Power Steering leak help - JeepForum.com
post #1 of 6 Old 07-18-2017, 06:38 AM Thread Starter
jkimmerlein7
Looking for some tips on identifying where a power steering fluid leak is coming from. I've checked the lower seal under the pitman arm and it is fine. I can't quite find a specific spot it is coming from but it is dripping. I have been trying to top it off when I can but as you can imagine it's getting annoying to have to top it off every day. Any suggestions on common leak spots to check?
jkimmerlein7 is offline
post #2 of 6 Old 07-18-2017, 07:20 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Have you checked the pump where it connects to the reservoir? That's where mine was leaking from and dripping onto the front axle diff.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #3 of 6 Old 07-18-2017, 07:22 AM
LJ Dave
Leaks can come from anywhere. I suggest you thoroughly clean the power steering pump, hoses and gear box. Use 409 or some other cleaner/degreaser and a rag to get the grime off and then watch for the highest spot that gets damp with power steering fluid. I had one of my hoses develop a leak where the rubber part meets the steel swaged on end of the hose. I was quickly able to locate the spot of the leak once I had everything cleaned up.
2005 Rubicon LJ 4.5 inches of lift, 35's
LJ Dave is offline
post #4 of 6 Old 07-18-2017, 07:41 AM
92WranglerinUT
I just discovered a power steering leak on my jeep. It is leaking at the pump itself, just behind pulley. Have you checked there?
92WranglerinUT is offline
post #5 of 6 Old 07-18-2017, 08:47 AM
wadewen
wadewen's Avatar
If it's coming out of the pulley shaft area, a rebuild kit will have all the seals and orings needed to repair it.
His: 97 TJ Sport -
FSM Link:
Hers: 02 WJ Overland -
FSM Link (have to create login) -
wadewen is offline
post #6 of 6 Old 07-18-2017, 10:34 AM
Jonny Jeep
Jonny Jeep's Avatar
If it's leaking from the shaft and you do it before the bearing collapses you can get away with just changing the front bearing.
That's what I ended up doing, after my pump failed when waiting for a repair kit to arrive. I still have the unused kit.
It's a 6203 2RS bearing on the 4.0L pumps.
Sent from my D5803 using JeepForum
Jonny Jeep is offline
