Replacing ball joints - knurled or smooth - JeepForum.com
 3Likes
  • 2 Post By 40vern
  • 1 Post By Tylervalo
post #1 of 11 Old 01-17-2020, 10:18 PM Thread Starter
Tylervalo
The previous owner of my Jeep mentioned it needed ball joints soon, and actually had Mopar ball joints ready to go. Tonight I started replacing them and when I removed the old joints I found out they were knurled so someone must have already replaced them previously.
Can I replace them with my smooth Mopar ball joints or should I purchased some knurled one, and which ones are recommended right now?
Tylervalo is offline
post #2 of 11 Old 01-18-2020, 12:33 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Spicer.
https://www.extremeterrain.com/omix-...j-1803603.html
Mopar.
https://www.morris4x4center.com/knuc...00202ab-m.html
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #3 of 11 Old 01-18-2020, 06:24 AM
40vern
i am sorry, please delete if you want, but i am wondering what is the difference and can you use either one. also how do you tell the difference? i have replaced them several times and never noticed the difference. it is possible that i have had one and replaced them with a different one.
40vern is offline
post #4 of 11 Old 01-18-2020, 07:04 AM
ibikee
ibikee's Avatar
@Tylervalo Found out too late when I replaced mine they had knurled joints. I already had the new smooth ones and wanted to get her back on the road. Went ahead and pressed them in and they were tight going back in. Mine have been fine. I donít think youíll know till you press them in.
ibikee is offline
post #5 of 11 Old 01-18-2020, 07:07 AM
ibikee
ibikee's Avatar
@40vern The part of the shaft thatís hidden in the knuckle will either be a smooth surface of will look like a splined shaft.
ibikee is offline
post #6 of 11 Old 01-18-2020, 09:42 AM
skjeep
Sometimes i had an issue with the knurled joints that it stretched the hole a bit and the smooth ones were too small and had play in the axle C-s
But you will not know until you drop it in.
current 2x XJ, 2x JK-U, SJ, M38A1, WJ
gone XJ, TJ, XK, ZJ
skjeep is offline
post #7 of 11 Old 01-18-2020, 10:07 AM Thread Starter
Tylervalo
They pressed in firmly, they definitely didn't just slip back in.
post #8 of 11 Old 01-18-2020, 10:54 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The new Mopar ball joints pressed in firmly? Did you have to use a ball joint tool to get them fully seated? They need to be so tight that a ball joint tool is needed to seat replacements. I ask because knurled aftermarket ball joints usually booger up the seating surface enough that it never seems to hang onto OE style ball joints well enough if you try to go back to them after having had knurled ball joints installed.
Jerry Bransford is offline
post #9 of 11 Old 01-18-2020, 11:10 AM
40vern
thanks everyone. i find this interesting. i must have been doing it right all along cause i have had to use a tool to press them in. very difficult
40vern is offline
post #10 of 11 Old 01-18-2020, 07:56 PM Thread Starter
Tylervalo
Thanks, Jerry I was hoping you would chime in. They definitely required the press to get in, it was hard enough to get them seated enough to slip the press and get them in.
I'm going to run them for now, my hub bearings are probably due soon, so if I have any trouble I'll replaced the ball joints then. I won't know for a few days, I bent another set of ears on my outer axle shafts and had to order replacements. It's like those outer shafts are disposable items, I've never not bent one using hammer, u joint press or shop press.
Jerry Bransford likes this.
post #11 of 11 Old 01-21-2020, 08:46 PM
Mousejockey
You can take a center punch and make a series of divots on the inside surface to hold the new ball joint firmly
Mousejockey is offline
