Which Rancho shocks for 2" TJ lift? - JeepForum.com
 5Likes
  • 1 Post By Jerry Bransford
  • 1 Post By TheBoogieman
  • 2 Post By Deputy_Wee_Woo
post #1 of 11 Old 05-10-2020, 10:15 AM Thread Starter
Deputy_Wee_Woo
Hi everyone,
Super quick question. I'm going the 2" route on my TJ and will be ordering pro comp coil springs. I want to run the Rancho 5000x shocks, but I'm not quite sure which ones to order. I would just order the ones that say they're for a 2" lift, but I've read that those end up being longer than needed. For anyone that has run 2" coils and rancho shocks, which part number of shocks were you running? I did check all of the jeep forums, but it's got me debating between sizes.
Thanks for any help.
I hope to order it tonight.
Deputy_Wee_Woo is offline
post #2 of 11 Old 05-10-2020, 01:37 PM
joe_jeep
pull your springs out, remove the shocks, disconnect the sway bar, remove the rubber bump stop pad.
use a floor jack, push it to full bump on one side, full droop on the other.
adjust your bump stops so everything clears at full bump.
while it is at full bump, measure from shock mount to shock mount.
find the longest shock that its collapsed length will fit at full bump.
i get that is not what u wanna hear though.
buying a 2" lift shock is a guessing game without measuring properly.
the rancho 5000x is a solid choice in shock.
quite a few here really like them.
what ever u do, do not buy pro comp shocks!
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #3 of 11 Old 05-10-2020, 01:52 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Go for the 0-2" model of the RS5000x. They run tall so don't even consider the next size up.
TheBoogieman likes this.
Jerry Bransford is offline
post #4 of 11 Old 05-10-2020, 02:18 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Kolak on here can hook you up with some good prices on the shocks. I bought some from him for my XJ.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
[email protected] or [email protected]
Kolak likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK on 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
SOLD 99' XJ /4.0L-AW4/ 5.5" lift / 33" DC tires.
TheBoogieman is offline
post #5 of 11 Old 05-10-2020, 03:48 PM
Pine_Cat
Pine_Cat's Avatar
Are those stock travel? The OP may need to worry about topping out because I'm not sure if Pro Comp's 2" springs are progressive.
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
post #6 of 11 Old 05-10-2020, 04:20 PM
TheBoogieman
Distubed Jeepaholic
Rancho shocks run long. The next size up would be for a 2.5" lift and would probably work for a 3.5" lift.
https://www.amazon.com/Rancho-RS5000.../dp/B013PUD120
post #7 of 11 Old 05-10-2020, 04:29 PM Thread Starter
Deputy_Wee_Woo
Thanks guys! 0-2" it is! I'll order them up now.
post #8 of 11 Old 05-29-2020, 07:33 PM Thread Starter
Deputy_Wee_Woo
Ordered them a few weeks ago, but the order never arrived and Amazon finally told me to cancel the order for a refund. The last ones I ordered were listed for 0-2" of lift, but it didn't have the actual part number in the listing. So, I found them somewhere else but I need to order them by part number. So, just to clarify, are the 0-2" lift shocks the RS55128 RS55240 combo? Thanks again.
post #9 of 11 Old 05-29-2020, 10:17 PM
RDPrimeaux
RDPrimeaux's Avatar
RS55128
Extended Length (in): 21.030 in.
Collapsed Length (in): 13.050 in.
Upper Mount: Stud
Lower Mount: T-bar
RS55240
Extended Length (in): 20.125 in.
Collapsed Length (in): 12.938 in.
Internal Design: Twin-tube
Upper Mount: Eyelet
Lower Mount: Eyelet
2006 LJ Rubicon
RDPrimeaux is offline
post #10 of 11 Old 05-31-2020, 08:56 AM Thread Starter
Deputy_Wee_Woo
Originally Posted by RDPrimeaux View Post
RS55128
Upper Mount: Stud
Lower Mount: T-bar
RS55240
Upper Mount: Eyelet
Lower Mount: Eyelet
Thanks a ton man! I went ahead and ordered them. They should be here Wednesday.
post #11 of 11 Old 06-01-2020, 03:02 AM
TheBoogieman
Distubed Jeepaholic
You should have ordered them from Kolak. You wouldn't have had those problems.
Kolak likes this.
