Repairing soft top frame worn/torn webbing - JeepForum.com
post #1 of 24 Old 07-15-2011, 01:34 PM Thread Starter
Richd1963
Richd1963's Avatar
Thanks to Tecumsa for the link to Strapworks
I was able to get replacement webbing at $.50 a foot and I picked up some Stainless steel pop rivets at the local hardware store for $.20 each. I thought about using other methods of fastening to make the repair, but all in all, the rivets were cheap and simple. Easy to remove and install and I really don't plan on repeating this repair every few years. The new webbing appears to be a bit thicker and more durable. I also used Stainless flat washers under the rivets. I had those in my hardware drawer. I will insert a few pictures and I believe that if you click on a photo it will allow you to view the folder at Photobucket. I took many photos to try to document the process. I use a butane torch to seal the edges of the webbing after cutting was completed to keep it from coming unravelled over time. To make the holes in the material for the rivets and screws, I used a soldering iron. It melted right through the webbing and sealed the material from fraying as well. I managed to salvage one of the two straps that was still fairly intact and I used this as a template for the two straps I fabricated. It all worked well and total cost (less the small washers I already had) was $5.00, which is unbelievable. The shipping on the webbing was a few bucks and I ordered enough to do another jeep as well as some cool straps from Strapworks.com. I had fun doing the work and it just takes some patience. I hope the pictures do it justice.
REMOVING THE RIVET DEBRI FROM INSIDE THE TUBE:
OLD STRAPS
MEASURING UP FOR NEW STRAPS
USING SOLDERING IRON TO MAKE HOLES IN STRAPS
ATTACHING WITH RIVET GUN
DONE
THE OH SO HANDY CRAFTSMAN POP RIVET TOOL
POPS OLD WELLER SOLDERING IRON
Again there are many more detailed photos at photobucket. If you are interested in them. Try clicking this thumbnail to view:
Enjoy
Rich G. 2005 Wrangler 4.0 6-Speed.
just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only
Richd1963 is offline
post #2 of 24 Old 07-15-2011, 02:24 PM
Jonny Jeep
Jonny Jeep's Avatar
Nicely done.
Jonny Jeep is offline
post #3 of 24 Old 03-30-2012, 12:55 PM
robinmcj
robinmcj's Avatar
I am Resurrecting an old thread.
I have lost sleep over replacing my soft top frame or my 1 year old soft top with the new frameless tops. JUST because the nylon straps are breaking on the frame. I KNEW there had to be a way to repair it. Without this write up, I would still be without sleep AND spending a crazy amount of money on things that are not necessary!
You're awesome!
You sir, have saved me $350 at least!
THANKS!!!
"MY MID-LIFE CHRYSLER"
robinmcj is offline
post #4 of 24 Old 03-30-2012, 11:01 PM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
Mine were trashed. I ended up putting some small ratchet straps up there in place of the web. So far so good.
armyRN is offline
post #5 of 24 Old 03-31-2012, 07:25 AM Thread Starter
Richd1963
Richd1963's Avatar
I made sure to order some spare webbing as it was so cheap. It was really too easy as long as I already had the tools.
post #6 of 24 Old 03-31-2012, 08:43 AM
Sundowner
Sundowner's Avatar
Nice...one of mine is broken, so I can fix it as soon as the top comes off for the summer.
Sundowner is offline
post #7 of 24 Old 05-22-2012, 11:05 AM
jeepeno
Thanks for your ideas! Never used a rivet gun before. I'm $4.30 poorer (rivet gun and rivets), but now my passenger side webbing is attached securely to the back bow. I'm sure the drivers side will need the same help in a few months. My only concern, and a small concern at that, was the half rivets that were cut off will be forever stuck in the bow rattling around. I'm sure I'll never hear them... but that was my biggest concern. Not too bad. Easy fix. Thanks!
jeepeno is offline
post #8 of 24 Old 05-22-2012, 11:35 AM
SlackJaw
baby jeep
SlackJaw's Avatar
Hey I need to ask...one of mine broke a while back...I couldn't tell that it was serving any purpose, other than making it only fractionally slightly easier to raise the top...what am I missing out on why should I make this repair...not that I won't, as cheap and easy as I know it is thanks to this great write-up ...but am I doing harm by not having the strap on there? My top still looks nice and tight and straight and everything. Thanks!
SlackJaw is offline
post #9 of 24 Old 12-10-2012, 04:06 PM
SpeedJeep
SpeedJeep's Avatar
Perfect! I'll be doing this soon.
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline
post #10 of 24 Old 06-19-2014, 09:44 AM
Time_Out
I have the same question as SlackJaw. I just got a New Jeep and the PO cut one of the straps off completely and sliced about 3/4 of the way thru the other one. How necessary are they ?
Time_Out is offline
post #11 of 24 Old 06-19-2014, 10:14 AM
Neil F.
Necessary. Without them, the rear of the top will sag
Neil F. is offline
post #12 of 24 Old 06-19-2014, 03:58 PM
Neil F.
This what it will look like without the straps http://www.wranglerforum.com/f210/wh...op-744338.html
Neil F. is offline
post #13 of 24 Old 06-19-2014, 04:13 PM
Jonny Jeep
Jonny Jeep's Avatar
Avast Web Shield reports malware on that wranglerforum link above. It may be a false positive, it may not. It's not the first malware report I've had recently from that site. I've reported it to them anyway so they can check it out. The page doesn't load at all for me now.
post #14 of 24 Old 06-20-2014, 07:40 AM
Time_Out
Awww - that's so sad. It looks depressed . Good to know, I will be replacing those when I replace my windshield header channel. Still trying to figure out why the PO cut them...
Time_Out is offline
post #15 of 24 Old 07-03-2014, 02:56 PM
billtheforth
Hey guys can you help me out on the size and type of webbing that you ordered, I just ordered a new sailcloth R-A-T, and want to replace the webbing as one side is all the way ripped and the other side is well onits way, thaks for your help
billtheforth is offline
Repairing Stitching on Soft Top/Soft Top Boot DeepSky JK Wrangler Technical Forum 3 05-13-2010 11:09 AM
Fixing transfercase skid mount & repairing frame UltimatE YJ Wrangler Technical Forum 2 08-14-2008 01:15 PM
repairing a soft top Lance25 TJ Wrangler Technical Forum 2 10-02-2006 11:42 PM
Repairing Soft Top shoregirl75 TJ Wrangler Technical Forum 6 07-03-2006 10:38 PM
Repairing soft tops Lee TJ Wrangler Technical Forum 2 07-05-2005 09:07 PM
