S&D intake system - JeepForum.com
post #1 of 5 Old 07-25-2010, 03:35 PM Thread Starter
2old2jeep
S&D intake system
Has any one used the S&B intake system with the 4.0? I am thinking of installing it and some type of chip for better gas milage and more power in the 2200 to 3500 rpm range. My 04 unlimited shifts from OD a lot on gentle hills. I would expect it on long steep grades but not easy hills.
2old2jeep is offline
post #2 of 5 Old 07-25-2010, 04:00 PM
DaleII
DaleII's Avatar
You have the 42RLE. There isn't a whole lot you can do. It has a really steep OD gear which makes it hard to drive on hills. You're better off just turning OD off for hills, or gearing a little lower.
As far as getting for power out of the 4.0, you really can't with anyhting bolt on. The stock intake provides more then enough air for the engine, so you can't gain anyhting from a different intake. Maybe only if you did something like the cowl intake to get cooler air, but that's it. Chips won't do a whole heck of a lot. You might get a little but not enough to offset the cost.
The best bang for your buck is gearing.
2005 Silver LJ
DaleII is offline
post #3 of 5 Old 07-25-2010, 04:42 PM Thread Starter
2old2jeep
Thanks for the info. I guess I'll just spend the money on a 505 turbocharger!!!
post #4 of 5 Old 07-25-2010, 04:51 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
the 42RLE is always out of the powerband. thats the problem. nothing you do will address it, besides regearing or tranny swap.
read this: https://www.jeepforum.com/forum/f9/33...ml#post9838564
as for Cold air intakes...see link in sig.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 5 Old 07-25-2010, 06:00 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
It would help to know the profile of your 04?
GOLENJEEPTJ is offline
intake , power , rpm
Air intake system for my 4.0 jvandy98 TJ Wrangler Technical Forum 9 04-14-2010 02:27 AM
Air Intake system LuCk3e87 TJ Wrangler Technical Forum 23 09-04-2008 12:36 PM
air intake system stu'sjeep TJ Wrangler Technical Forum 10 05-03-2008 02:18 PM
Which intake system is the best?? ThatGuysXJ TJ Wrangler Technical Forum 2 12-10-2005 06:08 PM
Which air intake system is the best to buy JeepMarine TJ Wrangler Technical Forum 17 07-11-2004 06:49 PM
