Plastic washer /bushing for slider bolt- front seat - JeepForum.com
 5Likes
post #1 of 33 Old 01-27-2018, 12:30 AM Thread Starter
TJnBC
Anyone know where to get this plastic little washer/spacer/buahing?? that goes on the bolt to the OEM slider? It is part of the roller on the slider. It is causing play in the seat...rocks back and forth slightly now that I put new seats in. Looks like part of it is broken and also worn out, tolerance is out.
Hoping someone has a Part # . If no luck might have to 3D print one up
Thanks in advance.
20180126_224127-1170x2080.jpg   20180126_224145-1170x2080.jpg   20180126_224225-1170x2080.jpg
2006 LJR...the madness begins again
TJnBC is offline
post #2 of 33 Old 01-27-2018, 07:16 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Thanks in advance.
It is called a flange bearing. There are many styles and materials. You will need to get accurate measurements of what you need and try places like McMaster Carr-
https://www.mcmaster.com/#standard-s...rings/=1bb53pt
TJnBC likes this.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 33 Old 01-27-2018, 07:45 AM
tworley
tworley's Avatar
McMaster would be a good place to start. They have everything. There was a thread over on WF a few years ago where someone replaced theirs with a bit from ACE hardware. Required careful cutting IIRC as they had to make it a flange.
Edit:
Here is the thread I remembered--no part numbers but gives you an idea what to look for, I have no idea how long something like that would hold up as I imagine it would take a beating from the seat (not sure if material is the same as what you can find on OEM or McMaster).
http://www.wranglerforum.com/f282/tj...ng-200256.html
TJnBC likes this.
Colorado Member 307
tworley is offline
post #4 of 33 Old 01-27-2018, 09:36 AM
JimSmith
Read something somewhere that someone took a plastic cutting board, used a hole saw to cut the right outside diameter, drilled the inside hole to spec, then ground a flange into it to make a new one. Fastened it on with a bolt and nut...... Seemed simple enough
TJnBC likes this.
'98 Chili Pepper 2.5, AX5, 33x12.5x15, 5.13, D30 Aussie, Super 35
JimSmith is offline
post #5 of 33 Old 01-27-2018, 10:09 AM Thread Starter
TJnBC
Thanks for the great info everyone! I posted elsewhere and everyone keeps telling me to 3d print the roller. I don't need the Roller , the bottom bolt head acts as the roller against the upper plastic roller. The upper usually wears and some have used a 3D printed roller to replace...
I will look for a Flange bearing...cheers
TJnBC is offline
post #6 of 33 Old 01-27-2018, 11:12 AM Thread Starter
TJnBC
Thanks Mr Blaine.
Is Mcmaster Carr a USA store? Do they have storefronts? Doesn't seem like up here we have them.
Thanks
TJnBC is offline
post #7 of 33 Old 01-27-2018, 12:17 PM
toximus
Thanks Mr Blaine.
Thanks
They do have some physical warehouses where you can pick up but it's mostly mail order. If you need a shipping quote before you buy you'll need to call or else you place the order, once it ships they charge you the actual amount, and then you pay.
Building the right way for 37s.
toximus is online now
post #8 of 33 Old 01-27-2018, 07:02 PM Thread Starter
TJnBC
They seem to be also known as shoulder washers. Can't find any up here today. May go across the line and see if any hardware stores have any
TJnBC is offline
post #9 of 33 Old 01-27-2018, 08:00 PM
mukluk
mukluk's Avatar
In the aviation field we called those hat bushings... gives you something else to look for.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #10 of 33 Old 01-29-2018, 02:41 PM
wvjeepguy81
You can buy these at lowe's in varying sizes. You could get one that is the right OD/ID and cut it to length.
wvjeepguy81 is offline
post #11 of 33 Old 01-30-2018, 06:30 AM
JeffBowser
JeffBowser's Avatar
I have the opposite issue. The plastic bearing disintegrated on mine, only its the one on top, with the captive pin. Obviously its there to keep the seat tensioned and from squeaking. Driving me nuts
JeffBowser is offline
post #12 of 33 Old 01-30-2018, 08:07 AM
JeepJJ
JeffBowser, I used a tire valve stem to repair mine. Just cut the large bottom part off and pry it on with a screwdriver.
JeepJJ is offline
post #13 of 33 Old 01-30-2018, 11:38 AM
JeffBowser
JeffBowser's Avatar
Interesting. I'll give that a try, thanks.
post #14 of 33 Old 01-30-2018, 01:04 PM
JeepJJ
I did it to both seats. I'm not the first to do it though. I got the idea off one of these forums.
JeepJJ is offline
post #15 of 33 Old 01-30-2018, 01:45 PM Thread Starter
TJnBC
What are they called @ Lowes? I have looked everywhere lol.
Any help in the right direction will help @wvjeepguy81 .
I have resorted to looking for junked TJs and taking them out of the seats...waiting on a fellow jeeper to show me the condition of the ones out of his.
TJnBC is offline
