Recovery questions inside. - JeepForum.com
post #1 of 9 Old 08-04-2010, 09:34 PM Thread Starter
zachy1029
OK guys, I just have a few questions about my new LJ. I've been searching all day but can't seem to find too much info on the stock bumpers for the TJ/LJ. Are either of them strong enough to be recovered with? I'm planning on getting a winch plate for the front bumper for my Mile Marker PE8000. Am I correct in believing this ties in to the frame and not the bumper? Also, would it be viable to weld some tabs for D-rings on the rear bumper? If it's possible I'd like to avoid buying new bumpers, provided the stock ones can do what I need them to. I also plan on shortening the front one on each side. Really what I need answered is if these babies would hold up if I needed to be pulled out with them. Hope you guys can help! thanks.
Anyone wanna give a struggling college student some free mods?
zachy1029 is offline
post #2 of 9 Old 08-04-2010, 09:45 PM
tjsooner
winch plate mounts to the frame, don't weld d-rings to the rear sheet metal Jeep calls a bumper. There should be a rear tow hook mounted to the frame from the factory. If not you can get one here in the classifieds for cheap.
tjsooner is offline
post #3 of 9 Old 08-05-2010, 01:09 AM
BlueFlame
BlueFlame's Avatar
... searching all day but can't seem to find too much info on the stock bumpers for the TJ/LJ.
There's plenty about them, but not what you're looking for.
NO. Not even close.
..winch plate for the front bumper for my Mile Marker PE8000. Am I correct in believing this ties in to the frame and not the bumper?
Correct.
Um. No.
They hold the license plate up and the milk jugs on. That's about it.
(Consider this - ever see what's inside a modern car bumper? The plastic fascia is hiding styrofoam! All the TJ bumper does is sacrifice itself - willingly - if you hit something. It's hardly thicker than the sheet metal the body is made of.
If you search well enough though, you can find pics of them Vee-shaped because someone tried to use them for recovery...
BlueFlame is offline
post #4 of 9 Old 08-05-2010, 06:21 AM Thread Starter
zachy1029
Thanks. I know that was a lot of questions haha, so I appreciate it.
post #5 of 9 Old 08-05-2010, 06:23 AM
Sundowner
Sundowner's Avatar
Or broken, entirely. Winch lines need a stable mounting point.
Sundowner is offline
post #6 of 9 Old 08-05-2010, 06:25 AM Thread Starter
zachy1029
Well if the winch plate mounts onto the frame, that should be stable enough i'm guessing, right?
post #7 of 9 Old 08-05-2010, 06:34 AM
Sundowner
Sundowner's Avatar
Well, unless you have a structural member that's more inherently strong than the frame, it's going to have to work.
Serious Answer: yes...that's why they're made that way.
post #8 of 9 Old 08-05-2010, 06:35 AM
woodie416
2011 JK Wrangler
to make a very long story short, there was one time when i was stuck in ice. i broke through a thick sheet of it, which caused my hitch to be under the ice and my rear bumper was the only thing exposed. It was the only way i could think of to have my buddy recover me because i didnt have front tow hooks either. Basically the stock rear bumper is good enough for one hard pull and its over. luckily the hard pull my buddy gave me was enough to get my rear tires up over the thick sheet of ice, but it also ripped the bumper halfway off. just search around for factory rear tow hooks or look around because you can get a decent rear bumper with d rings for relatively cheap.
And i have a smittybilt xrc8 winch mounted on the front bumper of my tj with a smittybilt winch plate. it has worked fine that way for me multiple times and my stock front bumper is fine.
2011 JKUR 6 speed.
The Weekend Warrior
woodie416 is offline
post #9 of 9 Old 08-05-2010, 07:17 AM Thread Starter
zachy1029
sweeet. sounds like i'll go with the winch on the front and a rear bumper.
tj , lj , wrangler , bumper , strength , recovery
TJ Stock Rear Recovery Hook Questions bmpregler TJ Wrangler Technical Forum 14 05-12-2010 07:35 PM
Bout To paint inside hardtop. Got some questions TOLjeep TJ Wrangler Technical Forum 0 06-01-2009 08:07 PM
Best place to attach recovery hook...other newb questions jp575 TJ Wrangler Technical Forum 12 04-18-2009 06:29 PM
Few questions - tow hook, quick disc, spacers - pics inside Buford TJ Wrangler Technical Forum 2 10-13-2008 10:38 AM
