see you are in FL. Still wonder if the engine is storing that much heat. If you wrap the injector you might want to do all 4.(?)
post #12 of 18 Old 03-09-2012, 04:33 PM Thread Starter
deadwalkinsammy
Yeah man, I hear ya. I might just try that cause I fixed the exhaust leak and it still seems to be doing it.
post #13 of 18 Old 03-09-2012, 04:44 PM
Dice48
Dice48's Avatar
I would probably take that one to a shop so they can see whats going on. Check engine light?
KCCO
Dice48 is offline
post #14 of 18 Old 03-09-2012, 05:16 PM
BioTex
BioTex's Avatar
1979 CJ7
Sounds ignition related to me. Like a module or reluctor gets hot and starts to open. Not sure so much about a 97, but very common on CJ's and YJ's.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #15 of 18 Old 03-09-2012, 06:39 PM
impboy65
I didn't see coil on your list. Running fine cold and crappy as it warms up sounds like a coil to me
01 TJ stock for now! OlllllllO
impboy65 is offline
cant find a clear cut answer basssolow5 TJ Wrangler Technical Forum 5 01-18-2011 10:00 PM
question re: RC 3.25 kit (i've searched but didn't find this answer) GomerPyle585 TJ Wrangler Technical Forum 4 04-22-2010 12:23 PM
Searched, couldn't find a straight answer on diff. oil.. help! Black06X TJ Wrangler Technical Forum 5 01-23-2007 11:23 AM
To Build or replace D30? searched & still without an answer jeepin494 TJ Wrangler Technical Forum 37 02-20-2005 07:37 PM
Searched but no real answer (Thermostat question). The_Wall YJ Wrangler Technical Forum 4 05-27-2004 11:45 PM
