Rough changing into 2nd when it is cold. - JeepForum.com
post #1 of 20 Old 01-15-2009, 06:48 PM Thread Starter
Silver04TJ
Silver04TJ's Avatar
When it is cold out my Jeep has a hard time changing into 2nd. It did not start happening until I put on my lift with my xfer case drop ( I know I know.. get rid of the xfer case drop and put in a SYE/CV). Anyone else have this problem? I think I'm going to try cutting the plastic spacers in half and putting them back on. ....see if that will help. It only happens when it is really cold and every once in a while when it is warm.
Silver 2004 Jeep Wrangler Sport
3.5" Rubicon Express Standard lift,
Cepek DC-1 15x10 Black wheels,
33x12.5x15 Cepek Fun Country II!!
M8000 Warn Winch with in cab controls
And the accessory every Jeep should have...DIRT/MUD!
Silver04TJ is offline
post #2 of 20 Old 01-15-2009, 06:49 PM
klincker
mine does it when its cold. no lift
2013 JKU Sport S 6speed
99 TJ sahara 5spd--sold
94 YJ 4cyl 5spd--sold
klincker is offline
post #3 of 20 Old 01-15-2009, 07:26 PM
RiponredTJ
Happy Member No. 1
RiponredTJ's Avatar
Do you have the old accordion style rubber boot. They get really hard when it's really cold and make shifting into 2nd a big problem. I had to pop my boot out of the console this morning so it would shift properly. As soon as I did that, it shifted great again.
This City is what it is because our citizens are what they are.
RiponredTJ is offline
post #4 of 20 Old 01-15-2009, 07:37 PM
CaleTJ99
CaleTJ99's Avatar
Mine dose it too, even before i put my lift on when ever its cold it is hard to get into second. Yes i am running the t-case drop but a buddy of mine also has trouble going into 2nd when its cold out and he has an SYE and CV DS. I think they all do it, once the jeep is warmed up it dosent do it anymore.
CaleTJ99 is offline
post #5 of 20 Old 01-15-2009, 07:43 PM
ninemili22TJ
ninemili22TJ's Avatar
I also have the same problem. If i let it warm up long enough it usually works better
ninemili22TJ is offline
post #6 of 20 Old 01-15-2009, 07:54 PM
gittman140
it all has to do with the rubber boot in the cold, i am wanting to switch it to leather or leather but not sure how hard it is
gittman140 is offline
post #7 of 20 Old 01-15-2009, 08:03 PM
jackbauersmom
jackbauersmom's Avatar
change your transmission fluid to synthetic
i'm so tired of being tired, sure as night will follow day, most things i worry about, never happen anyway
-petty
jackbauersmom is offline
post #8 of 20 Old 01-15-2009, 09:11 PM
charlied02tj
Mine did this also.. but only after I changed the tranny fluid.. come to find out it was suppose to have Synchromesh type fluid... It has additives that help with synchronization so you don't grind gears or have a hrd time shifting in cold weather!
try you'll like it!
charlied02tj is offline
post #9 of 20 Old 01-15-2009, 09:21 PM
tjwrangler99
tjwrangler99's Avatar
TA DA!
http://www.dailydriventj.com/newshifter.shtml
im prolly going to do this in a week or so...
also changing out the tranny fluid with Redline MT-90 (i have an AX-15)
1999 TJ
BFG AT 31's | BDS 2" Lift | JKS Quick Disco's | Zone Rear Sway Links | TeraFlex 1/2" Drop+Washer | Warn M8000 | Viking 80' 3/8 Synthetic w/ Safety Thimble | Viking 350 Fairlead | MetalCloak AL Bumper | 99 Durango Steering Box | Uniden 520 CB w/ 3' FireStik | ebay header | Magnaflow Mid-Cat | Banks Cat-back | XJ Steering Linkage | Hella Black Magic (x4)
2011 Patriot FD1
tjwrangler99 is offline
post #10 of 20 Old 01-15-2009, 10:31 PM
jeep06
jeep06's Avatar
2015 KL Cherokee
He has a NV3550... it better have synthetic in it already.
2015 Cherokee Limited (granite) 4x4, 2.4L, 8.4AN, luxury group, wireless charge pad.
jeep06 is offline
post #11 of 20 Old 01-15-2009, 10:35 PM
jeep06
jeep06's Avatar
2015 KL Cherokee
Leather isn't much better than rubber... my shift boot was like a rock tonight when I got ready to leave work at -12*F..... bout the only thing you can do is shift nice and slow till things get warmed up... or maybe move to a warmer state like I am ready to do...
jeep06 is offline
post #12 of 20 Old 01-15-2009, 10:48 PM
EZEC
2017 JK Wrangler
weird i never thought it could be the boot.. i'll check it out tommorrow since it's -4 right now it should be nice and hard to shift at all
EZEC is offline
post #13 of 20 Old 01-15-2009, 11:16 PM
Mini-Me26
Ditto on that. I thought the oil had thickened up in the cold to the viscosity of honey, but it was just that dang boot. I recommend just leaving it out of the bezel for the winter... and changing the oil.
Mini-Me26 is offline
post #14 of 20 Old 01-15-2009, 11:21 PM
Onion22
ya i mine does the same thing... i thought i had it in second and it popped out in the middle of the intersection, kinda embarrasing, then when i did get it second i let the clutch out a little quick and i went side ways on the snow and went on my happy way... kinda bad A**
-Sry bout my speling, i went too public school... an not dat offten.
- Member of "Kansas Mountain Rescue Patrol" if i see a mountain I'll rescue it.
White Rubi LJ, 6spd, 35" BFG KM2's
Onion22 is offline
post #15 of 20 Old 01-16-2009, 06:13 AM Thread Starter
Silver04TJ
Silver04TJ's Avatar
I don't have the accordion style boot. It actually grinds if I don't ease it in to 2nd when it is cold. I need to change the tranny and xfer case fluid anywayz.. which I'll do when it warms up to anything over 45 degrees.
Rough Idle when cold firefighter1 TJ Wrangler Technical Forum 1 04-22-2013 08:25 PM
4.2 idles rough when cold tet-ness-shot YJ Wrangler Technical Forum 3 08-13-2008 02:12 PM
TJ Rough in the cold Piper1 TJ Wrangler Technical Forum 3 01-17-2007 11:21 AM
Rough cold idle ckcarr TJ Wrangler Technical Forum 1 11-10-2004 03:45 AM
2.5 runs rough when cold slimlynn1 YJ Wrangler Technical Forum 11 04-07-2003 12:23 PM
