Rear Diff - cant get the axle pin out - JeepForum.com
 8Likes
post #1 of 34 Old 03-27-2020, 09:55 AM Thread Starter
ozzyjeep69
Hi, need some advice please.
I have a 98 TJ 2.5 petrol project.
The rear diff was known to be bad, had a bad whine. Ive had the cover off and sure enough there is a tooth smashed on the big ring, loads of debris in there.
Luckily enough the previous owner left an entire new spare pumpkin (I think its called), in the boot / trunk for the americans! Yay.
Strangely there was no small bolt holding the big central "spider gear"? pin in place. However, I cant get the big central pin out. Ive given it a few gentle whacks with a persuader in both directions, but its not budging.
Should I pound on it? Is there a trick to getting it out? I guess I cant get the pumpkin unity out without getting the pin out so the axles can slide sideways - even if I unbolt the carrier covers..?
Help!
ozzyjeep69 is offline
post #2 of 34 Old 03-27-2020, 10:24 AM
JFM626
JFM626's Avatar
unfortunately you have a broken cross shaft bolt (pin) Beating on it will likely break the cast metal holding it in. There are different methods of removing it. Google "removing broken cross shsft pin" and take your choice. Now as you will have to replace the ring gear in any event and if you have some means of cutting the cross shaft without damaging the axle (torch comes to mind) then you could do that. then push in the axles, remove the "C" clips and remove the axles. Now you can remove the Carrier assembly and work on a bench to remove the broken bolt.
How can you trust an atom, they make up everything
JFM626 is offline
post #3 of 34 Old 03-27-2020, 11:05 AM Thread Starter
ozzyjeep69
The small pin/bold which goes through the big cross shaft pin IS definitely out, gone, all the way, no where to be seen.
If I get a small scewdriver / q-tip it goes all the way through. So does that make life easier?
I do not have any cutting equipment. Home amateur mechanic...
post #4 of 34 Old 03-27-2020, 12:28 PM
JFM626
JFM626's Avatar
Yes, If you are certain that the pin is no longer there ( please be certain) and nobody has welded the cross shaft in place then by all means get a suitable sized punch and a good size hammer and drive it out. All that holds it in place is that pin. I am just amazed that it has not fallen out while being driven and caused some catastrophic damage.
JFM626 is offline
post #5 of 34 Old 03-27-2020, 03:36 PM
Ben
Ben's Avatar
Originally Posted by ozzyjeep69 View Post
Should I pound on it? Is there a trick to getting it out? I guess I cant get the pumpkin unity out without getting the pin out so the axles can slide sideways - even if I unbolt the carrier covers..? Help!
The C clips need to come out first so you can take the axles out, so that means the rear has to be on jackstands with no tires or brakes.
Then the whole pumkpin (carrier) comes out. Mark the bearing caps so you put them back the same.
Then take the ring gear off of the carrier, remember the bolts are reverse thread.
The cross pin does not have a retaining bolt like others, it's a roll pin, and it sure looks like some or most of yours is still in there.
Then the cross pin will slide right out.
Ben is offline
post #6 of 34 Old 03-27-2020, 04:17 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Some Dana 35 differentials do indeed have a threaded retaining bolt in there, not a roll pin. I assisted a friend with her broken Dana 35 axle shaft and I needed a 12-pt. 1/4" socket to get the threaded retaining bolt out so I could replace the broken shaft.
Ben likes this.
Jerry Bransford is offline
post #7 of 34 Old 03-27-2020, 04:18 PM
fromme
fromme's Avatar
In your photo I can clearly see the roll pin that holds the main cross pin is still in place. You need to drive that roll pin out and then the cross pin will slide out for you. You will need the correct size punch or driver tool to drive that pin out.
2003 TJ Rubicon, 3" Zone lift, 33" Mickey Thompson MTZs, 4.88s, Warn Zeon 8S winch
fromme is offline
post #8 of 34 Old 03-27-2020, 05:18 PM
JFM626
JFM626's Avatar
That I was not aware of, front Dana30's yes. I am unable to discern the roll pin, but for sure I would try to emove it as suggested. I did not mean to lead you astray. But hopefully you now have the correct answer.
JFM626 is offline
post #9 of 34 Old 03-27-2020, 06:27 PM
Mousejockey
To me it looks like a threaded bolt that has broken off at the threads. i 'zoomed in' and there appears to be threads showing in the housing.
BrokeJeepJoe likes this.
Mousejockey is offline
post #10 of 34 Old 03-27-2020, 06:59 PM
JFM626
JFM626's Avatar
I believe either supposition could be correct. IMO ozzyjeep69 it would be prudent to try to remove the "roll Pin" with a small punch first. If indeed you can put a Q-tip right through the pin, it would point to a roll pin securing the cross shaft, rather then a broken bolt
JFM626 is offline
post #11 of 34 Old 03-28-2020, 02:18 AM
Mousejockey
Not saying it isnt a roll pin, Ive seen strange stuff done to rigs, but there is no where for it to exit if you were to "punch it thru"
post #12 of 34 Old 03-28-2020, 02:36 AM
Arty McGeep
Arty McGeep's Avatar
Looks like maybe the bolt head broke off and someone already drilled a hole through it, in an attempt to remove it. Since you have an extra carrier, just keep drilling it out with larger diameter drill bits until all the threads are drilled out. The rest of the bolt/pin should come out then. I don’t think you can punch it through. It will have to come out the way it went in. I’ve never seen a roll pin there, but maybe? If it is, drill that sucker out. What do you have to lose? Use a left handed drill bit if you can. Maybe you’ll get lucky and it will catch and unscrew the bolt. A right angle drill such as this might be handy. Oh, don’t forget to make sure the new gear ratio is the same, obviously haha.
Arty McGeep is offline
post #13 of 34 Old 03-28-2020, 06:48 AM
Ben
Ben's Avatar
The only benefit to keeping this carrier would be not having to set the gears back up.
The more I look at it the more I agree it looks like a bolt. Had to drill one out on an 8.8 one time. Fun stuff.
Seeing as you're 4.10 and the ring gear has to come off (other ratios the cross pin can slide past) you might as well pull the carrier and fight the good fight on your work bench.
yes!
Ben is offline
post #14 of 34 Old 03-28-2020, 10:33 AM
williambmac
williambmac's Avatar
Jerry you are indeed correct. All dana 35 differentials use a cross pin locking bolt. The dana 30 front differentials use a drift pin.
If you are lucky, you may be able to heat the differential case with a propane torch to melt the Loctite, then back the retaining bolt out with a trans pick. If that doesn't work you may need a right angle drill and an EZ out kit.
2005 Rubicon Unlimited, 4" Clayton long arm
35" Mickey Thompsons, lots of stuff
Black Magic Big brake kit
williambmac is offline
post #15 of 34 Old 03-28-2020, 04:12 PM
bonza
I think he may have a Dana 44 axle going by the photo?.
and if as the OP name suggests he is in Australia, then its certainly a 44 as all TJ Wranglers delivered there had Dana 44's as standard, but then again he mentions a 2.5 motor. all Aussie delivered TJ's only had the 4.0
2005 TJ Light Khaki
bonza is offline
