remove hood prop from hood ? - JeepForum.com
post #1 of 14 Old 07-19-2010, 07:42 PM Thread Starter
Hesher420
Hesher420's Avatar
Thanks to a moron that damaged my hood, I'll be swapping it out for a new one tomorrow. ('06 TJ) A seemingly simple task except for when it comes to removing one component, the plastic clip that holds the hood prop up against the hood when it is not in use. Does anyone know how to remove this piece of plastic without breaking it?
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #2 of 14 Old 07-19-2010, 07:43 PM
KeefsTele
Funny thing, mine somehow broke and I cannot find it.
~Nick
"I never thought I was wasted...but I probably was." ~Keith Richards
"I've never had a problem with drugs. I've had problems with the police." ~Keith Richards
KeefsTele is offline
post #3 of 14 Old 07-19-2010, 08:00 PM
hoosier724
hoosier724's Avatar
you have a hood prop? cool!
'03 TJ Sport,Light Tan Metallic,, Superlift 4" with BFG 33x12.5x15
Honk if you love Jesus...text while driving if you want to meet him!
hoosier724 is offline
post #4 of 14 Old 07-19-2010, 08:02 PM Thread Starter
Hesher420
Hesher420's Avatar
^Yeah, when I change the oil in the garage I don't have enough overhead to flip the hood back onto the windshield
Anyone have any ideas?
post #5 of 14 Old 07-19-2010, 08:35 PM
tulman22
tulman22's Avatar
Us a pick (ie dental or ice) and work your way sound one side at a time slowly prying it out as you go. Had to do this at the junkyard. Slow and Easy, it will come out.
Good luck.
US Navy "SPOOK" RETIRED
Impact Orange member # 39
tulman22 is offline
post #6 of 14 Old 07-19-2010, 08:41 PM
despotic
if worst comes to worst i think advanced auto sells them (or autozone) i broke mine aswell and so right now im using the zip-tie method, it works i guess.. good luck
Red Jeep club: Member #588
despotic is offline
post #7 of 14 Old 07-19-2010, 09:01 PM
wushaw
Rockin jeep
wushaw's Avatar
Your hood prop is on the hood itself? Wonder when they did that? Mines on the grill.
wushaw is offline
post #8 of 14 Old 07-19-2010, 09:47 PM
shanteaud
shanteaud's Avatar
** tj
Mine is on the hood as well......
shanteaud is offline
post #9 of 14 Old 07-20-2010, 06:37 PM Thread Starter
Hesher420
Hesher420's Avatar
Are you sure? The prop (and retainer) on my wife's '00 is mounted to the hood also.
Thank you Autozone - universal part - $7.99
post #10 of 14 Old 07-20-2010, 07:08 PM
Mousejockey
$8 for a plastic clip ?????
Mousejockey is offline
post #11 of 14 Old 07-20-2010, 07:37 PM
wushaw
Rockin jeep
wushaw's Avatar
Damn it could be....I haven't used it in like 9 years.
wushaw is offline
post #12 of 14 Old 07-21-2010, 07:20 PM Thread Starter
Hesher420
Hesher420's Avatar
Update for future reference:
1. The universal kit at Autozone does not have the correct part for the TJ hood.
2. To remove the "hood prop retainer piece" use a flat blade screw driver or a "auto door panel clip removal tool" (pictured below) to pry between the clip piece and the thin square piece at the base of the clip. The part that clips onto the hood prop will pull out of the base, and then the base will easily pull out of the hood. It can then be reinstalled in another hood and is just as tight and sturdy as it always was.
post #13 of 14 Old 07-21-2010, 08:38 PM
Jon-joN
i just put mine in the spring by the latch, no noise or problems
Jon-joN is offline
post #14 of 14 Old 11-27-2017, 03:27 PM
Intoojeep
Hesher 420 is right. That is how mine came out. One note: there is a square hole in front of the mounting hole that is larger and can easily be mistaken for the clip hole. Don't ask how I know. The correct square hole is behind the bump the larger hole is on and is smaller it accepts the clip perfectly.
Intoojeep is offline
remove , removing , hood prop , replace , replacing , TJ
Where's my hood prop? jeepcreep TJ Wrangler Technical Forum 22 06-21-2010 08:54 PM
Hood prop or lay the hood right back on the windsheild frame? Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 27 01-29-2010 04:55 PM
Broken Hood Prop Catch mjmangus YJ Wrangler Technical Forum 18 03-24-2009 07:00 PM
Hood prop TheMatrix TJ Wrangler Technical Forum 12 02-29-2008 09:11 AM
Hood Prop rod trav_k1234 TJ Wrangler Technical Forum 31 05-22-2007 05:35 AM
