Removing jugs from stock bumper... - JeepForum.com
post #1 of 50 Old 03-05-2008, 12:20 PM Thread Starter
BloodThirsty
BloodThirsty's Avatar
Total noob here so bear with me. Just wondering if the jugs can be popped on and off or if I take them off are they off for good? Also when you take them off do you guys cap the ends with something, mod it or leave it open?
BloodThirsty is offline
post #2 of 50 Old 03-05-2008, 12:22 PM
Rocky529
Rocky529's Avatar
There are torx screws to remove and then the milk jugs slide right out of the bumper. You can put them back on if you want, no damage is done to the bumper.
You can leave the bumper un-capped, or you can purchase bumped end caps which came stock on 2006 SE and X model Wranglers:
http://www.jeepsareus.com/Merchant2/...Category_Code=
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 50 Old 03-05-2008, 12:23 PM
DVR
you can remove them and put them back if you want. some people report difficulty removing them. I had no trouble.
DVR is offline
post #4 of 50 Old 03-05-2008, 12:29 PM
Capeman29
I took mine off, they just bolt on with some torx screws, so long as theres no rust (the jugs have little metal spots for the bolts to grab) then its as easy as removing anything else that has screws.
I keep mine off though cuz its the closest thing to looking like an agressive rock bumper when your flat broke like me!
02 TJ, X Trim, Patriotic Blue, All Stock - - - Too Broke To Buy Any Fun Stuff
Capeman29 is offline
post #5 of 50 Old 03-05-2008, 12:31 PM
TanTJ04
TanTJ04's Avatar
I used a BFH on mine, But I'm never putting them back on!
Originally Posted by chriswj View Post
The 4.0 is like that fat guy who will eat mac and cheese that has been on the stove for three days; eats it and wont look back!
2004 TJ X 5spd, 30-Aussie locker and Chromo'd, 44-lsd & disc brakes, 4" Currie lift, Anti-rock, 1.25" bl, UCF 1" skid & Lo-pro mount, AA SYE, JKS MML, ZJ V8 Tierod, JKS Trackbars, smittybuilt winch w/ synthetic line, Caravan fuel injectors, CAI, TB spacer, flowmaster 44 2.5", 35x12.50x15 km2, 7" fenders, uniden cb
TanTJ04 is offline
post #6 of 50 Old 03-05-2008, 12:39 PM Thread Starter
BloodThirsty
I feel ya bro. I've had mine since August and I'm itching to mod it but family comes first.
post #7 of 50 Old 03-05-2008, 12:53 PM
slate210
A good way to remove them permanently is with a firm kick from a heavy boot.
2000 TJ 4.0 5-SP 115k mi. Patriot Blue - Bone stock...for now.
1997 TJ 4.0 5-SP 134k mi. Red Jeep Club Member
- Some mods...
2006 VW Jetta TDI DSG 54k mi. BLACK Rocketchipped, boostvalve, boost gauge.
slate210 is offline
post #8 of 50 Old 03-05-2008, 01:28 PM
M2LJ
A lot of people (myself include) take the front ones off but leave the back ones on. For one, the back isn't as pretty without them as the front it. Secondly, they do offer some protection from rocks on the trail or shopping carts.
I've heard rumor that some Jeepers won't wave if they see the milk jugs on the front bumper! That's not nice, I always wave!
Cheers ! M2
M2LJ is offline
post #9 of 50 Old 03-05-2008, 02:17 PM Thread Starter
BloodThirsty
Originally Posted by thedirt View Post
They require a Torx 30 bit to remove. For the front, unscrew the two top bolts and the one bottom bolt and pull them off. For the rear, there are two top bolts, and two bottom bolts.
I got the end caps from the local dealership. They were $3.60 each IIRC. Here are the part numbers for the end caps:
Front: 55078138AA
Rear: 55078139AA
You will need two each.
When you go to install them, take the milk jugs off, and using a flat head screwdriver, pop the nutserts off of the milk jugs, just rest them over the end caps, and carefully put them in the bumper. When they are lined up, tighten the screws on at a time and then once you have the end caps aligned, tighten them all the way.
Good luck! It took me maybe 20 minutes to get them all installed (mostly fighting with the nutserts).
THANKS! I'm calling my local dealer right now.
post #10 of 50 Old 03-05-2008, 02:35 PM Thread Starter
BloodThirsty
Covers will be here Friday. $3.20 each. Thank again!
post #11 of 50 Old 03-05-2008, 03:00 PM
WillysEdition04
WillysEdition04's Avatar
But without them how will your Jeep float in case of a flood or water fording incident?
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited
WillysEdition04 is offline
post #12 of 50 Old 03-05-2008, 03:33 PM
panathinaikos55
panathinaikos55's Avatar
Or a street sign!!! The neighborhood watch sign worked the best for me, although the speed limit sign didn't do too bad on the driver's side...
panathinaikos55 is offline
post #13 of 50 Old 03-05-2008, 04:06 PM
rxl
rxl's Avatar
2006 WK
Thats too funny, I just did this the other day. Everytime I looked at them they bothered me.
I bought "MY JEEP" for my wife
I bought "MY OTHER JEEP" for my daughter [she sold it]
I finally bought one for me
Canadian Jeep Club Member #7
99 GC limited
4.7 Quadradrive
97 TJ Sport
4.0 5 speed
99TJ Sahara
4.0 Auto
Sold to a life of blacktop
94 ZJ Limited
I6 Quadratrac
rxl is offline
post #14 of 50 Old 03-05-2008, 04:25 PM
JeepersCreapers
i used a hack saw when i removed mine because the screw were stuck.
JeepersCreapers is offline
post #15 of 50 Old 03-05-2008, 05:29 PM
JasonJW
Guest
I took the front ones off but left the back to plug the hole it leaves behind. Also, I hear they have tremendous resale value..
JasonJW is offline
Removing stock front bumper JeepsOLot YJ Wrangler Technical Forum 3 12-24-2008 10:10 AM
Bumper end jugs Big-E TJ Wrangler Technical Forum 11 09-18-2007 11:17 AM
Removing Rear TJ stock bumper grboone TJ Wrangler Technical Forum 8 09-09-2007 04:18 PM
Removing Stock Front Bumper? Mechamaniac TJ Wrangler Technical Forum 14 06-14-2007 09:00 PM
Removing Jugs? god.loves.ugly TJ Wrangler Technical Forum 3 02-09-2007 09:13 AM
