Rock Krawler long control arms or Savvy short arms ??? - JeepForum.com
 6Likes
post #1 of 26 Old 02-14-2018, 01:06 PM Thread Starter
alienator
Like in subject just trying to make my mind what brand arms should I get for my TJ and why.
Rock Krawler long control arms or Savvy short arms or maybe Rock Krawler short arms ???
Please advice
alienator is offline
post #2 of 26 Old 02-14-2018, 01:15 PM
arg0413
arg0413's Avatar
Tell us more about your setup, plans, and goals:
Desired lift height?
axles & gearing?
tire size?
Type of wheeling?
Supercharged 4.0 Rubicon build:
arg0413 is offline
post #3 of 26 Old 02-14-2018, 01:30 PM Thread Starter
alienator
Rock Krawler 3.5" springs now but maybe ACOS spacers in future 5" -5.5" max lift
dana 30 and 44 4.56 gears with ARB front and rear
33" tyres now but 35" later this year
mild trails mainly with mud because no rocks in my area
post #4 of 26 Old 02-14-2018, 02:22 PM
biffgnar
biffgnar's Avatar
Personally, I would stick to short arms with real Johnny Joints. There are several brands out there.
BTW, ACOS coil spacers are overpriced junk IMO. Adjustability is nothing like how it is sold and just really not necessary. Most people around here pair a 1.25" BL with 3.5-4" springs to create a little more room (that is useable in many ways) and don't stack spacers on top of lift springs. If you really want to do coil spacers then decide on a height and just buy regular spacers.
arg0413 likes this.
biffgnar is offline
post #5 of 26 Old 02-14-2018, 02:26 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Savvy or Currie short arms with Johnny joints. Having run one bolt-on long arms suspension, there's not a bolt-on long arm kit I'd run. There's only one thing my previous long arm suspension did better than my current short arm suspension does... and that was its long arms got hung up on rocks and trail obstacles far more easily.
arg0413 likes this.
Jerry Bransford is offline
post #6 of 26 Old 02-14-2018, 04:17 PM Thread Starter
alienator
1.Would Savvy SA works with 5"lift in future and can I setup castor and pinion correctly( I got ACOS already only need to be instaled)???
2.Rock Krawler SA lowers apparently only works between 2" - 4" lift
3.so RK long arms or Savvy short arms are better on highway or flexing(I dont worry about rocks because there is none where I live)
post #7 of 26 Old 02-14-2018, 04:18 PM
xtremeasures
I had (what I'm guessing was the 2-3rd gen, I think their website is 5 gen) RKs 5.5 X Factor Long Bent Arm and was not impressed. Most of the powder coat flaked off prematurely. It felt like it had axle rap, which I'm guessing was from the bent arms straightening and poly bushings, and the shocks were the limiting factor on travel.
It did ride good and had good clearance.
xtremeasures is offline
post #8 of 26 Old 02-14-2018, 04:22 PM
biffgnar
biffgnar's Avatar
You are going down a road of too much spring lift and a less than ideal means of getting there. If you want to do that good luck, but I don't think you are going to find many fans here of where you are going.
Joe Dillard likes this.
biffgnar is offline
post #9 of 26 Old 02-14-2018, 04:28 PM Thread Starter
alienator
Well thats why I asking before any purchases and always I can change my plans thats the reason why I'm here...
post #10 of 26 Old 02-14-2018, 04:33 PM
Jerry Bransford
Administrator
I had a 5.5" Rock Krawler lift many years ago and my present 4" Currie plus a 1" body lift is better all the way around. It easily handles 35's which is the biggest the TJ's axles can handle, and it has a lower COG. Most experienced TJ owners will agree a 6" suspension lift is too tall for a TJ.
jjvw likes this.
post #11 of 26 Old 02-14-2018, 04:40 PM Thread Starter
alienator
Ok What you think then about RK 3.5" springs and Savvy ca combo Jerry???
Any good???
post #12 of 26 Old 02-14-2018, 04:54 PM
xtremeasures
Here's the kit I had. Notice the rear bent upper arms and poly joint bushing on one end of the arms.
https://www.extremeterrain.com/rock-...55xf-la01.html
Here is what I think is their 4th gen. Straight rear uppers with heims and RKs joints and triple rate coil springs.
https://www.morris4x4center.com/rock...j55xfla01.html
And now their 5 gen. with all straight arms.
http://www.rockkrawler.com/ProductDe...tCode=TJ55XFLA
post #13 of 26 Old 02-14-2018, 08:15 PM
jjvw
jjvw's Avatar
Any good???
Why not Currie 4" springs? If you want good suspension travel, Currie is the platform to build your shock travels around. That 1/2" lift between brands is going to be gained or lost depending on the actual weight of your Jeep.
2003 Rubicon
jjvw is offline
post #14 of 26 Old 02-14-2018, 08:17 PM
biffgnar
biffgnar's Avatar
Aren't RK spring rates on the higher side? He may get a bit more out of them depending on weight.
biffgnar is offline
post #15 of 26 Old 02-14-2018, 09:30 PM
arg0413
arg0413's Avatar
Any good???
Do you already own the RK 3.5" springs? Like they've mentioned: Currie 4" is the best
Proven recipe:
*3.5 - 4" Springs
*1.25" BL
*properly measured shocks and bumpstops
*Quality adjustable control arms (currie/Savvy or Metalcloak)
*combined with your D44's with 4.56/ARB, you'll have one very capable and durable setup!
arg0413 is offline
