JeepForum.com (https://www.jeepforum.com/forum/)
-   TJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f9/)
-   -   Savvy Under Armor (https://www.jeepforum.com/forum/f9/savvy-under-armor-1046497/)
zachbh 06-08-2010 10:30 AM
Originally Posted by rmb2485 (Post 9591737)
I sure hope it comes out to $700, and not $1000.
Rokmen lists their belly and transmission / oil skid as a package for $659, and they're probably your closest competition for this thing. For $849 they'll throw in a gas tank skid too (hint, hint :wave:).
I'm with the hint hint guy here. For $700, I feel like this is competitively priced, especially with a unique design. Although its a little disappointing customers can't use their pre-installed MML.
lumpster 06-08-2010 10:34 AM
Originally Posted by mrblaine (Post 9592397)
If you add up a 1.25" premium body lift, a new transmission mount with relocated exhaust hanger, and a motor mount lift, Gerald is trying to give the skids away for a couple of hundred bucks. :rofl:
i know, it seems to cheap, but then again im not "Savvy":(
NotURMailman 06-08-2010 10:44 AM
Originally Posted by mrblaine (Post 9592481)
The question then becomes how long it would be before you had all that done. The requirement that's been sorta glossed over in this thread is I don't want these to be purchased and then tossed in the garage to be installed at a later date. Early adopters MUST be ready to go now with the installation, otherwise they do me no good.
I can guarantee I would start on it the night it arrived or the next night at the latest. I would gladly forgo a wheeling trip to do this.
Question: all of this talk of cable shifters doesn't indicate that that is a necessity does it?
Deacon 06-08-2010 10:44 AM
Heh, I'm in kind of an interesting position considering I have a 231 with all adjustable arms, but no SYE at the moment and no plans to put one in since I'll be moving to a 241 shortly. But I'll have no need for locker pump mounts since I'm not a Rubi and am running E-Lockers front and rear. It'll be interesting to see how this works out. After the last K2 run my belly skid is pretty beat up...
This is ridiculous. Why would this be disappointing to you in the first place? You can always sell you existing MML if this is some sort of nickle-and-dime thing. And the new stuff is likely to be far superior to whatever you're selling. Besides, it's integral to the design. Something has to hold up your engine skid... You'd prefer that the skid must be TIG welded to your frame or some such nonsense? Come on...
Honestly after moving to a raised motor mount from Brown Dog, I'm looking forward to going back to the stock mounts. The Brown Dog is far, far beefier than the stock stuff, but the relatively small amount of rubber in its bushing means vibes are much greater than the stock mounts.
mrblaine 06-08-2010 10:45 AM
If you're disappointed over a MML, perhaps you aren't the ideal candidate for early adoption.
Early adopters are a unique and select group of individuals that willingly and enthusiastically embrace a new product and are willing to suffer a bit for that privilege by helping with instructions and fitment issues.
If you're already disappointed, you're not my guy.
Savvy 06-08-2010 10:46 AM
Our front cross member does the MML for you. It is integrated into the motor mount lift. What would have us do? Change the whole design to accomodate a existing MML that we have no control of? You could use your existing MML but your motor is now going to be 2" up. We are talking about 6 bolts to remove and replace the existing MML. You're going to be able to sell it anyways!
I'm all ears!
mrblaine 06-08-2010 10:48 AM
The cable shifter is a great solution, but it is NOT a required solution. T-case shifting is one of the issues we still need to address with all this early adoption installs and see what the best solution will be.
That will be the sort of feedback we need.
NotURMailman 06-08-2010 10:53 AM
Roger that! :thumbsup:
Durnit... if this happens I would have to get a Savvy gas tank skid to raise everything up to fully utilize the BL :rofl:
Anyone want to buy a rediculously heavy Skid Row engine skid, gas tank skid, and a trailer hitch (kind of now one piece with the GTS :laugh:)...
zachbh 06-08-2010 11:09 AM
I'm willing, enthusiastic, and able, but early adopters are all your choice. I suppose my animosity towards messing with the MML stems from the hassle I had with it last time, hack sawing a bolt off at an awkward angle for what felt like an eternity. :laugh: It's disappointing in the sense that now all that work was for nothing, if I do end up with this setup one day. I guess I haven't stared at the teaser pic long enough, but I'll go back and check it out. I suppose I spoke too soon. More pics would help :thumbsup:
Originally Posted by Savvy (Post 9592573)
Our front cross member does the MML for you. It is integrated into the motor mount lift. What would have us do? Change the whole design to accomodate the MML? You could use your existing MML but your motor is now going to be 2" up
I'm all ears!
I didn't mean to suggest a change is needed, I just didn't grasp how the front was put together. Thanks for describing it further, I understand more clearly now! I didn't study the front cross member portion of the first picture as much as the belly pan portion.
mrblaine 06-08-2010 11:14 AM
Next time will be a cake walk because you flipped the new bolt around, right?
Anyway, for future reference and anyone that needs to cut that bolt, a 4" angle grinder with a cut off disc zips it out of there in roughly 15 seconds.
You'll get more Savvy as time goes by. :D
zachbh 06-08-2010 11:21 AM
Right. I wasn't about to make the same mistake the Jeep did. Should have used an angle grinder, but I decided I needed the exercise :laugh:
Oh, I'm sure I will :D
ActionJackson 06-08-2010 11:22 AM
I can't stop looking at this, every time I'm on a computer I look at it. :drool:
06WranglerX 06-08-2010 11:22 AM
Originally Posted by mrblaine https://www.jeepforum.com/forum/image...s/viewpost.gif
Just throwing it out, if selected as a candidate, I can begin working on it once it hits the state of NJ, and if you wanted Blaine I could have a webcam session going while in the garage so you can yell at me cross country if I do not do something right. Also have no problems ditching current Bl in favor of whats supplied.
jg2001 06-08-2010 12:45 PM
email sent, Thanks...
SuperWade2 06-08-2010 12:55 PM
As these 231 cable shift conversion kits are not released yet, info might still be fuzzy, but I wonder if they will retain the stock handle like the 241 cable kit (I expect so)? I also wonder if it will support the 2Lo position (although I've only used a couple times, so wouldn't make much difference anyhow).
Anyone have a stock 231 handle laying around, mine didn't "make it" through the transition to the other Novak style shifter? :rofl::mad:
The time now is 06:27 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
