Right hand drive limitations - JeepForum.com
 3Likes
  • 1 Post By Wheelin98TJ
  • 1 Post By Jonny Jeep
post #1 of 9 Old 04-08-2021, 08:09 AM Thread Starter
nondem
I'm shopping for a TJ and found a couple that are just right except they are right hand drive. I've had a right hand drive vehicle before so it isn't a problem for my plans in itself. What I'm wondering is: Will I be limiting my options for lift and aftermarket mods by getting a right hand drive model?
Not sure if the steering gear being on the right will limit which lifts will work etc...
nondem is offline
post #2 of 9 Old 04-08-2021, 12:50 PM
Jonny Jeep
Jonny Jeep's Avatar
The steering and track bars are the only areas lift will differ. If you stick with stock steering Crown/RT Offroad do standard and heavy duty steering parts. The track bars run from opposite sides of the axle. For 4 inch lifts track bar relocation brackets are available that go on the frame side. The Front can have the axle side bracket drilled and the trackbar moved over the same way as it's done on LHD TJs. RHD adjustable track bars would be harder to come by.
Jonny Jeep is offline
post #3 of 9 Old 04-11-2021, 10:32 AM
TheBoogieman
The Devil's advocate
TheBoogieman's Avatar
NotURMailman's build thread.
https://www.jeepforum.com/forum/f9/r...thread-757968/
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #4 of 9 Old 04-14-2021, 09:43 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You can drill a new hole in the rear axle bracket too.
There's enough room to center the axle up with a 4" lift.
edit: me stupid, read following posts.
Jonny Jeep likes this.
Wheelin98TJ is offline
post #5 of 9 Old 04-14-2021, 11:43 AM
Jonny Jeep
Jonny Jeep's Avatar
I can see from the brackets on my rear axle that there is enough room to do that on the LHD axle mount, but if you have a look where the RHD track bar mount is near the pumpkin, there isn't enough material to do that.
Wheelin98TJ likes this.
post #6 of 9 Old 04-14-2021, 11:52 AM
Wheelin98TJ
JEEP FREAK
Thanks for correcting me. I forgot that RHD trackbar bracket is entirely different and not just a flipped version of the LHD bracket.
post #7 of 9 Old 04-15-2021, 06:06 PM
Pine_Cat
Pine_Cat's Avatar
A lot of the people who drill/weld trackbar mounts get bad results. An OP who needs to ask the question probably doesn't want to go there.
Plan on a 1.25" BL, and limit suspension lift to 1" or 2"
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
post #8 of 9 Old 04-15-2021, 07:20 PM Thread Starter
nondem
Thanks to everyone for their help with this...I didn't want to limit my options so fortunately before I pulled the trigger on one of the RHD drive Jeeps I found a 2003 TJ Sahara left-hand-drive in EXCELLENT condition as a base for my build. Of course, I'll have tons of questions about that now
Thanks again guys.
-Randy
nondem is offline
post #9 of 9 Old Yesterday, 07:12 AM
Wheelin98TJ
JEEP FREAK
On a LHD, no problem at all drilling a new hole in the rear. It's not a steering axle so the track bar doesn't see much stress.
Front is a different story.
