Rear Axle Bearing/Seal Kit - Need Help - JeepForum.com
 3Likes
  • 1 Post By 2jhanna
  • 1 Post By jay-h
  • 1 Post By rockcrawlin
post #1 of 9 Old 10-19-2021, 11:40 PM Thread Starter
rockcrawlin
rockcrawlin's Avatar
I have a 2005 LJ with a leaking rear axle seal. This Jeep belonged to my father and I inherited it after he passed.Most of the mods where done while he owned it. If I remember correctly, it has Superior Super 44 axles, but I知 not 100% sure. How do I determine which 44 axle I have? I知 assuming that if I have Super 44 axles, I値l have to buy a Super 44 bearing and seal kit?
2005 Jeep Wrangler Rubicon Unlimited (LJ) 4.0L / 42RLE
rockcrawlin is offline
post #2 of 9 Old 10-20-2021, 08:47 AM
greenmachine99
greenmachine99's Avatar
Those axle shafts will still run a standard set10 bearing. The seal will also be standard. You will need a way of cutting the old bearing/retainer off and a way to press the new bearing/retainer on.
greenmachine99 is offline
post #3 of 9 Old 10-20-2021, 03:17 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The bearing retainer is removed by drilling through it but stopping just before the drill bit reaches the axle shaft. Use a bit diameter equal to the width of the bearing retainer, then use a cold chisel to break it open at the hole. The old bearing can be removed with side cutters and pliers, pealed apart like an orange. The new bearing and retainer will have to be pressed on though.
Jerry Bransford is offline
post #4 of 9 Old 10-20-2021, 05:10 PM
2jhanna
Yep, did mine on stock axles last year. Like said above, trickiest park is cutting off old retainer and bearing, and pressing new ones on.
Jerry Bransford likes this.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #5 of 9 Old 10-20-2021, 05:27 PM
jay-h
pretty good explanations
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #6 of 9 Old 10-20-2021, 09:10 PM Thread Starter
rockcrawlin
I already removed the seal, bearing and retainer. I just needed to know what parts I値l need to replace. Thanks guys. I値l order some timken or spicer parts.
post #7 of 9 Old 10-20-2021, 09:36 PM
Jerry Bransford
Administrator
The bearing and retainer set is called a SET10, go with either Koyo or Timken. For the seal go for a Timken 9912S.
post #8 of 9 Old 10-21-2021, 06:07 AM
2jhanna
I was pleasantly surprised when I got my Crown kit pictured above. There was actually Timken bearing and seal in the box. Can be seen by zooming in on the bearing.
jhanna
denton county, tx
2jhanna is offline
post #9 of 9 Old 10-21-2021, 10:16 PM Thread Starter
rockcrawlin
Thanks
