Rear Main Leak? - JeepForum.com
 4Likes
post #1 of 17 Old 07-14-2020, 11:55 AM Thread Starter
bamaham
Rear Main Leak?
My daughter, living away from home for school, has a 2005 TJ with a 4.0 that she purchased in May. I drove up and met her and we test drove the vehicle and all seemed fine. I got under it to look for the common rust issues and it was clean. Last week the transmission went out and she took it to Aamoco for repairs. They replaced the transmission and now there is an oil leak. I am thinking it is the rear main leaking since these things are notorious for that problem. It was not leaking before the repair, but now it is.
Question, is it possible that they were a bit too rough removing and installing the transmission and caused the rear main to develop a leak? She lives 4.5 hours away, so I am just guessing here. I am already dealing with a crappy power train warranty where the provider has denied the claim on the transmission. I just dropped $3,400 and I am broke. If it is possible the transmission shop helped create the problem, I'll even share in the cost of the repair.
Thanks for any suggestions -
bamaham is offline
post #2 of 17 Old 07-14-2020, 12:03 PM
2jhanna
Sorry, but I can't answer your question regarding if the trans shop could have caused the leak. But, RMS leaks are very common with our 4.0s, some think about every 50k miles. Secondly, I just replaced mine myself, after many years of leaking, and while pretty labor intensive, parts were less than $50.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #3 of 17 Old 07-14-2020, 12:28 PM Thread Starter
bamaham
2jhanna - was it an all day job or a two day job? I just read the instructions another user posted a while back. I usually double the time others say it took them. I'm not afraid of getting my hands dirty, just seem to always run into bad luck!
bamaham is offline
post #4 of 17 Old 07-14-2020, 12:44 PM
2jhanna
Bama, it could be a one day job, but I spent 2-3 days on it. I actually started disassembly even before I had the parts. I tend to take my time, do a lot of clean up, walk away when need be, etc.
Here's a link below where I made several post. I just again made the last post a few minutes ago. Not happy right now, you'll see why when you read it.
https://www.jeepforum.com/forum/f9/r...plate-4395577/
jhanna
denton county, tx
2jhanna is offline
post #5 of 17 Old 07-14-2020, 01:04 PM
UKXJ
I can't see how changing the trans could damage the RMS - but I'm no expert.
Both my (running) XJ's leak but not seriously but when I read how to do the job it scared me a little. However, now I've seen a couple of vids on how it's done I feel more confident & will probably tackle one when I'm swapping in another trans, as access is better - then (hopefully) I'll feel up to doing the other one. Of course this is of little help to OP whose major problem is distance separating him from the Jeep. I think what I'd do is tell her to live with it until she can bring to him - say, next Easter.
$3,400! What, for the trans job? How can that be? It's well over 3-times what I was quoted (albeit a couple of years ago) to rebuild mine - & THAT was far more than I was prepared to pay.
UKXJ is offline
post #6 of 17 Old 07-14-2020, 01:12 PM Thread Starter
bamaham
2jhanna - Just read your posts. Sorry - gotta be rough. I am torn between going up and trying to do it or just trying to scrape up the money to a pay a shop. She lives in an apartment complex and I am not so sure they would appreciate me doing this in the parking lot.
Thanks for all the advice in your write-up -
bamaham is offline
post #7 of 17 Old 07-14-2020, 01:14 PM Thread Starter
bamaham
UKXJ - $3,400 is the going price in our area. I checked around because my Tahoe transmission was half that price just 18 months ago.
bamaham is offline
post #8 of 17 Old 07-14-2020, 01:49 PM
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
I have removed many a transmission in my day- all out of older GM V-8's all with similar 2 piece RMS's
I just dont see how its possible to damage it by R&R a tranny
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
post #9 of 17 Old 07-14-2020, 02:43 PM Thread Starter
bamaham
Thanks guys for all your help. I just did not have a clue. The more I read, the more I see that the main seal (if that is the problem) can just suddenly start leaking. After the $3,400, I was jsut trying to grab onto anything I could. I appreciate all the input!
bamaham is offline
post #10 of 17 Old 07-14-2020, 03:44 PM
2jhanna
this is not a fun job even in a shop, much less an apartment parking lot. Never know what you may run into or what tool you left at home.
Depending on how bad its leaking, you may can wait till next time your daughter comes home. Have her check the oil form time/time, and even have a quart and a funnel if need be.
Mine leaked but never had to add oil between changes. The 4.0 holds 6 quarts, so being 1/2 qt lo isn't a big deal.
Good luck.
jhanna
denton county, tx
2jhanna is offline
post #11 of 17 Old 07-15-2020, 07:06 AM
jeepguy03
Winning
jeepguy03's Avatar
I would first verify if the Jeep is leaking engine oil, or transmission fluid. If it's transmission fluid, it is related to the work that was done, and probably more likely if it wasn't leaking anything before. If it's oil, then it's just a coincidence the rear main seal started leaking when the work was done on the transmission. The 4.0L has a 2 piece rear main seal that can be changed without even removing the transmission, so I don't believe replacing the transmission is likely to interfere with it.
Depending on how bad the rear main leak is, it really won't hurt anything besides maybe the asphalt she parks it on. Just remember to check the oil every so often, which on a 15 year old Jeep she should be doing anyway.
bamaham likes this.
0331 head swap DIY:
"Build" thread:
Previous: 1990 XJ Limited, 2000 XJ Sport, 2000 XJ Sport
Current: 1998 Wrangler Sahara
jeepguy03 is offline
post #12 of 17 Old 07-15-2020, 01:45 PM
UKXJ
Never cease to be surprised at price differences between our 2 countries, especially the parts for US vehicles that are cheaper here but one thing I'd have expected to be (much) cheaper for you guys would be auto. trans. work. I was quoted a couple of years ago (by the only trans. shop in town) £800 - say $1,000 - either to repair my 2nd XJ's trans 0R pull the one out of my 1st one (already reduced to parts status) & swap that in - so I bought a 3rd one for a few $'s more.
bamaham likes this.
UKXJ is offline
post #13 of 17 Old 07-15-2020, 02:48 PM
shortydog33
shortydog33's Avatar
Verify it is the rear main and not the valve cover, they tend to leak from the rear and oil runs down the back of the engine and appears to be a rear main seal, a lot of times it is just the valve cover and an easy fix. Just something to check.
bamaham likes this.
shortydog33 is offline
post #14 of 17 Old 07-16-2020, 09:22 AM Thread Starter
bamaham
Thanks for all the input folks. I am going to try and drive up in two weeks. She knows to check the oil at least every two days for now until we find the cause.
bamaham is offline
post #15 of 17 Old 07-16-2020, 10:15 AM
jeepguy03
Winning
jeepguy03's Avatar
It could be the valve cover since it will run down the block to the same spot, but in my experience the valve cover is usually just a seep, and won't create as much of a drip onto the ground as the rear main seal or oil pan unfortunately.
bamaham likes this.
0331 head swap DIY:
"Build" thread:
