Savvy Under Armor - Page 195 - JeepForum.com
 44Likes
post #2911 of 2934 Old 04-20-2018, 10:39 AM
Notsmartenuf
Notsmartenuf's Avatar
Originally Posted by CGrugger View Post
So after getting the crossmember put in, adjusting pinion angle, remeasuring drive shaft, etc, finally sitting in the Jeep with all but the plate installed and the motor skid installed.
My hand is hitting the dash on the top three gears. I have the Currie 1" MML installed and Zone 1.25" bl installed.
It is definitely drive able like this, but very annoying... Should I have expected to have to bend my shifter? Will the bushings in the crossmember settle?
Sent from my Pixel 2 XL using Tapatalk
Ended up pulling and bending mine on my '98 when I got tired enough of hitting toggle switches in 1st and 3rd. My lights and/or locker unexpectedly coming on got to be pretty annoying after a couple weeks. Also clearanced the plastic bezel for the shift boot for smoother shifting for 1st and 2nd
He that is good for making excuses is seldom good for anything else.
Those who would give up essential liberty for a little temporary safety deserve neither liberty nor safety
-Benjamin Franklin
Notsmartenuf is offline
post #2912 of 2934 Old 04-20-2018, 10:59 AM
CGrugger
CGrugger's Avatar
I drove the Jeep to work this morning. I didn't have an issue with hitting the dash too much, but it was on my mind. Might take a look at bending it this weekend if I have time.
It feels so weird shifting now though. The position is so different after driving around with the MML and BL for so long.
2005 TJ X: MC 3.5" lift, 33"x12.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
post #2913 of 2934 Old 04-22-2018, 07:34 PM
CGrugger
CGrugger's Avatar
Finally finished the install. I finally got some time to work on it today.
I couldn't get the engine skid to line up with the engine drain, but I am able to take off the skid with little effort.
Despite the snags I hit during the install, it was pretty straight forward with no instructions...
Now to put some miles on my new gears and try Hold Mountain again...
Altonymous likes this.
CGrugger is offline
post #2914 of 2934 Old 05-06-2018, 09:17 PM
CGrugger
CGrugger's Avatar
So I had to throw the top on the jeep to go camping, and holy crap, the transmission passed so much heat through the body my right leg was uncomfortably hot... I take it the UA pushes the tranny up so much it passes heat through the body, but what can I do to make it bearable. I am willing to do whatever. Even with the doors off and in 50* weather my leg was burning.
Ideas?
CGrugger is offline
post #2915 of 2934 Old 05-06-2018, 09:32 PM
sdjp
sdjp's Avatar
I commonly drive hundreds of miles at a time in my rig and know your pain. I’ve laid down a double layer of heat shield underneath my center console to help things out but it still gets darn hot. I don’t have any carpet in favor of a spray in bed liner but I think carpet would help too. I ended up putting down some carpet floor mats I still had and that helps a bit too.
sdjp is offline
post #2916 of 2934 Old 05-06-2018, 09:52 PM
CGrugger
CGrugger's Avatar
Originally Posted by sdjp View Post
I commonly drive hundreds of miles at a time in my rig and know your pain. Iíve laid down a double layer of heat shield underneath my center console to help things out but it still gets darn hot. I donít have any carpet in favor of a spray in bed liner but I think carpet would help too. I ended up putting down some carpet floor mats I still had and that helps a bit too.
Thanks, thinking of laying some heat shield between the carpet and body and the body and the tranny. Just trying to get the group opinion
CGrugger is offline
post #2917 of 2934 Old 05-06-2018, 10:41 PM
jjvw
jjvw's Avatar
Are your cats still in good shape?
My install is a bit different in that it coincided with the mid arms which required far more exhaust work. My new main cat is sitting forward of the skid. I haven't noticed any significant increase in cabin heat.
2003 Rubicon
2003 Rubicon
jjvw is offline
post #2918 of 2934 Old 05-07-2018, 10:56 AM
pcoplin
pcoplin's Avatar
Try a completely flat belly, a 6/0 and TH400, and 3 inch exhaust. Mine gets HOT. Like burn your hand hot. I put some foil insulation under the carpet back when I ran carpet. Helped a ton. Just a wheeler now, so I don't worry about it anymore.
FullStack MotorSports
pcoplin is offline
post #2919 of 2934 Old 05-07-2018, 11:49 AM
Trevlaw
Trevlaw's Avatar
2003 Rubicon
With it being forward of the skid, is it pretty much right next to the starter now? I was thinking about trying that, but wasn't sure if the extra heat would damage the starter
I want a J-Series
TJ Build:
Trevlaw is offline
post #2920 of 2934 Old 05-07-2018, 12:08 PM
jjvw
jjvw's Avatar
The cat is now next to transmission just in front of the cross member, nowhere near the starter. Nearly a year of daily driving and it hasn't been a problem that I'm aware of.
2003 Rubicon
2003 Rubicon
jjvw is offline
post #2921 of 2934 Old 05-07-2018, 02:34 PM
JEK3
JEK3's Avatar
Any issues with an exposed cat? I'm eventually going to move mine forward a bit with the crossmember I want to put in.
JEK3 is offline
post #2922 of 2934 Old 05-07-2018, 02:36 PM
jjvw
jjvw's Avatar
None that I'm aware of.
2003 Rubicon
2003 Rubicon
jjvw is offline
post #2923 of 2934 Old 05-11-2018, 12:22 AM
CGrugger
CGrugger's Avatar
I am guessing this isn't helping my heat issue either.
I should have that and the heat sheild delivered by Monday. See if u can get it cool enough to make the girlfriend happy.
CGrugger is offline
post #2924 of 2934 Old 05-11-2018, 12:26 AM
Notsmartenuf
WTF did that used to be? Cat?
-Benjamin Franklin
post #2925 of 2934 Old 05-11-2018, 01:11 AM
CGrugger
CGrugger's Avatar
The lower shift boot. With it torn, it doesn't keep all the heat out from the tunnel.
CGrugger is offline
aluminum , belly up , crossmember , high clearance , savvy , savvy under armor , t-case , t-case skid plate , transfer case , transfer case skid , under armor
For the Savvy amongst us mrblaine TJ Wrangler Technical Forum 2789 11-04-2018 12:24 PM
Savvy Corner Armor Install Write-up SuperWade2 TJ Wrangler Technical Forum 36 03-03-2015 06:06 AM
Savvy vs. Rokmen Aluminum Corner Armor eblack TJ Wrangler Technical Forum 47 04-24-2012 01:08 PM
Savvy aluminum armor, what tube flares? pjku79 TJ Wrangler Technical Forum 11 07-12-2010 08:05 AM
Savvy at KOH!! DevilDogDoc Wrangler General Discussion 11 02-13-2010 02:40 PM
