Rollbar is off- angle grinder opinions? - JeepForum.com
 3Likes
  • 1 Post By mukluk
  • 2 Post By jeff_in_rc
post #1 of 10 Old 04-09-2018, 09:20 PM Thread Starter
Trespasser
Paint it or keep grinding???
I'm doing an amateur restoration of my 97. The tub interior is good except under the rollbar and the footwells.
So far, I took an angle grinder cup brush and rotary brush to the tub. I thought it looked shiny until I started on the rollbar itself with a grinding disc which dug in too much at spots and still didn't get deep enough in others.
Should I prime as is or take a shot on the tub itself with a grinding disc?
Trespasser is offline
post #2 of 10 Old 04-09-2018, 10:14 PM
mukluk
mukluk's Avatar
Remove all the loose rust, hit it with some rust converter or Rustoleum rusty metal primer, and paint it.
Joe Dillard likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 10 Old 04-10-2018, 08:17 AM
jeff_in_rc
What mukluk said and I will add, get a flap wheel instead of a grinding wheel for the rust, you will have better control. Then clean it well, and paint it with a rust encapsulater paint then the color of choice.
2004 Jeep Wrangler Rubicon
Member of Off-R-Rockers California Chapter Facebook Group
jeff_in_rc is offline
post #4 of 10 Old 04-11-2018, 11:23 AM
1longcj
I like the flap discs better than the flap wheels.
Life is short, Play hard.
1longcj is offline
post #5 of 10 Old 04-11-2018, 11:26 AM
jeff_in_rc
I might have used the wrong word on that! Flap disk sounds more like it.
post #6 of 10 Old 04-11-2018, 07:17 PM
vtx531
Unless you cut it out and replace metal, the rust will come back through. Speaking from experience.
vtx531 is offline
post #7 of 10 Old 04-11-2018, 08:06 PM
tanksoldier
tanksoldier's Avatar
True, in 20 more years it will look more or less like it does now.
Iíd try a wire brush wheel to get the lose stuff then rustoleum.
Multiple coats, let each one dry well before the next.
I have a 97 TJ as well and Iím afraid to take too much apart for fear of what Iíll find.
"I am a Soldier. I fight where I'm told and I win where I fight." GEN George S. Patton, Jr.
tanksoldier is offline
post #8 of 10 Old 04-11-2018, 10:01 PM Thread Starter
Trespasser
It may yet come back in another decade but cutting is not an option for me. I can do a lot but I can't weld. I'll be grinding and painting, the main question is how much grinding!
This Jeep is my 4th one, but a doppleganger for my very first one so it has sentimenal value and I plan to keep it.
So... Grind at that pitted spot with a flap disc or just seal it as is???
post #9 of 10 Old 04-12-2018, 02:03 PM
Bigbob
Bigbob's Avatar
I'd just wire brush it or sand blast and kill the rust. people say you can't kill the rust and that may be true. But you sure can stop it. Invest in some converter like POR or go to the Mostaliner web site and check for his rust paint. Back in 1988 I had some bad flaky rust, not surface rust, on some 1/4" steel frame work at an industrial site. I electric wire brushed all the loose stuff off and put the Rustoleum rust primer on it in 2-3 coats. Then it was top coated with rustoleum. It's still good today. Never even been repainted. If you grind away till all is shiny your metal is going to be pretty thin.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #10 of 10 Old 04-12-2018, 02:04 PM
Bigbob
Bigbob's Avatar
And use never seize on those bolts.
6 Speed, Hardtop
Bigbob is offline
