Rear turn signal and brake light short - JeepForum.com
post #1 of 14 Old 12-28-2015, 03:55 PM Thread Starter
Twanner
I'm having trouble with my 04 TJ. When it gets really cold (20 degrees or colder) both rear turn signal lights flash at the same time, but the front works fine. Also, when this happens, if I hit the brakes with the blinker on the blinkers all stop flashing completely. Even the dash light for the turn signal stops flashing and ticking.
Any advice on what could be causing this? I find it really strange that it only seems to happen when its bitter cold out.
Being stupid does not make you an expert on what is stupid...
Twanner is offline
post #2 of 14 Old 12-28-2015, 09:52 PM
Cuder
Cuder's Avatar
I would bet your multifunction switch has gone bad. It's under the steering column cover, your brake lights, tail lights, hazards, and turn signals function thru it. It's easy to replace, three screws in the bottom cover and two torx screws hold the switch in.
My Build Thread:
Cuder is offline
post #3 of 14 Old 12-29-2015, 03:41 AM
Jonny Jeep
Jonny Jeep's Avatar
I'm with Cuder on this one. Temporarily, until you can replace the switch, you could try cycling the hazards on and off several times to see if that will help.
Jonny Jeep is offline
post #4 of 14 Old 12-30-2015, 10:44 AM Thread Starter
Twanner
Thanks for the input guys. I'll check it out. I was thinking that it could be a bad ground somewhere, but I'm hoping it's just the switch because that will be much easier to fix.
Twanner is offline
post #5 of 14 Old 12-30-2015, 11:17 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
X 3 on that diagnosis.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #6 of 14 Old 12-31-2015, 10:34 AM Thread Starter
Twanner
Cycling the hazards doesn't seem to help. Just to be sure, I cycled everything a few times and nothing. Got a new switch on order, should be here in a few days.
Twanner is offline
post #7 of 14 Old 01-06-2016, 11:33 PM Thread Starter
Twanner
It wasn't the multifunction switch. I replaced it tonight and the problem persisted. My next try will be the break solenoid switch under the break pedal.
Twanner is offline
post #8 of 14 Old 01-07-2016, 12:15 PM
williamb81
I had very similar issues and would have bet it to be the multifunction switch as it fixed my issue. Please keep us updated as to what you find. Thanks.
williamb81 is offline
post #9 of 14 Old 01-07-2016, 10:18 PM
jpfelix
check the grounding at the taillights and trailer harness, if installed. they ground through the mounting bolts and can act up from time to time.
jpfelix is offline
post #10 of 14 Old 01-08-2016, 11:30 AM Thread Starter
Twanner
I tried replacing the stop light switch and that didn't fix the problem either. Checking the grounding for the trailer harness and the tail lights was going to be my next move.
Twanner is offline
post #11 of 14 Old 01-08-2016, 02:13 PM
DilutedImage
It's interesting that this only occurs at such low temperatures. I'd look for contacts/components close enough to be effected by thermal contraction, or perhaps a short being created by water/ice.
DilutedImage is offline
post #12 of 14 Old 01-08-2016, 03:45 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Make sure both tail light housings are well grounded which is accomplished via the three hex-head bolts under the red lens cover inside both tail light housings. Use a wrench or nutdriver to loosen/tighten all six bolts a few times and then secure them so you're sure they're making a good ground connection to the tub's sheet metal for the tail lights. Bad/weak/intermittent grounds between the tub and tail light housings can cause all kinds of weird tail light problems.
Jerry Bransford is offline
post #13 of 14 Old 01-08-2016, 05:02 PM
TJ4Jim
I was having a minor problem with the left blinker lighting up when braking so as Jerry suggested I removed both rear fixtures and ran a tap thru the body threads and cleaned up the bolts on the wire wheel and re-installed. Problem disappeared after that.
If you come to a fork in the road take it.
TJ4Jim is offline
post #14 of 14 Old 01-13-2016, 01:26 PM Thread Starter
Twanner
Fixed the issue. Terminals on the trailer harness were burnt out and a couple of them were fused together. Replaced the trailer harness and everything is all good.
Twanner is offline
brake light , short , tail light , turn signal
