Savvy Under Armor - Page 103 - JeepForum.com
 52Likes
post #1531 of 2938 Old 10-03-2011, 08:51 PM
robert_hollis
robert_hollis's Avatar
Originally Posted by boilerup1998 View Post
Has anyone installed the Under Armor with a 1" BL vs. the 1.25" that comes with the kit?
I'm pretty sure it could be done with the 6 speed trans, but I can't say anything about the auto.
I say this, because due to trans mount issues (early adopter before they had a manual transmount), I modified my stock trans mount to work, and it holds my trans about 2" higher up than the UA manual trans mount does. No tub clearance problems for me.
Having said that, unless you already have a 1" BL mounted, and are dead set on keeping it, I see no reason to not get the 1.25" BL.
Also, I wanna say that extra 1/4" helps on gas tank tuck, but I may totally be imagining that...
You read it. You can't unread it!
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline
post #1532 of 2938 Old 10-04-2011, 01:12 PM
GMBNT42
Maybe this is a stupid question or has been already answered, but on an LJ, since Im doing this skid in 2 parts,(body lift and mml and novak cable, then skid), if I decide to add the SYE and new tom woods driveshaft, would I still need adjustable upper control arms in the rear for a no lift LJ? Or does the SYE and new driveshaft eliminate that need?
GMBNT42 is offline
post #1533 of 2938 Old 10-04-2011, 01:17 PM
geiman
Probably depends on how off your pinion angle would be. If you take some measurements now and fudge the numbers to what they should be after the UA install, you should be able to use Pythagoreans theorem (A^2+B^2=C^2) to find out what the angle would be.
EDIT:
Guess I should clarify; that will give you the length of your driveshaft, but you'll need to do a little trig to get the angle. Common sense for me, but just hit me that it might not be for others. If you get the numbers, we should be able to find the angle for you.
geiman is offline
post #1534 of 2938 Old 10-07-2011, 01:58 PM
cjtheodo
zinc
Is the zinc coating a clear coat or does it have some color? Is it still being offered if requested?
cjtheodo is offline
post #1535 of 2938 Old 10-11-2011, 10:29 AM
geiman
Curious as well...
geiman is offline
post #1536 of 2938 Old 10-11-2011, 11:02 AM
NotURMailman
NotURMailman's Avatar
I tried really hard to test mine this weekend. But, I couldn't really make it hit anything. That added clearance is doing the trick!
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #1537 of 2938 Old 10-12-2011, 10:51 AM
TJRHD
TJRHD's Avatar
do you guys make radiator or any other skids?
NOT A HATER
TJRHD is offline
post #1538 of 2938 Old 10-12-2011, 11:08 AM
PurpleTJ
PurpleTJ's Avatar
http://savvyoffroad.com/
Purple Jeep Club member #8
PurpleTJ is offline
post #1539 of 2938 Old 10-12-2011, 09:42 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Originally Posted by geiman View Post
Curious as well...
No it is not being offered anymore. Too much time and California is making it difficult to even get it done any longer.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #1540 of 2938 Old 10-15-2011, 03:56 PM
TJRHD
TJRHD's Avatar
how long before late model tj's are in stock
NOT A HATER
TJRHD is offline
post #1541 of 2938 Old 10-15-2011, 04:34 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
I saw all of the parts on Wednesday. Should be next week.
Like us on Facebook
Savvy is offline
post #1542 of 2938 Old 10-15-2011, 04:42 PM
TJRHD
TJRHD's Avatar
Thanks also does the standard sye that you guys sell work with the UA? Do you need the mega short?
NOT A HATER
TJRHD is offline
post #1543 of 2938 Old 10-16-2011, 06:15 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
SS Sye is best for the TJ. LJ not needed.
Thanks,
G
Like us on Facebook
Savvy is offline
post #1544 of 2938 Old 10-16-2011, 07:26 PM
krughzn
krughzn's Avatar
Took it out this weekend to the desert and had a blast. Yes I did break it in nicely. It now has some new scratches. I love it.
krughzn is offline
post #1545 of 2938 Old 10-17-2011, 08:54 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You should try airing down next time, it's a whole lot more fun.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
aluminum , belly up , crossmember , high clearance , savvy , savvy under armor , t-case , t-case skid plate , transfer case , transfer case skid , under armor
For the Savvy amongst us mrblaine TJ Wrangler Technical Forum 2791 03-24-2020 08:23 AM
Savvy Corner Armor Install Write-up SuperWade2 TJ Wrangler Technical Forum 36 03-03-2015 05:06 AM
Savvy vs. Rokmen Aluminum Corner Armor eblack TJ Wrangler Technical Forum 47 04-24-2012 12:08 PM
Savvy aluminum armor, what tube flares? pjku79 TJ Wrangler Technical Forum 11 07-12-2010 07:05 AM
Savvy at KOH!! DevilDogDoc Wrangler General Discussion 11 02-13-2010 01:40 PM
