Pledge on plastic windows?? / washing the soft-top - JeepForum.com
post #1 of 10 Old 01-16-2006, 07:43 PM Thread Starter
94523
Guest
I've heard/read a couple different places that Pledge is a good idea to be used on soft-top plastic windows. Is this true??
Also, what recommended for washing the soft-top? Brush? Sponge? Type of soap?
Thanks...
94523 is offline
post #2 of 10 Old 01-16-2006, 08:04 PM
Dragonmaster
Guest
pledge works great, not sure on the rest
Dragonmaster is offline
post #3 of 10 Old 01-16-2006, 09:33 PM
RHA1583
Guest
i dont know if its good for the top but a presure works well for mud stains
RHA1583 is offline
post #4 of 10 Old 01-16-2006, 09:45 PM
stedwest
The manual calls for a soft-bristle brush on the canvas top.
2003 SE, 4.88's, Yukon axles, Rancho springs, JKS Disco's & MML, RE trackbars, ZJ steering, and a bunch of other stuff my wife hasn't found out about...
stedwest is offline
post #5 of 10 Old 01-16-2006, 10:03 PM
JeepXJ00
Pledge works but not for long that's what I hate. Make sure you clean off the worst of the dirt first with the hose. Get a micro-cloth.
2003 JEEP WRANGLER X-4.0L 5spd
4" Superlift
33x12.5x15 Trxus
JeepXJ00 is offline
post #6 of 10 Old 01-16-2006, 10:17 PM
Kiwi_TJ
To keep my plastic windows nice I just use Mequires Plast-X. It seems to take out the fine scratches quite well. As for washing the soft top, I use the normal Mequires Gold Class car wash stuff, this clean most of it off, but not the mud stains. I have heard that Simple Green works well on mud stains, but I have not used it myself.
Hope that helps
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #7 of 10 Old 01-16-2006, 10:22 PM
dalby
not to hi-jack the thread, but while we're on the topic of cleaning soft tops... I have some sap from a pine tree staining my top. am i screwed or is there some way to get this off??
-2005 TJ X Electric lime green...
31x10.50 BFG AT's on 15x8 soft 8's
2.25" BB with Skyjacker Hydros
dalby is offline
post #8 of 10 Old 01-16-2006, 10:41 PM
magnum629
I found something that works great on soft top windows!! Its called pro honda spray cleaner & polish !! i worked in a honda bike show room and thats what we used on the bikes front windshields it also beads up like wax, repels water it says safe on all plastics rubber and paint. I been using it for years on my tjs tinted oem soft top windows. They sell it where they sell honda bikes and jet skis
magnum629 is offline
post #9 of 10 Old 01-16-2006, 11:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Pledge is nothing more than a temporary band-aid fix that fills small scratches with wax that eventually disappears. Better to polish out such scratches with a plastic window polish like Novus or Maguires.
Of course it's best to help prevent the scratches by never rubbing them when they're dirty and especially never using paper towels on them.
Gone to Florida 7/19-7/28.
Jerry Bransford is offline
post #10 of 10 Old 01-17-2006, 01:03 AM
victory red
it's not to bad with the right products. plastic windows: NOVUS makes a 3 piece kit. heavy scratch remover. fine scratch remover. and plastic clean and shine. i have used all three and the results are amazing! soft top: RAGGTOPP makes a kit of cleaner and protectant. it's approved by haartz, the original fabric manufacture for jeep tops. and 303 makes a top cleaner also. hope this helps! now for some part #'s. #771000-novus kit. #03143-raggtop cleaner. #01141-raggtop protectant. #030550-303 top cleaner. all can be bought at www.4wd.com PLEXUS is also a good product fo the plastic windows.
victory red is offline
Pressure washing soft top windows? ZeroGravity Wrangler General Discussion 5 05-29-2009 07:31 AM
Fogged plastic windows in a soft top.... bigjim in vegas TJ Wrangler Technical Forum 2 02-12-2009 09:14 PM
Noob question... Washing soft windows Cdash JK Wrangler Technical Forum 8 12-07-2007 12:27 PM
Tintend Plastic Windows on Soft Top JFiorentino TJ Wrangler Technical Forum 2 11-13-2005 07:21 PM
Washing Windows on Soft Top JeepKidd TJ Wrangler Technical Forum 12 09-09-2004 04:49 PM
