Quiet muffler, Wich one? - JeepForum.com
post #1 of 11 Old 03-15-2009, 01:36 PM Thread Starter
popeyesides
popeyesides's Avatar
Quiet muffler, Which one?
I have a 06 LJ and want to replace the stock muffler but I would like to keep it quiet as as I can. What do you guys recommend.
popeyesides is offline
post #2 of 11 Old 03-15-2009, 01:38 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Do a search on mufflers.They have covered this a zillion times.I like Magnaflow personally.
GOLENJEEPTJ is offline
post #3 of 11 Old 03-15-2009, 02:21 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Wouldn't that be WITCH ONE for married Jeepers?He said quiet. STOCK is as quiet as any.No companies boast of low performance,quiet mufflers that I know of.Loud mufflers do nothing but piss off your neighbors.
TheBoogieman is offline
post #4 of 11 Old 03-15-2009, 02:36 PM
Doggbone
Doggbone's Avatar
Hushpwer II
I am running the Hushpower II .... sounds nice and mean, not to loud either... thats what worked for me and my LA
Doggbone is offline
post #5 of 11 Old 03-15-2009, 03:36 PM
Tim
Tim's Avatar
he said quiet....
i have the hushpower ii also...
with the 5 speed it was obnoxous as hell but with my auto its not as bad. i would like to have a quieter muffler but with the clayton long arm it is not really possible.
97 TJ 4.0, AW-4, Clayton, A.R.B., Highly polished HP30, Super 88
There are no shortcuts to any place worth going
91 XJ 4.7
Tim is offline
post #6 of 11 Old 03-15-2009, 05:23 PM
George Dickel
George Dickel's Avatar
Hey Popeye - fill in your profile.
With that said, I will have to assume that since you have a stock muffler, then you probably still have your Catalytic converter. A Dynomax Super Turbo will be fine with a cat. I had a pair welded in on my Stang before I removed the cats and it was quiet. After cat removal, it rumbles at idle and screams at WOT. (More to my liking!) I would think it would be fine for what you're looking for. The 18" Magnaflow sounds pretty good too coupled with cats. I heard one of those last week at the local muffler shop.
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #7 of 11 Old 03-15-2009, 06:23 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
go to a Midas and buy a factory replacement muffler.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 11 Old 03-15-2009, 08:40 PM Thread Starter
popeyesides
Thanks George, I will fill out my profile and check out the Dynomax. Thanks for everybodys response as well.
post #9 of 11 Old 03-15-2009, 08:57 PM
ET48
ET48's Avatar
Quiet!!!!????? Come on. What is this world coming to?
I would just find a factory replacement. You could have no muffler, have your factory catalytic convertor and still be considered quiet.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #10 of 11 Old 03-16-2009, 06:48 AM
VTECZILLA
Stock.......... if you want quiet. want to cheaper Dynomax Super Turbo
2003 Sahara [B]4" Superlift JKS 1.25BL and MML 33" BF-G muds on
American Racing Baja's Magnaflow exhaust. Factory Rubicon Rockers. 10K winch.
VTECZILLA is offline
post #11 of 11 Old 03-16-2009, 08:07 AM
Nonya
Go to NAPA...they have a couple of very choices.
Nonya is offline
Looking for very quiet muffler with 2.5" inlet... dwilliamsceg TJ Wrangler Technical Forum 3 01-04-2010 05:53 PM
Looking for free flow quiet muffler. KMB TJ Wrangler Technical Forum 10 10-16-2008 01:37 AM
A quiet flow-thru muffler? live2hunt TJ Wrangler Technical Forum 16 03-22-2008 09:51 PM
Quiet Muffler scrappy TJ Wrangler Technical Forum 18 12-21-2007 06:08 AM
Quiet YJ muffler available ? stilllearning6 YJ Wrangler Technical Forum 11 09-08-2005 11:00 AM
