Replacing Airbags...Hard? - JeepForum.com
post #1 of 19 Old 12-11-2010, 05:47 PM Thread Starter
ipodblue12
Well, i got in a wreck in my 2000 Jeep Wrangler Sahara and both driver and passenger airbags deployed. How hard is it to replace them and what all do i need? Also, do i have to get them inspected by someone after?
Thanks
ipodblue12 is offline
post #2 of 19 Old 12-11-2010, 06:13 PM
flatlander757
flatlander757's Avatar
It's easy... basically you just remove the bag from the steering wheel and reinstall the new one.
Do it with the battery disconnected for safety reasons. You'll need the airbag module.
While I'm sure you could find one "used", I'm fairly certain it is illegal to reuse airbag parts... so check into that... may need to buy new from the dealer.
edit: Not sure about the passenger side airbag... it is usually a little more involved on most vehicles(remove glovebox and either contort around stuff to remove the airbag pad or remove the dash almost entirely). I haven't had one out of a TJ myself... but have on many other Chrysler vehicles.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #3 of 19 Old 12-11-2010, 06:20 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The passenger side is a PITA since it involves removing the dash which is why I haven't installed my replacement airbag yet.
Jerry Bransford is offline
post #4 of 19 Old 12-11-2010, 06:49 PM Thread Starter
ipodblue12
So all i need is one computer module? or one for each airbag?
post #5 of 19 Old 12-11-2010, 07:02 PM
Jerry Bransford
Administrator
You don't need a computer module, you just need replacement air bags.
post #6 of 19 Old 12-11-2010, 07:16 PM
flatlander757
It is the physical steering wheel "pad" that has the airbag assembly as a part of it.
Same with the dash pad... it will be the airbag assembly including the pad that you see on the dash.
Currently Jeepless.
post #7 of 19 Old 12-11-2010, 07:24 PM
lostone73
lostone73's Avatar
You must replace the airbag computer, once it stores a deployment command it cannot be cleared. Its done, finished, Kaput. Of course you can replace just the Airbag modules themselves for appearance reasons. They just wont work again until you correctly replace the SDM(computer).
SDM (sensing and diagnostic module) is inside the passenger compartment just ahead of the gear shifter. The SDM also contains the Discriminatory Sensor.
Replace Dashs and Airbags daily at a Large Multi-Brand collision center. The Jeep Wrangler is not too tough for either side. Take your time and reassemble everything the EXACT way it was originally, the integrity of the system depends on it.
FWIW Acura and Honda are the absolute worst to repair from an airbag perspective.
Simple explanation of faith :
Think of it as a movie. The Torah is the first one, and the New Testament is the sequel. Then the Qu'ran comes out, and it retcons the last one like it never happened. There's still Jesus, but he's not the main character anymore, and the Messiah hasn't shown up yet.
Jews like the first movie but ignore the sequels, Christians think you need to watch the first two, but the third one doesn't count, Moslems think the third one was the best, and Mormons liked the second one so much they started writing fan-fiction that doesn't fit with ANY of the series canon.
(credit to unknown author)
lostone73 is offline
post #8 of 19 Old 12-11-2010, 07:29 PM
Jerry Bransford
Administrator
Could you actually be talking about the airbag control module (essentially an impact sensor) which is really just an impact-activated switch mounted under the console at its forward-most position? I know about the airbag control module sensor, I have never heard of an airbag computer in the TJ.
post #9 of 19 Old 12-11-2010, 07:42 PM
lostone73
lostone73's Avatar
Depends on the year model, in my 2000 the box in front of the shifter contains the forward crash sensor AS WELL as the Diagnostic computer.
I dont know how it is configured in your 2004, it may be two separate units. I do know that it logs the data of the crash( veh speed, brake pedal status , rate of decelleration, ABS status, seatbelt use , ect). That has been required on all us vehicles since 1996 or 1997 per the DOT and NTSB.
