RE adjustable lower control arms - JeepForum.com
post #1 of 5 Old 11-07-2006, 02:10 PM Thread Starter
Serafim
Serafim's Avatar
Hi,
Sorry about these stupid questions, but I just got a set of RE SR2 lower adjustable control arms and it came without install instructions and I need some help.
1 - Does the jam nut go on the axle side or the frame side?
2 - The other side has an off center rubber joint. The arm side of this joint should face up or down in the mount?
3 - In Rubiconīs website they said that these arms are greasable. As It donīt have any grease point, what shoul I grease (joints or the steel insert inside the arm) ?
4 - After adjust the arms, what is the tork to tight the nut?
Thanks
Mauricio
https://www.jeepforum.com/forum/attac...1&d=1162930210
1998-white-4.0 L-manual-BFG 31x10,5
1999-green-4.0L-auto-BFG 31x10,5
Serafim is offline
post #2 of 5 Old 11-07-2006, 02:48 PM
UTWeezul
The jam nut goes toward the frame mount of the control arm. You want the axle mount of the control arm to be the smooth part where nothing hangs down below the control arm brackets. I know the SuperFlex CAs are greasable but I don't know about the superride CAs. I know the rubber bushing end of mine do not have a grease point but the bearing end does. Yours should be like stock bushings just a better/stronger control arm
36" TSL/SX
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #3 of 5 Old 11-07-2006, 04:38 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
To explain the jamnut: the jamnut is screwed onto the male threaded part of the arm... that threaded part is screwed into the female threaded part of the control arm.
The jamnut should be tight against the female arm to keep things tight so it acts as one solid control arm.
As for the direction of the bushing... the offset bushing should be on the axle end, and should be placed so the arm is lower than the bushing. That is done to provide clearance so the arm doesn't bind on the bracket when the suspension is flexed.
Picture from stu-offroad.com
I'll be Savvy someday!
neZZr is offline
post #4 of 5 Old 11-08-2006, 04:57 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
your instructions are the same for the SF arms. you don't have any grease points.
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
Poor Boy is offline
post #5 of 5 Old 11-08-2006, 04:58 AM Thread Starter
Serafim
Serafim's Avatar
Thanks Guys. You help me a lot.
Serafim is offline
Lower Fixed Control Arms vs adjustable lower contol arms jeep2005ride TJ Wrangler Technical Forum 5 03-20-2009 02:23 PM
Adjustable Lower Control Arms scanderw TJ Wrangler Technical Forum 0 02-24-2008 12:34 PM
Lower Adjustable Control Arms... need 'em soon! thejafe TJ Wrangler Technical Forum 3 03-19-2006 11:12 PM
Lower Adjustable control arms Jr KLR TJ Wrangler Technical Forum 1 07-17-2005 09:25 AM
Adjustable Lower Control Arms Spiderman TJ Wrangler Technical Forum 21 03-15-2005 02:24 AM
