prowd new father - JeepForum.com
post #1 of 6 Old 08-01-2003, 07:26 AM Thread Starter
kjg26
kjg26's Avatar
prowd new father
I picked her up monday. She's a 97 Sport! Black on Black. Anywho I figured I post some pics up! Also I got a few questions. Well i can't figure out how to post pics! Damnit!!! I''ll ut em up on a website and link to em. I got a quick question about my rear diff. It's "wet" the mechanic says it is normal? Is it?
thanks
keith
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 6 Old 08-01-2003, 07:33 AM
GoTopless
Guest
GO TO SEARCH!!!!!!!!!! remember to look under search before you ask questions!!!! (just a tip) GO under search and type in posting pics....them go to the box under that and put it to General Discussion and you should find youe awnser! HTH
GoTopless is offline
post #3 of 6 Old 08-01-2003, 07:56 AM
Dee Cue
Dee Cue's Avatar
First off, Congrats! To post pics, just click on the link below for details. https://www.jeepforum.com/forum/showt...threadid=22702
FYI, There's a wealth of information near the top of the TJ Forum section called "TJ Forum F.A.Q. & Commonly Used Links." Enjoy!
Blk, '05 LJ, 6-spd, 3" Zone SL, 33" BFG AT on Soft 8's
Dee Cue is offline
post #4 of 6 Old 08-01-2003, 12:07 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Congrats, I think you got the best year made for a TJ! So far as the differential being wet, is the differential vent tube connected? If so, where does the wetness appear to be coming from? If it's from the front pinion shaft area, which is not uncommon, that's not a difficult seal to replace. I replaced mine and the seal was under $10. It took me maybe 30-45 minutes to replace it. Most of that time was spent tearing up the old seal to get it out!
Jerry Bransford is offline
post #5 of 6 Old 08-01-2003, 12:12 PM
Owen
Owen's Avatar
I have a 98 d44 in the rear of my 2000 it leaks lsightly out of the pinion seal as Jerry described. I will eventually replace it but to be honest unless it gets to be a faster leak real quick I wouldn't worry about it.
Smuggler Re-Born.....
Owen is offline
post #6 of 6 Old 08-01-2003, 06:05 PM Thread Starter
kjg26
kjg26's Avatar
thanks for taking the time to answer my question. you all seem to know what your talking about when it comes to my problem. I'm going to set up an imagestation account now and i'll be posting up pics of the rear diff and it's issue. The mechanic said that the rear pinion seal will need to be replaced, could that be causing the diff. to be wet? thanks again Also, if you think thats my problem, does anyone have a walk through on how to change the rear diff seal?
keith
kjg26 is offline
A Father and Son 87 YJ Build UnderPar YJ Wrangler Technical Forum 31 09-26-2010 04:09 PM
A father and two son's versus the 88 Wrangler Ron83CJ YJ Wrangler Technical Forum 136 12-21-2009 03:28 PM
seriously, im not a bad father puckjer JK Wrangler Technical Forum 47 11-09-2009 11:28 PM
Father and Son Project Completed! Zazoos YJ Wrangler Technical Forum 21 08-04-2009 10:56 PM
Father wanting to purchase 89 YJ - Need Advice kinder YJ Wrangler Technical Forum 18 02-10-2008 05:22 AM
