Rubicon Locker Air Pump question (how to wire your Rubicon air pump) - Page 12 - JeepForum.com
 2Likes
post #166 of 173 Old 03-23-2015, 08:40 PM
TJJeepster
TJJeepster's Avatar
I know this is an old thread but its related and i would rather ask here then start a new one. i have recently wired in my rubi pumps and have everything working/locking fine. But I wired in some indicator lights without much luck. I did a rubicon axle swap in to a 97 TJ so i don't have the indicator lights in the dash. I just picked some small round LEDS and mounted them in the dash. I ran one hot wire from the same power fed as the pumps. ( when i hit the switch to the lockers the LED should have power going into one of the wires going into the sensor (can these wires be mixed up ?) . The other wire off the sensor i have ran to the hot side of the Light and then grounded the lights out on a screw on the fire wall. I'm not sure what I'm doing wrong? I don't even have power to the lights even tho i know the axles are locked. I would see maybe one sensor not working, but both makes me think its a wiring error.....
TJJeepster is offline
post #167 of 173 Old 03-24-2015, 06:09 AM
jeepinhokie
jeepinhokie's Avatar
sounds like your issue is with the power getting to the sensor in the first place. have you uased a multi-meter to verify 12v at the sensor when you switch the pumps on?
the sensor is a simple mechanically operated switch, does not matter which side of the sensor you are using as "in" or "out".
in the OEM configuration the sensor does not handle 12v though. the sensor complets a ground circuit. not sure what happens if/when you put 12v on it.
personally, I would use the 12v supply from the switch to the pump as the source for the LED, and ground the LED through the diff sensor switch back to the frame somewhere. something like this...
HOKIES UNITED!
jeepinhokie is offline
post #168 of 173 Old 03-26-2015, 06:49 PM
TJJeepster
TJJeepster's Avatar
Thank you , I have them wired correctly now . I didn't realize the sensor creates the Ground . Ran the hot line off my fog lights and I was good.
Thanks
post #169 of 173 Old 04-25-2017, 12:12 PM
metalmen
how do you wire the diff lock lights on dash non rubicon , what plug on cluster
jseal57 likes this.
metalmen is offline
post #170 of 173 Old 04-25-2017, 12:55 PM
jeepinhokie
Did you go back and look though the posts. There are a couple wiring diagrams which show what your looking for.
Cluster needs to be a later model TJ to work. Since the early TJs didn't have locker lights in the clusters
HOKIES UNITED!
post #171 of 173 Old 04-25-2017, 04:00 PM
metalmen
I don't know I'm lost, theres 2 wires to each light both ground? one with a diod? I know is simple but too many post and confused
metalmen is offline
post #172 of 173 Old 04-25-2017, 05:33 PM
jeepinhokie
Yeah there is a bunch of info out there.
6&7 on the white connector for the rear.
10&16 on the black for the front.
HOKIES UNITED!
post #173 of 173 Old 04-25-2017, 07:59 PM
metalmen
ok thanks I think I got it, ground them off the diff plug on the rear
metalmen is offline
Rubicon air locker pump install tjrunner TJ Wrangler Technical Forum 9 06-12-2014 01:44 PM
Rubicon locker air pump. CoolContractor TJ Wrangler Technical Forum 2 03-04-2009 09:33 PM
Rubicon locker pump wiring surfcat2000 TJ Wrangler Technical Forum 0 04-29-2008 08:41 AM
Rubicon locker pump relocation. Si1ver03Rubicon TJ Wrangler Technical Forum 2 04-08-2008 04:31 AM
rubicon locker air pump wiring scottodog TJ Wrangler Technical Forum 1 12-07-2004 10:26 AM
