Removing stock fog lights on a TJ - JeepForum.com
post #1 of 16 Old 11-17-2009, 03:11 PM Thread Starter
Smitttykid
Guest
I just received my new front bumper and was wondering if there are any tricks or things I should watch out for before removing the stock fog lights from the front bumper. I plan on reattaching them to the new tube bumper. The new one has the mounting tabs for fog lights. I plan on replacing the stock fog lights down the road, but right now - the budget says "nay nay". Any input would be greatly appreciated. Thanks, Smitty
Smitttykid is offline
post #2 of 16 Old 11-17-2009, 03:16 PM
zachbh
zachbh's Avatar
I think all you have to do is unplug them from the harness that's just inside the fender, then unbolt them. I hope your mounts on the new bumper are within reach of the stock harness! Good luck.
zachbh is offline
post #3 of 16 Old 11-17-2009, 03:26 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Unplug them and one bolt inside the hollow stock bumper.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #4 of 16 Old 11-17-2009, 03:32 PM
MisterO
MisterO's Avatar
yes its a fairly simple process.. unplug the wire harness and next grab a 13mm socket and unbolt it.. then to put back do the same just in reverse ..
MisterO is offline
post #5 of 16 Old 11-17-2009, 03:39 PM
mageedog
mageedog's Avatar
Yep real easy unplug and unbolt I just done this a while back.
mageedog is offline
post #6 of 16 Old 11-17-2009, 04:35 PM
SDDAVE
Im lazy I didn't unplug mine.
SDDAVE is offline
post #7 of 16 Old 11-17-2009, 04:43 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Yep. And if the mounts aren't within reach, Teraflex sells 10" extensions that are direct plug-ins.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #8 of 16 Old 11-17-2009, 05:06 PM
MudDuck99
MudDuck99's Avatar
2014 JK Wrangler
it was a pain getting mine off. the bolt broke off on each side.
MudDuck99 is offline
post #9 of 16 Old 11-17-2009, 06:21 PM Thread Starter
Smitttykid
Guest
fog light removal
Thanks guys! I'm going to tie into the project tomorrow morning! Smitty
post #10 of 16 Old 11-18-2009, 05:38 PM Thread Starter
Smitttykid
Guest
fog lights
-I got everything off ok, but there is no way the wiring plug is gonna reach the lights. They mount in the middle in front of the grill. I looked on Teraflex's website, but I could not find any harness extensions for the fog lights. I don't think 10" is going to be long enough. (that's what she said last night-ha-ha!).
Anyway, any input would be helpful. Do after market fog lights plug into the stock harness under the fenders? Smitty
post #11 of 16 Old 11-18-2009, 07:06 PM
RubiconRazorbac
Page 1 of "Jeep Wrangler TJ Products"
TJ Wrangler Fog Light Extension Wire | TeraFlex Suspensions
2003 TJ Rubicon:
2017 JKU Rubicon:
post #12 of 16 Old 11-19-2009, 05:10 AM Thread Starter
Smitttykid
Guest
Jeep fog lights
Got it. Thanks!! Smitty
post #13 of 16 Old 11-19-2009, 07:13 AM
robncar
robncar's Avatar
The thing I question about those extensions is that I don't see more than one year range? Jeep changed the fog light wiring in 2005. KC sells direct replacement fogs in two year ranges, '97-'04 and '05-'06. The tera ad makes no distinction. I'd call them before the order.
https://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #14 of 16 Old 11-19-2009, 07:35 AM
Phreak480
your local jeep dealer can get you fog light extensions as well. when i bought them from my 04 TJ they were cheaper than the aftermarket
Phreak480 is offline
post #15 of 16 Old 11-19-2009, 07:58 AM
Sobie
Bolt-on Maniac
Sobie's Avatar
I just snipped the wires and added my own wiring.
USAF
Sobie is offline
Help removing stock fog lights JeepsInLove YJ Wrangler Technical Forum 2 09-28-2008 04:54 PM
Removing daytime running lights Crawlings YJ Wrangler Technical Forum 1 04-12-2008 09:08 AM
Silvian Star Headlight w/ Stock Fog Lights / Halogen Off Road Lights mferrari TJ Wrangler Technical Forum 3 03-29-2006 07:37 PM
removing stock fog lights? Flatbroke TJ Wrangler Technical Forum 3 08-27-2005 11:17 PM
removing dash lights Bucket110 TJ Wrangler Technical Forum 3 09-27-2002 09:58 AM
