regear on 32's? - JeepForum.com
post #1 of 43 Old 09-15-2008, 08:23 PM Thread Starter
jeepramnauth
jeepramnauth's Avatar
2010 JK Wrangler
regear on 32's?
hello guys. i got a stock geared 99 tj. im putting on a 2" skyjacker lift and planning on putting in 32x11.5 interco TSL tires. would you recommend a regear? to what?
jeepramnauth is offline
post #2 of 43 Old 09-15-2008, 08:26 PM
Red_
With your 3.07s it'd be an idea. Just find a set of axles off a 4 cylinder TJ. Easiest way to get a set of 4.10s under your rig
Red_ is offline
post #3 of 43 Old 09-15-2008, 08:33 PM Thread Starter
jeepramnauth
2010 JK Wrangler
ok, sounds good. I got the 4.0L So 4.1's will do the trick? I was thinking on possibly buying some 4.88 but I guess that would be overkill right?
post #4 of 43 Old 09-15-2008, 08:39 PM
cheapjeep06
cheapjeep06's Avatar
4.88 would be good for 33's. Just add 1"BL and bumpstops to your 2" lift.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline
post #5 of 43 Old 09-15-2008, 08:52 PM
DBLJ
DBLJ's Avatar
Thats if he had the auto. He has the manual so 4:56's would be perfect for 33's.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #6 of 43 Old 09-15-2008, 09:17 PM
Red_
Yeah 4.88s would be over kill for 32s
Red_ is offline
post #7 of 43 Old 09-15-2008, 09:40 PM
DBLJ
DBLJ's Avatar
Oh for 32's? If you are dead set on sticking to that tire size then go with 4:10's. Like someone else said find some axles from a 4cyl and swap those. I would not spend the money to regear for such a small tire size. You could also throw on a body lift and get 33's and then regear.
DBLJ is offline
post #8 of 43 Old 09-15-2008, 10:14 PM
mudb8
want it rite or rite now?
mudb8's Avatar
4.10's will do the trick for a 3spd auto on 32's, with a 5spd manual, 4.56-4.88 would be in the ball park.
the 4spd auto does it's best work with 4.88's on 32-33's .69 OD ratio.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #9 of 43 Old 09-15-2008, 10:17 PM
2005X
2005X's Avatar
swampers tend to run larger, so a "32 is more fo a "33
2005X is offline
post #10 of 43 Old 09-15-2008, 10:19 PM
2005X
2005X's Avatar
i was looking on interco website and it doesnt look like they make a 32x11.5 TSL, i see a 32x9.5
2005X is offline
post #11 of 43 Old 09-16-2008, 07:21 AM Thread Starter
jeepramnauth
2010 JK Wrangler
Oh, my bad, I guess I misread it somehow! You are correct, I am looking for the 32x9.5 I know these will decrease my mileage, but the 33's will do so even more! So since its my daily driver I'll just do the 32's and look for a 4cyl axle from a scrap yard or something! Thanks!
post #12 of 43 Old 09-16-2008, 07:41 AM Thread Starter
jeepramnauth
2010 JK Wrangler
Oh wait, I think I was looking at the TSL SX, they got 32x11.5. But for a compromise (better mileage) I should probably get the 32x9.5's
post #13 of 43 Old 09-16-2008, 07:49 AM
2005X
2005X's Avatar
thats there not gonna be much if any difference in milage between a 9.5 or 11.5, your talking about swampers any way, they are in their own seperate class. your are looking at radius right, and not the bias
2005X is offline
post #14 of 43 Old 09-16-2008, 08:45 AM
breckboarder55
breckboarder55's Avatar
Not all 4cyls came with 4.10s, some of them came with 3.73s...
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #15 of 43 Old 09-16-2008, 08:55 AM
badoosh27
badoosh27's Avatar
I have 32" BFG's with 3.07's and its not bad at all. It suffers somewhat on the highway, but it's fine for me. I get 17.5 mpg, but if i were going to a higher gear, i would not be able to keep that milage.
If it's your DD, i would recommend buying the tires and running them for a while till you know what you need.
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
Do I need to regear? raztastik TJ Wrangler Technical Forum 11 08-20-2009 05:58 PM
TIRE SWAP! 31's to 32's and 32's to 33's *PICS* thejafe TJ Wrangler Technical Forum 69 05-13-2007 05:37 PM
3.07 regear for 32's???? sparsons79 TJ Wrangler Technical Forum 14 03-12-2006 07:14 PM
When to regear? sgrim80 TJ Wrangler Technical Forum 21 04-12-2005 10:37 AM
What do I need to regear?? blacktjsport TJ Wrangler Technical Forum 10 02-02-2005 10:16 PM
