Questions on pulled drive shafts, Chasing Vibrations. - JeepForum.com
post #1 of 15 Old 01-03-2010, 04:08 PM Thread Starter
Maxxram
Maxxram's Avatar
Hello,
I have been having some vibes while driving on the highway at 50mph and up. The vibrations seem to be rhythmic and are felt throughout the entire jeep. (although not in the steering wheel)
I have been going through the suspension over the last few days and found the front and rear track bars were loose. Also found front drive shaft u-joint had a little movement so I replaced it. Checked all other u-joints front and rear, check the bolts on all control arms, Lubed all grease fittings.
The vibes seemed to be a lot better,vibes were moved to about 65mph and up.
Then today the wife and I decided to take a trip to Cabela's, Its about a 30min ride down the highway. On the way out jeep felt smooth as long as i kept it under 65mph. On the way home however, the vibes proceeded to get worse. The vibe's started at 45mph and above. Vibes did not chance with acceleration, deceleration, coasting, was just related to speed.
By the time we reach our off ramp on the return trip the vibes were getting to the point were my phone laying on the dash was vibrating. As soon as i slowed below 40mph the vibes went away. But now i have an issue with vibes on acceleration, once the jeep gets above 15mph when acceleration the jeeps starts shaking. None of the vibes or shaking can really be felt in the steering wheel so it leads me to believe the issue is in the rear.
My first question is how fast can i go in 4H with the rear drive shaft removed?
(I would like to take it on the highway to test since that's were the vibes originally started)
My second question is instead of removing the complete front drive shaft, could i just unbolt it from the front diff and tie it up to the frame? (I would of course be in 2H with the rear shaft reinstalled)
Thanks for any information.
Maxxram is offline
post #2 of 15 Old 01-03-2010, 06:31 PM
Bubba3200
Yes you can remove the front drive shaft from the front diff and strap it to the frame. Dont put in 4-L tho. Most ppls say not to go over 55 in 4-H. I had the angry sparrows and I took the jeep to a driveshaft shop and for 260.00 out the door they removed both shafts, all new joints and centering ball and balanced both shafts. I see that lots of ppls do there own driveshafts u-joints but what I dont understand is you almost never hear about them getting the shafts re-balanced. Hell I didnt even know I had vibs-balance problems with the shafts until they were re-balanced. When I drove the rubicon off from the shop I couldnt believe the smoothness of the drivetrain. When I got up to 60-70 mph I thought I was driving a Lincoln (not really lol!). Since you replaced a u-joint why not rebuild both shafts and take it somewhere that has the equipment to balance the shafts. I watched mine be rebuilt and the guy was not gentle with the shafts. After the BFH banging on the shafts they needed a balance. Also check ball joints TRE's and maybe get the tires balanced.
Bubba3200 is offline
post #3 of 15 Old 01-03-2010, 06:39 PM
Imped
Imped's Avatar
Check both output nuts and pinion nuts. Make sure both are torqued to spec and not loose.
OlllllllO
IndyORV
Imped is offline
post #4 of 15 Old 01-04-2010, 11:07 AM
Gl0b3y
Gl0b3y's Avatar
Ive been driving around for a week now without my rear driveshaft since it blew. Ive gone speeds up to 100 KM/H without any problems. Not sure if it would be the same for you so I would take it easy at first
Gl0b3y is offline
post #5 of 15 Old 01-04-2010, 11:21 AM Thread Starter
Maxxram
Maxxram's Avatar
Thanks for the information.
This morning on the way to work nothing changed with the vibes, they were still bad. (I only have a 2mi drive). I did notice however that when backing into the parking spot as soon as i hit the breaks they was a loud clunk from under the jeep. At lunch time i had the wife stop by and drive the jeep forwards and backwards while i watched all the control arms. Found the RE Bushings are shot. Drivers front lower, and passenger front upper.
Ordered a complete new set of bushings and will be installing them this weekend.
Hopefully that solves my issues. Only thing i don't understand is how they failed so fast? I was just under the jeep on Saturday checking everything out and didnt notice them moving.
Maxxram is offline
post #6 of 15 Old 01-04-2010, 11:48 AM
Jeffro06
Jeffro06's Avatar
Originally Posted by Maxxram View Post
Found the RE Bushings are shot. Drivers front lower, and passenger front upper. Only thing i don't understand is how they failed so fast?
A buddy of mine just got a free set of bushings from RE, they had a bad batch and had a bunch of early failures, you may want to call them.
