Rear Tailgate Maximum Weight - JeepForum.com
post #1 of 3 Old 02-14-2004, 09:25 PM Thread Starter
DouginTN
Guest
Anyone know what the max weight is the rear tail gate will hold before it starts sagging when opened?
I'm designing a gas and water can rack to fit over the spare tire, but do not want to overload the tailgate.
Thanks...
DouginTN is offline
post #2 of 3 Old 02-14-2004, 11:15 PM
blupupher
blupupher's Avatar
Seems like it is either 50 or 70 lbs that it is rated for. For any type of water/gas carrier, you need something else besides just the tailgate, either a swing out carrier or something like the best top tire carrier.
blupupher is offline
post #3 of 3 Old 02-15-2004, 08:40 AM Thread Starter
DouginTN
Guest
Sounds about right when I look at the hinges. What got me thinking was the Wrangler Trail Rack from Garvin Industries. It appears to attach to the door at the tire carrier, and has two swing out braces, held to bracket by pins. The pins can be removed and the gate opened. I beginning to wonder if they mean you can only open if the rack is empty.
I have written them, and hope to receive a reply.
For my application I am adding the inside Mountaineer storage rack, but want to keep the fuel outside. So, I was considering welding together a small rack that would be designed for only a gas and water cans.
Thanks...
DouginTN is offline
How much weight on TJ tailgate? fowlball TJ Wrangler Technical Forum 4 02-01-2008 10:20 AM
Whats the maximum tyre size with hanson rear tyre carrier? JCM TJ Wrangler Technical Forum 1 10-01-2007 07:58 AM
Maximum Tongue Weight on Class III Hitch Cooper993 TJ Wrangler Technical Forum 10 09-11-2007 12:55 PM
practical weight limit of tailgate Faramir66103 TJ Wrangler Technical Forum 3 11-30-2006 10:01 PM
Spare tire bike racks... too much weight for the tailgate? 98Sahara TJ Wrangler Technical Forum 9 11-03-2003 09:43 PM
