The right lift for my needs ==> Cost/Parts - JeepForum.com
post #1 of 14 Old 05-19-2012, 12:30 AM Thread Starter
EagleTwoThree
The way I use my '97 TJ:
Not a DD.
Must go 65-70 on highway once or twice a week. I don’t want a trailer queen.
No rock climbing.
No mudding.
Off roading to include unimproved roads (gravel, dirt, rutted, old logging trails), wooded areas (with some downed trees), sand.
I do not want any clearance/rubbing issues…at all.
Don’t care about gas mileage.
Don’t want a slug…if I have to regear, then I will.
Current:
All stock with 225/75 R 15”. Meaning “28 inch tires”, essentially.
31” Build. Adding 1.5” of clearance for diff ( ~ $800 ):
Put 31” tires on with no other mods needed. Not sure this is doable…backspacing? Rubbing?
Dick Cepek Radial F-C II Tire 31x10.50R15LT $800
33” Build. Adding 2.5” of clearance for diff (Cost ~ $3500 ):
3.5” Rubicon Express Super Flex $1000
Rubicon Express Extreme-Duty™ Mono-Tube Shocks $300
JKS 1.25” BL. $125
Slip yoke eliminator and double Cardan drive shaft $500 (edit: added to OP)
iON alloy Style 171 (16x8, 4.25 backspacing) Rims $500
Dick Cepek Radial F-C II Tire 33” LT305/70R16 $1200
37” Build. Adding 4.5” of clearance for diff (Cost ~ ZOMG $12,300 ):
6” lift (leave room for larger tires since I have to do all the other crap below anyway for tires over 35”) $2,000
Black magic front rotor/pads brakes $500
Space out the steering stop bolt with washers
Heavy duty drag link and tie rod ???
Dana 44 front/rear 4.88 gear w/Detroit lockers and chromoly shafts $5000 ($2500 ea)
Lower/raise bump stops: JKS Manufacturing Adjustable Bump Stops $400
Performance Accessories 3" Body Lift Kit. $150
iON alloy Style 171 (17x9, 5 backspacing) Rims $600
Dick Cepek Radial F-C II Tire 37” 37x13.50R17LT $1900
Fender mod of some sort ???
Of these, I feel like the 33” build will fit my needs. I’d like to do the 37”, but I don’t think my off road habits make it necessary, and I’m not sure 37” on the highway a couple times a week is smart. I’m thinking about a tummy tuck, but that’s later.
Any input on which build fits my needs is welcome, as well as inputs on the 33” parts list. I don't think I've missed anything, but I'm posting in case I have.
[Reference Thread: https://www.jeepforum.com/forum/f9/tj...embers-722109/ ]
EagleTwoThree is offline
post #2 of 14 Old 05-19-2012, 12:39 AM
Benderff
Benderff's Avatar
Add a small spacer lift and/or body lift to option number 1 and be done. That will handle everything you want to do.
Benderff is offline
post #3 of 14 Old 05-19-2012, 09:22 AM
Richd1963
Richd1963's Avatar
If you go with the RE 3.5 SA super flex lift, You will also want to add the SYE and CV drive-shaft as well as rear adjustable upper control arms to your list.
Rich G. 2005 Wrangler 4.0 6-Speed.
just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only
Richd1963 is offline
post #4 of 14 Old 05-19-2012, 11:41 AM
bobsled84088
33"
2" BDS lift 400.00
1" PA BL 100.00
Brown dog MML 100.00
Orfab Tire carrier 600.00
Regear 1200.00
speedometer gear 45.00
Husqavarna chain saw 400.00
bobsled84088 is offline
post #5 of 14 Old 05-19-2012, 11:49 AM
crateampscal
crateampscal's Avatar
you need to figure out what your jeep has in it, then put it in your profile. once you figure that out, youll have a better understanding what your jeep is cabable of handling. i can tell you right now, if you have 3.07 gears, you wont like 33's
crateampscal is offline
post #6 of 14 Old 05-19-2012, 01:21 PM
dcope17
dcope17's Avatar
Do the 33"... leave out RE stuff... stock CAs... 2.5" springs... add savvy underarmor and a winch to pull over those downed trees especially if they're wet...
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #7 of 14 Old 05-20-2012, 10:16 PM Thread Starter
EagleTwoThree
I'll keep that as an option, thanks! And I looked at your build thread...holy crap! Nice!
post #8 of 14 Old 05-20-2012, 10:17 PM Thread Starter
EagleTwoThree
Yeah, I wasn't sure I needed to do that. It was one of the things I wanted to avoid. But, if I don't do it, I'll have vibes, right?
post #9 of 14 Old 05-20-2012, 10:25 PM Thread Starter
EagleTwoThree
At first, I was like WTF? I said it was all stock, and it is...then I saw that you could get 3.07 or 3.55. I have the 3.55.
post #10 of 14 Old 05-20-2012, 10:27 PM Thread Starter
EagleTwoThree
Originally Posted by bobsled84088 View Post
33"
2" BDS lift 400.00
1" PA BL 100.00
Regear 1200.00
It took me a min to get the chain saw...funny!
post #11 of 14 Old 05-20-2012, 10:31 PM Thread Starter
EagleTwoThree
I guess if I did the smaller lift, 2.5" plus shocks, I wouldn't need the SYE/CV and arms. Would I have clearance issues with the 33"s? I hear you on the wet trees...the bark comes off and it's like trying to get over a cylinder of ice. I could use the winch/underarmor or bobsleds' chain saw idea. I'm thinking of the added weight of the armor, but I have not researched it yet.
post #12 of 14 Old 05-20-2012, 10:39 PM
crateampscal
Originally Posted by EagleTwoThree
I guess if I did the smaller live, 2.5" plus shocks, I wouldn't need the SYE/CV and arms. Would I have clearance issues with the 33"s? I hear you on the wet trees...the bark comes off and it's like trying to get over a cylinder of ice. I could use the winch/underarmor or bobsleds' chain saw idea. I'm thinking of the added weight of the armor, but I have not researched it yet.
You still might need an sye with a 2.5 lift, and definitely will need one if you get a tummy tuck.
post #13 of 14 Old 05-21-2012, 06:06 AM
Jasons4x4
It honestly doesn't sound like you need a lift for the type of use you're describing. I would suggest putting a decent set of tires on it (with what you describe I hesitate to say mud terrains, as you could probably get by with an A/T, but obviously that's your choice) and a winch and call it a day. I just don't understand what you would need the extra clearance for with the use you described.
Jasons4x4 is offline
post #14 of 14 Old 05-21-2012, 09:33 AM
geiman
This. I don't see spending a ton of money on upgrades just to run unimproved roads and the like. You can do those without any problems as you sit right now.
geiman is offline
How much would it cost to add to a lift? Tylerjoje YJ Wrangler Technical Forum 21 03-18-2012 12:44 PM
Cost of parts and labor to regear 97TJ to 4.10 from 3.07 , parts and labor? chaznad TJ Wrangler Technical Forum 6 02-19-2009 04:38 PM
8.8 Brake parts cost jjabell2000 TJ Wrangler Technical Forum 17 12-22-2008 02:39 PM
Lift? the right way...Cost? Hpdrifter TJ Wrangler Technical Forum 4 11-21-2005 04:21 PM
What's the ballpark cost of a 2.5 rebuild? Parts and labor.. zpmada YJ Wrangler Technical Forum 3 04-12-2004 09:09 PM
