power locks - JeepForum.com
post #1 of 12 Old 08-28-2002, 12:23 AM Thread Starter
bmcm161
Guest
power locks
Sundawg saw you posted about power locks wandering if i could get some pics of the install before i try to do it myself
bmcm161 is offline
post #2 of 12 Old 08-29-2002, 01:53 PM
wheelerman
Guest
power door locks
i have power door locks in my 00 tj,but i didn't put them in .the guy that had the jeep before me did it or had someone do it. i guss i'm not much help but i do like myt p. d. locks .
wheelerman is offline
post #3 of 12 Old 08-29-2002, 04:01 PM
KnightFire
KnightFire's Avatar
If I recall correctrly, www.qaudratec.com sells these. They are simple motors that simply bolt on over your window roll down teeth (when you remove the hand crank you'll see it) and all you do is wire them up!
Sounds pretty simple
Patriot Blue 4.0L
Cardinal Red 355CI
Flame Red 5.7L 4x4
Titanium Metallic 4.7L 4x4
KnightFire is offline
post #4 of 12 Old 08-30-2002, 04:01 AM
AgentZed
Guest
Dude, he was asking about power LOCKS, not power WINDOWS.
AgentZed is offline
post #5 of 12 Old 08-30-2002, 04:06 AM
AgentZed
Guest
Originally posted by Mr. Bill
Beat me to it...
That's hard to do, as I don't see any evidence that you ever sleep!
AgentZed is offline
post #6 of 12 Old 08-30-2002, 07:48 AM
KnightFire
KnightFire's Avatar
ROFLOL, its what I get for answering posts after long shifts....hahahaha oh well
KnightFire
Patriot Blue 4.0L
Cardinal Red 355CI
Flame Red 5.7L 4x4
post #7 of 12 Old 08-30-2002, 07:57 AM
YellowX
YellowX's Avatar
JC Whitney has been selling manual/power conversions for years. Might be interesting to peruse their site for a setup. Be it locks or *snicker* windows.
Here's a set: Valiant Power Lock Conversion
Fred
JAFGJ
YellowX is offline
post #8 of 12 Old 09-02-2002, 08:24 PM
Trippnk
Guest
I installed the door lock actuators myself. It was actaully really simple but I might recommend one of those trim panel removal tools so you don't break off the retainer clips, also you need a small torks bit for the trim panels, a srew driver or two, and asmall drill bit to put holes in the doors were the wires have to go through, I drilled mine right behind the strap that keeps the door from swinging all the way open, some wire splices to extend the two leads off the actuators to under the steering wheel and of course electrical wire, about 5ft on the driver side and about 10 on the passenger side so there is plenty to work with. I bought the actuators at best buy for 20 bucks. When putting the door panels back on, be sure to put the little clips back on the door straps other wise the srews will just spin and eventually fall out. After I did the install I took it back to Best Buy and had them install the rest of the equipment which was included in the price of the transmitters, brain, ect. which was $100. So I had keyless entry for about $150 total. If I had the actuators installed at Best Buy it was going to be $40 per door. Not worth the money.
Trippnk is offline
post #9 of 12 Old 09-03-2002, 06:15 AM
YellowX
YellowX's Avatar
Trippnk,
Where did you get the actuators?
Thanks!
Fred
JAFGJ
YellowX is offline
post #10 of 12 Old 09-03-2002, 06:33 AM
AgentZed
Guest
Originally posted by YellowX
Trippnk,
Thanks!
He said it right there in his message: "I bought the actuators at best buy for 20 bucks."
AgentZed is offline
post #11 of 12 Old 09-03-2002, 08:43 PM
4cornerzJeeper
4cornerzJeeper's Avatar
I've installed two kits, one in my 97 and one in room-mates 00. Both Jeeps have Viper 500 car alarms installed. The kits came from here http://www.autotechs.com/items/item82.htm, part # DS-102. It's a complete kit and plugs directly into the alarm power door lock jack. Installation was simple and took about 2 hrs for mine (first ever attempt) and about 1hr for my buddies.
The kit has worked flawless for sense 5/16/02 and works well with the alarm. When armed they lock, disarm unlock, start engine about 10sec delay auto lock while vehicle is running. Easy to unlock if you need to keep engine running and jump out to get mail or whatever.
No pic of the installs but like Trippnk said get the panel tool. I had one from way back when No need to drill holes in the panel for wires though. Just run them and some slit loom under the door strap hook.
I made our system detachable, by using 5 prong connections that accomidate the five wires required. So, like now, my doors are off and when ready I just plug and play again.
Having them is priceless. Never could live without them now. Get em and put em in yourself. I'll try to get photos.
4cornerzJeeper is offline
post #12 of 12 Old 09-03-2002, 11:16 PM
Knave
I have a 02 sport and kept the power lock from the dealership, but it's only on the drivers side. Could I the same thing be instaled on the passengers side and plug into the system?
Knave
Knave is offline
power locks Bmel17 TJ Wrangler Technical Forum 4 11-08-2006 02:39 AM
Power Door Locks and Power Windows JurassicMan JK Wrangler Technical Forum 8 07-12-2006 09:14 AM
power locks blueyj TJ Wrangler Technical Forum 3 03-16-2006 09:04 AM
Power Locks Abathur TJ Wrangler Technical Forum 7 06-24-2004 08:28 PM
Power locks drew622 TJ Wrangler Technical Forum 6 06-19-2003 10:38 PM
