Pictures of Dick Cepek 15" X 10 wide wheels on TJ? - JeepForum.com
 22Likes
post #1 of 20 Old 06-23-2021, 02:11 PM Thread Starter
Guy_Van_Horn
1936 CJ2A
Has anyone got any pictures of a set of Dick Cepek DC-2 15" X 10" wide wheels with 35" tires mounted, on a TJ Wrangler? The specs say they have a -47mm offset, and that makes me a little nervous. I'd like to see how far they stick out before buying a set.
Thanks in advance .
Sent from my SM-G973U using Tapatalk
Guy_Van_Horn is offline
post #2 of 20 Old 06-23-2021, 07:58 PM Thread Starter
Guy_Van_Horn
1936 CJ2A
I found this old forum thread, but only one of the replies had 15"X10" DC-2 wheels, and it doesn't give me a good front on or rear view:
https://r.tapatalk.com/shareLink/top...ink_source=app
post #3 of 20 Old 06-24-2021, 04:39 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
That's 3.65" backspacing. They will stick out 1" more than mine if you have the narrower non Rubicon flares.
numchuck and Guy_Van_Horn like this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #4 of 20 Old 06-25-2021, 11:45 AM Thread Starter
Guy_Van_Horn
1936 CJ2A
Thanks for the pictures. I have 6" Xenon flat fender flares on mine.
I'm thinking of buying just a single wheel first, and mounting my spare on it, and pitting it on the front to check it. If I like it, I'll buy four more. If I don't, I'm only out the mounting and balancing, shipping, and restocking fee.
TheBoogieman likes this.
post #5 of 20 Old 06-25-2021, 11:48 AM
Ironhead
Ironhead's Avatar
are you set on 15x10 rims? most prefer 15x8 with 3.75"-4" backspacing
Ironhead is offline
post #6 of 20 Old 06-26-2021, 12:46 AM Thread Starter
Guy_Van_Horn
1936 CJ2A
I have 8" wide wheels on it now. But the manufacturer recommends a wheel from 8.5" to 11" wide, with 10" being optimal. 35" tires on a 15" wheel already have a lot of side wall to begin with, but throw on top of that a wheel that is undersized on width... well it feels a bit wobbly to me going around corners.
I never liked having dark wheels with a black painted jeep anyway, so I think some brighter wheels would add some much needed contrast to the color scheme.
bruinjeeper likes this.
post #7 of 20 Old 06-26-2021, 12:48 AM Thread Starter
Guy_Van_Horn
1936 CJ2A
I found these pics online today of a jeep with 15X10 wheels, and I don't think it looks half bad.
post #8 of 20 Old 06-26-2021, 03:49 AM
draioks
Anybody know whether these will fit on a 2010 Jk? I realize the deleting must be around 3.75 for most 15 inch wheels to work however am contemplating whether this particular edge will fit with no issue? Anybody have any photos?
draioks is offline
post #9 of 20 Old 06-26-2021, 09:49 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Go with 15x8, not 15x10, if you offroad. The wider 10" wheel width makes it harder for the tire to stay seated when the tire is aired down for offroad use. That simply means you can't air down as much with a 10" wheel as you can with an 8" wide wheel. NO an 8" wide wheel is not too narrow for even 35x12.50 tires it's the preferred and most commonly chosen wheel width.
Jerry Bransford is offline
post #10 of 20 Old 06-27-2021, 09:19 AM Thread Starter
Guy_Van_Horn
1936 CJ2A
I know what you're saying, I've read that before. But I can't remember a time when I aired my tires down lower than 15 psi. If I really want to air down lower than that, then I ought to be getting wheels with bead locks. I suppose that's something to consider...
post #11 of 20 Old 06-27-2021, 05:17 PM
TheBoogieman
I never go below 10 psi on any of my Jeeps with 10" wide wheels. I don't think I would with 8" wide either. I had the charcoal Mammoth Boulder wheels on my white Sahara and thought about getting some for my current Jeep for a change.
post #12 of 20 Old 06-27-2021, 05:32 PM
TheBoogieman
They fit with the proper bolt pattern, backspacing and size.
Guy_Van_Horn likes this.
post #13 of 20 Old 06-30-2021, 05:52 AM
OBX-05TJ
FWIW here's a look at my TJ. I'd have to check on the rim width. The tires are 33x12.50R15LT.
TheBoogieman and Guy_Van_Horn like this.
OBX-05TJ is offline
post #14 of 20 Old 06-30-2021, 10:35 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
2020 J-Series Truck
Those are 8" wide wheels.
Wheelin98TJ is online now
post #15 of 20 Old 07-23-2021, 10:21 PM Thread Starter
Guy_Van_Horn
1936 CJ2A
Those look pretty good!
