Replacing half doors with full doors - JeepForum.com
post #1 of 14 Old 02-07-2009, 03:32 PM Thread Starter
N4cer76
Guest
I was going to replace my half doors with full doors. Are there any problems I will encounter when doing this? Obviously the ignition key and the door key wont match but I never lock my doors anyway.
I did a search but found no info.
N4cer76 is offline
post #2 of 14 Old 02-07-2009, 04:58 PM
Apex
Recon death squad
Apex's Avatar
Well then I hope some wiseguy doesnt lock your door for you
Apex is offline
post #3 of 14 Old 02-07-2009, 05:04 PM
661
Swap the lock cylinders. Should not be too difficult.
661 is offline
post #4 of 14 Old 02-07-2009, 05:13 PM
2jhanna
the only thing i have read, is that it may be necessary to adjust the hinge plates a little.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #5 of 14 Old 02-07-2009, 05:18 PM
daveshan
Feeding the money pits
daveshan's Avatar
Take out the lock cylinders and take them and a spare key to a locksmith, cost me $15/ea to have them matched to my ignition key.
Dave Shannon
Durango, CO
Gone but not forgotten
'56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr
daveshan is offline
post #6 of 14 Old 02-07-2009, 08:37 PM
GzrGlide
GzrGlide's Avatar
You're a delinquint!!!!
Mike
<<< ya know ya want to!
98 TJ SE
RE 4.5SF with 3.5 springs & Tera QDFTs
Super 35 & Detroit in back w/4.88s
33x10.5 BFG KM2's
Cobra 75WXST w/4' Wilson Antenna
Warn M8000
(1) Rubber Ducky
GzrGlide is offline
post #7 of 14 Old 02-07-2009, 08:42 PM
offroadutopia
i believe you will have to install the upper door surrounds to put hard doors on a soft tj top.these sell used for about150. check into them theres some kinda issue to do the swap.??????
offroadutopia is offline
post #8 of 14 Old 02-07-2009, 08:46 PM
brian674
brian674's Avatar
X2 on this, I did the same with an used center console once, there is no reason to have a key not work.
Also, yeah I think you'll need to use the door surounds, that is if you want to put the top on!
'There is nothing more deceptive than an obvious fact.' Sherlock Holmes
brian674 is offline
post #9 of 14 Old 09-18-2020, 08:45 AM
Figaro
Can i replace the soft top for my 1998 wrangler sahara with a hard top and full doors
Figaro is offline
post #10 of 14 Old 09-18-2020, 01:09 PM
mukluk
mukluk's Avatar
@Figaro
Yes, just make sure the top and doors you acquire are for a TJ (1997-2006).
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #11 of 14 Old 09-18-2020, 02:18 PM
2jhanna
And be prepare to adjust the door hinges. Make sure not to loosen the screws for the "hinge halves" that are on the tub. Only loosen and adjust the hinge halves that are on the new doors.
By doing it this way, you can go back to the half doors with no adjustments. Also, expect to strip the heads of the screws out, and there isn't any paint under the hinges. So,if you're repainting the doors to match, get them adjusted first, then paint.
jhanna
denton county, tx
2jhanna is offline
post #12 of 14 Old 09-18-2020, 02:54 PM
Maverickxeo
Maverickxeo's Avatar
I do this every Spring/Fall.
I swap the mirrors over (only one set of mirrors), swap the doors over physically, and then I have to adjust the striker plates for better fitment. They are a T50 on the tub and a T30 (?) on the door itself. When I got my half doors, I took the lock cylinders out, and repinned them to my factory hard doors so my factory key works with them (it isn't very hard to do, just time consuming). I also spray lube through each of the door pin 'holes' on the tub and take sandpaper to the door pins on the doors themselves to remove the rust and buildup.
When running my soft top, I run door surrounds as I have upper fabric doors and I want it to be was 'waterproof' as possible. The door surrounds are the same for half and full doors - they are removed when my hard top is installed.
Maverickxeo is offline
post #13 of 14 Old 09-19-2020, 08:30 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
I run half doors when I wheel, and full doors the rest of the time, so I swap back and forth all the time. I adjusted the strikers and the doors so they go back and forth with no fuss. Since I swap frequently, I found it is worth it to me to have mirrors on both. Keeping the hinges greased, it takes about a minute to swap.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #14 of 14 Old 09-19-2020, 07:32 PM
bobjp
I wish I had the same situation as some of you. I bought some full doors, and there is about a 3/4" overlap on the windshield frame on the passenger's door. And that is after loosening the hinges and the bolts on the roll bar. The gap on the lower portion of the door is good.
I previously had another set of full doors (but sold them) that fit just fine.
So I would say, don't expect them to fit. Jeep's must have had a final assembly operation where a couple guys with torx bits and rubber mallets made things fit.
Also, you can buy sets of lock cylinders with keys for not much.
97 TJ sport.
bobjp is offline
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 03:29 PM
Trade Unlimited Half Doors for your Full Doors? Antenna_X JK Wrangler Technical Forum 18 05-19-2009 05:19 AM
Possible to replace soft-top half doors with full doors? laka YJ Wrangler Technical Forum 5 09-11-2006 03:24 PM
Question about Full Doors/Half Doors and Locks booyia TJ Wrangler Technical Forum 9 09-09-2005 01:21 PM
Soft top? full hard doors vs. half doors jgarden TJ Wrangler Technical Forum 8 10-17-2004 02:00 PM
