Replacing an automatic tranny with a manual??? - JeepForum.com
post #1 of 13 Old 09-29-2013, 09:01 AM Thread Starter
YellowJeepGuy
So my 42RLE Transmission is on its last legs of life. I always wanted a stick shift that's the one thing I don't like about my Jeep. Would it be cheaper to bolt a Manuel transmission then a new 42RLE? Thanks in advance. Sorry if it is a dumb question I'm really curious.
YellowJeepGuy is offline
post #2 of 13 Old 09-29-2013, 09:05 AM
Ironhead
Ironhead's Avatar
i think you made a typo. can you explain what you want to do?
Ironhead is offline
post #3 of 13 Old 09-29-2013, 09:31 AM Thread Starter
YellowJeepGuy
My bad, I fixed it
post #4 of 13 Old 09-29-2013, 09:37 AM
Ironhead
Ironhead's Avatar
it can be done, thats for sure, but it is a bit of work. you would have to change out the PCM as well
if you really want a manual, then go for it. personally, i would swap in an AW4, but I prefer auto while off-roading
Ironhead is offline
post #5 of 13 Old 09-29-2013, 09:45 AM
Stu Olson
Stu Olson's Avatar
Hmmm.....in my work group, making that kind of statement would result in my manager issuing a "drug testing for cause" request.
The cost of the transmissions would be the lesser thing to worry about, if I were considering it. There are other issues to consider.....clutch pedal, clutch, clutch master cylinder and slave, and manual shifter. I'm pretty sure you'll need to also consider the engine computer and perhaps the input shaft of the t-case. (on my TJ, they are different lengths)
It is not a minor undertaking.....but it can be done. I did just the opposite and went from a manual tranny to an AW-4 automatic.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #6 of 13 Old 09-29-2013, 09:54 AM
Hendrix
TJOTY 2013
Hendrix's Avatar
I swapped out a 32RH for a NSG370 or whatever the 6 speed is. It was a simple swap, except for the long list of parts i had to locate.
Manual PCM
Clutch pedal assembly
I used all LUK parts for the swap
Flywheel,clutch kit
Trans cover OEM
OEM slave/master cylinder come preassembled and bled
CPS from a 05 for me
Longer front DS
shorter rear DS
Trans mount
Total cost was around 900.00 I think I got off cheap.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #7 of 13 Old 09-29-2013, 10:29 AM
Rollbar12
I thought about this for my TJ, but decided it would be simpler to buy a different Jeep with a manual
Rollbar12 is offline
post #8 of 13 Old 09-29-2013, 10:46 AM Thread Starter
YellowJeepGuy
Yeah well my Jeep is more of a sentimental thing to me. My grandpa bought be the Jeep stock for me when I was 16 and we drove it from where he lives, Oregon, to where I live in Texas. It's one of the greatest memories that I have with him sooo no selling the Jeep. As far as cost goes. Would it be cheaper just to get the Trany rebuilt or converting it to standard?
post #9 of 13 Old 09-29-2013, 11:45 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Before you can make a determination on which would cost less to do, you need to take the Jeep to a small Better Business Bureau rated INDEPENDENT NON-CHAIN transmission repair shop & get an estimate. Do NOT take it to a chain transmission shop like Aamco who is more likely than not to rip you off by estimating a low cost up front & then calling you later to say it's going to cost more... a lot more... than their original estimate. By then they have you by the short hairs. There are honest transmission shops out there but one that is a member of your local BBB is likely to be more honest than others.
Jerry Bransford is offline
post #10 of 13 Old 10-04-2013, 02:43 PM
Rollbar12
I get the sentimental value, do what Jerry suggests. I dont like large chain outfits for the same reason he posted.
post #11 of 13 Old 10-04-2013, 07:42 PM
jay-h
A trans rebuild will be a LOT less trouble than a conversion.
When you go for a quote, just ask for full rebuild... trying to save a few bucks by selective work is not worth it. If it's going to come out, do everything at once.
Mine was still working ok (though a bit lazy in very cold weather) when the shifter seal started to leak. I had the full rebuild done, and never regretted it.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is online now
post #12 of 13 Old 10-04-2013, 07:46 PM
digdug18
I just searched car-part.com in you area, nobody has a low mileage one, which would have been one option. Like stated above, check out the transmission shop. Checking online it seems prices for a fully rebuilt unit will run you $1300. Depending on the availability of jeeps in your area, you might be able to find a rear ended donor jeep for all the parts that you need to pull. Will you be doing the swap yourself? As swaps are very labor intensive, though I'm sure if you post up that you need help in your local forum, offer free beer and food you'll find people gladly willing to help you out.
digdug18 is offline
post #13 of 13 Old 10-06-2013, 01:51 PM
PhulesAu
In Texas is kinda vague, SA, DFW, Houston? If Houston, call thunderbolt.
PhulesAu is offline
