plug off the solenoid - JeepForum.com
 2Likes
  • 1 Post By Rubi4MyMrs
post #1 of 8 Old 05-13-2021, 07:09 AM Thread Starter
pipeburn
Can any one tell me where this plugs into, it is coming from the starter solenoid and it is a female type and grey in color?????. thank you!.
pipeburn is offline
post #2 of 8 Old 05-13-2021, 01:20 PM
Jonny Jeep
Jonny Jeep's Avatar
It looks OEM but I see no connectors that shape in the 97 or 98 FSMs. What are the wire colours going into the connector? Starting to loose light here now. If I remember between rain showers tomorrow I'll have a look in my engine bay for anything similar.
Jonny Jeep is offline
post #3 of 8 Old 05-13-2021, 03:53 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
I assume you mean near the starter solenoid. If so it might be the battery temp sensor & if so the actual wire colors would have been brown/yellow & pink/yellow. But after all the years the colors could look like most anything.
pipeburn likes this.
Rubi4MyMrs is offline
post #4 of 8 Old 05-14-2021, 01:52 AM
Jonny Jeep
Jonny Jeep's Avatar
Battery temp connector is black and come off the loom running past the battery. I went through the connector pin out section looking for a connector that shape but didn't see anything that matched.
post #5 of 8 Old 05-14-2021, 12:30 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Looking further it could be one of the a/c pressure switches. The one in the 97 FSM is completely different looking, the ’98 looks a bit closer & the one in ’05 looks just like it. And if the a/c is an add-on anything is possible. I don’t know where the pressure switches are for the ‘97s or for an add-on unit for that matter but worth checking.
post #6 of 8 Old 05-14-2021, 07:07 PM Thread Starter
pipeburn
i found it johnny it is part of the starting mechanism going into the black box on passenger fender is were they connect. female side comes from starter silenoid and male end is by that black box!.
pipeburn is offline
post #7 of 8 Old 05-14-2021, 07:12 PM Thread Starter
pipeburn
yes it comes straight from the starter silenoid ,its a grey color plastic plug and i found it plugs into the male end right by the black box that mounts on passenger fender!
pipeburn is offline
post #8 of 8 Old 05-14-2021, 07:39 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Thanks for posting findings. It must be for an alarm system which would be an add-on option.
