Scars on spider gears - JeepForum.com
post #1 of 4 Old 05-04-2017, 10:38 PM Thread Starter
renguomin
Just got a set of 4.10 dana30&35 axles from a 4 cylinder TJ. When I opened the diff cover, I found there were some scars on the spider gear (see pics). In total of 8 tooth were damaged like that. How bad are they, are they still drivable? Do I need to set/adjust backlash when replacing them? Can I use my old 3.07 spider gears (are spider gears the same regardless of ratio)? Thanks for any input!
renguomin is offline
post #2 of 4 Old 05-04-2017, 10:53 PM Thread Starter
renguomin
post #3 of 4 Old 05-05-2017, 10:43 AM
freeskier93
Originally Posted by renguomin View Post
Your pics don't look as bad as that.
Yours look pitted but I wouldn't worry about it, run it.
freeskier93 is offline
post #4 of 4 Old 05-05-2017, 02:10 PM
88hatchy
The hardened surface on the outside of the gears has been compromised and they wont last much longer. I would replace them before putting the axles in your Jeep.
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
