Question about changing gear oil after a R&P swap - JeepForum.com
post #1 of 6 Old 06-16-2014, 12:46 AM Thread Starter
Jeeper69
Jeeper69's Avatar
Pertaining to giving the differential(s?) fresh gear oil after the gear break-in, can I just pump it out and put in new oil? Or since there might be metal flakes I need to unbolt the cover and let it drain that way? Sounds like a stupid question.
Jeeper69 is offline
post #2 of 6 Old 06-16-2014, 05:50 AM
2jhanna
Many "quick lube shops" just pump/suck out the old. I would pull the cover though to get it all out and do a inspect.
It will work either way.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #3 of 6 Old 06-16-2014, 05:50 AM
Poswald
It would be best to pop the covers and look at the gears for any unusual break in wear or other anomalies.
Poswald is offline
post #4 of 6 Old 06-16-2014, 09:03 AM
pcoplin
pcoplin's Avatar
You're gonna want to check and wipe any metal flakes out.
FullStack MotorSports
pcoplin is offline
post #5 of 6 Old 06-16-2014, 11:54 AM
Robbie13
Robbie13's Avatar
I have to do that to mine here shortly. I just got 4.10's put in and have to do this in about 250 more miles. I am going to remove the covers.
Robbie13 is offline
post #6 of 6 Old 06-16-2014, 12:43 PM
gregstudeny
2006 WK
I was wondering this after I changed gears a few months ago. I pumped out all the fluid first. Then I popped off the cover and checked what I would have left behind. There wasn't a a significant amount of metal found in either. After removing the cover there was definitely some metal left on the cover and diff. I don't know if it was enough to cause a problem or not but I'm glad I did. If you get lube lockers it takes some of the work out of disassembly and reassembly.
gregstudeny is offline