In my experience, all 2nd generation airbag crash sensors, once tripped (command deployment), stay that way just the way they were made. They are basically a steel ball held in place by a calibrated magnet, when enough force comes along to dislodge the ball, it contacts two sharp pins and completes a circuit. The frontal impact sensor and the Discriminatory sensor must accomplish this task within .50 Ms (not sure of the exact spec).
Jerry, by all means, give it a try. Maybe the collision that deployed your TJ bags wasnt enough to really waste the whole computer. Damn sure not going to hurt anything to try. Just use common service precautions( battery disconnect, ECT).
My .02
post #10 of 19 Old 12-11-2010, 07:54 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That is not correct according to at least the 2001 Jeep Wrangler FSM. It says to only replace the ACM if it has suffered external damage.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #11 of 19 Old 12-11-2010, 08:00 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Jeep TJ's use an accelerometer and a microprocessor to fire the bags or verbatim from the FSM- When a frontal impact is severe enough, the microprocessor in the ACM signals the inflator units of both airbags to deploy the airbags.
I am Savvy
mrblaine is offline
post #12 of 19 Old 12-11-2010, 08:02 PM
lostone73
lostone73's Avatar
At this point its a matter of opinion, nevertheless, crash data is stored in that ACM....Period. I Get paid to put the vehicle back to pre accident condition, which doesent include a crash event stored in the ACM.
Its all falls on ethics I guess, If Jerry wants to see if it will work without a new computer, I encourage it. It cant hurt a thing.
Back on topic to the OP question, Yes you can replace airbags in your TJ. If you are capable to replace a heater core, you can relace your airbags.
post #13 of 19 Old 12-11-2010, 08:11 PM
lostone73
lostone73's Avatar
In addition to the electronic impact sensor, there is
an electromechanical sensor within the ACM called a
safing sensor. The safing sensor is a normally open
series switch located in the airbag deployment circuit
of the ACM. This sensor detects impact energy of a
lesser magnitude than the electronic impact sensor,
and must be closed in order for the airbags to deploy.
The ACM also contains an energy-storage capacitor.
This capacitor stores enough electrical energy to
deploy the airbags for up to one second following a
battery disconnect or failure during an impact. The
purpose of the capacitor is to provide airbag system
protection in a severe secondary impact, if the initial
impact has damaged or disconnected the battery, but
was not severe enough to deploy the airbags.
This is the steel ball MECHANICAL SENSOR I was refering too.(I called it the discriminatory sensor, as called by I-CAR)
Page 8M-4 2000 FSM
post #14 of 19 Old 12-11-2010, 08:53 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Page 8M-4 2000 FSM
Mine says similar, but one would readily surmise from the section stating which components SHALL be replaced because they are not intended for REUSE, that it is odd that the ACM is specifically NOT mentioned, when the airbags, Driver airbag trim cover, horn switch, the clockspring, and passenger airbag door are.
It's your job to do as you see fit, I only checked the FSM out of curiosity and found nothing about replacing the ACM and the description of the switch would seem to indicate that's it's not a single use ball trapping mechanism you made it out to be.
I am Savvy
mrblaine is offline
post #15 of 19 Old 12-11-2010, 09:06 PM
cosmo_j
this is alittle off the thread topic but if i were to remove the airbag fuse would the airbags still be able to deploy???
cosmo_j is offline
Replacing Airbags jeepthing360 TJ Wrangler Technical Forum 5 03-19-2009 05:04 AM
replacing airbags Peanut72 TJ Wrangler Technical Forum 4 10-05-2008 04:37 PM
Replacing and removing the hard top Ctskip YJ Wrangler Technical Forum 11 03-21-2008 07:00 PM
Replacing Airbags pwhit TJ Wrangler Technical Forum 1 06-24-2003 04:08 AM
Replacing Hard Top Windows scott YJ Wrangler Technical Forum 0 09-27-2001 05:01 PM