Jeffro06 is offline
post #7 of 15 Old 01-04-2010, 11:57 AM
Imped
Imped's Avatar
This has been an ongoing issue for a long time. Search around and you'll fine plenty of info. Regardless, I highly doubt that's the cause of your vibe. So you're saying you pulled the rear shaft and drove in 4wd? How's the front pinion angle look?
OlllllllO
IndyORV
Imped is offline
post #8 of 15 Old 01-04-2010, 01:53 PM Thread Starter
Maxxram
Maxxram's Avatar
Never got the chance to pull any of the shafts, was going to do it today after work, But then i found the bad bushings, I will not be driving the jeep till the bushings are replaced. They should be here Friday. Since the lift was already installed when i bought the jeep, (I'm the second owner) RE will not warranty anything, nor would i have expected them to. Right now as it is when just moving the jeep forward or backward the front pinion is rotating up and down quite a bit. So the plan is to wait till i have all the bushings replaced then revisit the vibe issue's if they remain.
Maxxram is offline
post #9 of 15 Old 01-07-2010, 06:21 PM Thread Starter
Maxxram
Maxxram's Avatar
Update on my vibration issue, Replaced all the RE control arm bushings today and took the jeep for a drive, I am still getting bad vibrations when under acceleration from 20mph and up. All U-joints in front and rear drive shafts feel tight with no play. The things that has me really confused is that if I put the jeep in 4H almost all the vibes go away. In 2H from 20mph and up the vibes can be felt slightly in the steering wheel and felt pretty good in the seat. Anything that's on the dash will vibrate like crazy.
Anyone have any clue on what I should check next??
Again the vibes form 20mph and up did not start until after a 30min highway drive at 65mph this past Sunday. Up until that point the only vibe I had was a very slight one between 65 and 75mph
Maxxram is offline
post #10 of 15 Old 01-07-2010, 07:09 PM Thread Starter
Maxxram
Maxxram's Avatar
Here are pics of the front and rear drive shaft angles. Do they look ok?
Maxxram is offline
post #11 of 15 Old 01-07-2010, 07:14 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Front pinion looks low?...
Gone but not forgotten.
Knuckelhead is offline
post #12 of 15 Old 01-07-2010, 08:41 PM Thread Starter
Maxxram
Maxxram's Avatar
Well I couldn't just let this issue wait till tomorrow. So I said to heck with going to bed and I went out and removed the front drive shaft from the axle. Took a test drive and the issue remained. So that rules out the front for the most part. Come back home and crawled back under the jeep and reattached the front shaft, then removed the rear shaft. Turns out the rear u-joint at the pinion is bad. When I removed it from the pinion one cap fell off and there was nothing but dust inside the cap. Also if you try to rotate the u-joint on the drive shaft it is locked almost solid. It will only move about 1/4" when trying to rotate it. Took the jeep for a drive with the rear shaft removed and NO MORE VIBES!!
Looks like tomorrow I will be replacing the rear drive shaft u-joint.
Maxxram is offline
post #13 of 15 Old 01-07-2010, 09:19 PM
rondak46
rondak46's Avatar
Good Job Max! I love this stuff! Troubleshotting is great fun when you get to do it Vicariously. Just kidding, the reward of fixing something when you go through the frustration of having the problem yourself makes the satisfaction ten fold. .... or something like that....
rondak46 is offline
post #14 of 15 Old 01-07-2010, 09:50 PM Thread Starter
Maxxram
Maxxram's Avatar
Anyone know the spicer part number for the rear driveshaft to axle u-joint for the RE CV shaft im running. Would it be the spicer 5-212x?
Here is a link to the shaft.
http://www.rubiconexpress.com/Jeep/LJ/Product.aspx?folder=LJDS∂=RE1895-265
Maxxram is offline
post #15 of 15 Old 01-09-2010, 04:36 PM Thread Starter
Maxxram
Maxxram's Avatar
Just an update on my issue, I replaced the rear u-joint in the rear driveshaft and now all serious vibes are gone. I still have one annoying vibe that does not start till I hit 65mph. But i think the issue with that could be a slightly low front pinion angle. I will be purchasing a magnetic angle finder tomorrow then setting the proper front pinion angle.
Thanks again for the help.
Maxxram is offline
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 08:39 PM
vibrations from drive line? Pathogen1337 TJ Wrangler Technical Forum 3 04-26-2008 08:11 AM
Drive shaft vibrations Junk TJ Wrangler Technical Forum 4 07-26-2007 01:01 PM
SYE & CV Drive Shaft Vibrations mikesixtysix TJ Wrangler Technical Forum 10 11-29-2006 09:35 PM
drive shaft yoke got pulled out of TC, what do i do!?!?! youngjeeper11 YJ Wrangler Technical Forum 11 12-22-2004 02:47 PM
